Craig.Spainhower(at)exelo Guest
Posted: Wed Nov 07, 2007 7:14 am Post subject: Zenith-List Digest: Elevator cable rubbing |
I had the identical issue and installed a piece of fairlead material at the contact point. Fortunately this is an area that is easily inspected for wear of the fairlead or cable. Hopefully updated drawings have corrected this issue.
Craig S.
N601XS, 601xl lyc 0-235, wiring in progress
Mornin' all -
I was trial-rigging the cables last night in preparation for installing the Trio
autopilot servos and found that the upper elevator cable just barely rubs against
the bottom of the flanged hole in the seat back, maybe deflected 1/4" from
straight.? Re-checking the position of the fairleads just aft of the seat back
found everything per the drawings, and the cable runs through the upper elevator
fairlead hole as drawn.? Looking at a few builders' web sites, I don't
see this condition.? By the way, the arm length of the control stick is 120 mm
from pivot to cable hole.
Has anyone else seen this, and installed another piece of fairlead material onto
the seat back hole to prevent metal contact?
Thanks -
David Glass
This e-mail and any of its attachments may contain Exelon
Corporation proprietary information, which is privileged,
confidential, or subject to copyright belonging to the Exelon
Corporation family of Companies.
This e-mail is intended solely for the use of the individual or
entity to which it is addressed. If you are not the intended
recipient of this e-mail, you are hereby notified that any
dissemination, distribution, copying, or action taken in relation
to the contents of and attachments to this e-mail is strictly
prohibited and may be unlawful. If you have received this e-mail
in error, please notify the sender immediately and permanently
delete the original and any copy of this e-mail and any printout.
Thank You.
