Craig.Spainhower(at)exelo Guest
Posted: Fri Nov 09, 2007 1:21 pm Post subject: Zenith-List Digest: Jabiru FWF Ivoprop |
I strongly considered the Ivoprop with my lyc 0-235. The issues that lead me to choose the Warp drive prop were; the Medium prop is only rated (according to their website) for 100 hp on direct drive engines. Also using an in-flight adjustable prop prohibits the plane from being flown under LSA rules. I know of one individual running an Ivoprop and he installed the Magnum, which is twice the weight at 26 pounds. I really liked the idea of an in-flight adjustable prop but I think the Warp drive optimized for cruise will work fine for me.
Craig S.
Hi all,
Just wondering if anyone has any experience with the Australian Jabiru
FWF,as compared to the US version, for the XL.
Also, Ivoprop makes an electrically adjustable prop they claim will fit
on the 3300, any comments on this?
Darryl.
This e-mail and any of its attachments may contain Exelon
Corporation proprietary information, which is privileged,
confidential, or subject to copyright belonging to the Exelon
Corporation family of Companies.
This e-mail is intended solely for the use of the individual or
entity to which it is addressed. If you are not the intended
recipient of this e-mail, you are hereby notified that any
dissemination, distribution, copying, or action taken in relation
to the contents of and attachments to this e-mail is strictly
prohibited and may be unlawful. If you have received this e-mail
in error, please notify the sender immediately and permanently
delete the original and any copy of this e-mail and any printout.
Thank You.
Gig Giacona
Posted: Fri Nov 09, 2007 1:44 pm Post subject: Re: Zenith-List Digest: Jabiru FWF Ivoprop |
Completely unscientific but interesting none the less.
A Google search with the words
Ivo prop failures produces 60,400 results
Warp Drive Prop failures produces 14,900
Sensenich Prop failures produces only 970
Now think about how long Sensenich has been in business.
Also admittedly many people probably misspell Sensenich but I'll still go with them.
601XL Under Construction
Posted: Fri Nov 09, 2007 4:40 pm Post subject: Zenith-List Digest: Jabiru FWF Ivoprop |
Gig,
The search doesn't say whether these were failures contemplated,
failures searched or failure to go as fast as desired.
You need a better stick than that. Warp Drive owners props are lifetime
warranted which is hard to beat.
Lycoming is old too and still paying for their bad cranks.
Larry McFarland 601HDS at macsmachine.com
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=144838#144838
Gig Giacona
Posted: Fri Nov 09, 2007 11:19 pm Post subject: Re: Zenith-List Digest: Jabiru FWF Ivoprop |
Larry, I said it was completely unscientific but I think the difference between the three with that search term is interesting. That's big ass difference.
larry(at)macsmachine.com wrote: | Gig,
ProWash
Posted: Sat Nov 10, 2007 1:31 pm Post subject: Re: Zenith-List Digest: Jabiru FWF Ivoprop |
Unscientific and equally as interesting,,,
A Yahoo Search using the words
IVO prop success... 2930 Results
Warp Drive prop success.... 80200 Results
Sensenich prop success... 306 Results
I don't know if I feel better now or not.
_________________ R Craig
North Central Arkansas
N701LR CH701 SP ELB
30 HRS into Phase One testing
Do Not Archive |
purplemoon99(at)bellsouth Guest
Posted: Sat Nov 10, 2007 9:42 pm Post subject: Zenith-List Digest: Jabiru FWF Ivoprop |
How about a Princr P-Tip / You have the best of both worlds,climb,and
cruise. It's afixed pitch prop that flexes ! go to Aircraft Spruce or Google
Prince P-Tip propeller , It's one hell of a prop .,and the best people in
the world to deal with,if you call the co. to talk prop's,you'll talk to the
owner,Lonnie Prince. He's been buildind props for about 25 years or more
for guy's like Rutan, G.E. ,U.S. Gov. the list goes on and on Alot of people
have never heard of him, I haden't untill a friend of mine told me about
them, One of the best thing's I ever did for my plane. 130 H.P. (at)1800
F.P.M. ,and it will do better than that... Joe N101HD 601XL/RAM
jetboy
Posted: Sun Nov 11, 2007 12:09 am Post subject: Re: Zenith-List Digest: Jabiru FWF Ivoprop |
Darryl,
You need to do some research. Download the Jabiru manuals and see the props that they approve. I think the only non- wood one is the Sensenich hollow carbon fire. There is good reason for their decisions. But they wont tell you. And its not because they want to sell a line of props.
The Ivoprop attachment scheme is not up to the torque reversals applied by the Jab and the Warpdrive hub and blades get eaten for breakfast. I'm not making this up one of the associations - PFA or one of the UK equivalents - not sure - has AD'd these parts off of Jabirus and they can only be used elsewhere if no cracks and total time is less than 10 hours, otherwise they are scrap.
This problem is common to most direct drive engines, in the Jabiru case it may also be a factor in the flywheel attach bolts problem.
701 drivers have reported good results with the Prince p tips, and the wood Sensenich. Reports on the Carbon model yield same performance as a good wood one, only advantage is its ground adjustable.
Ralph
_________________ Ralph - CH701 / 2200a |
