Rusty Wing Strut Cross Brace
JimmieBlackwell(at)austin
PostPosted: Sat Nov 03, 2007 7:04 am    Post subject: Rusty Wing Strut Cross Brace Reply with quote
Yesterday, in a preflight I noted that the strut cross brace where the struts attach to the bottom of the wing has a 1/4" hole that is apparently the result of rust.
Has anyone else had this happen?
Would appreciate opinions as to whether this calls into question the structural integrity of the entire wing strut.
Jimmie
Model IV, 1200
lcfitt(at)sbcglobal.net
PostPosted: Sat Nov 03, 2007 12:33 pm    Post subject: Rusty Wing Strut Cross Brace Reply with quote
Jimmie,
I have been told that the cross brace is there to ease the construction
process - stabilize the whole lift strut assembly when fitting it to the
wing. With that thinking, it has no structural value at all. I think my
only concern would be where else there might be rust.
Lowell
dcsfoto
PostPosted: Sat Nov 03, 2007 4:21 pm    Post subject: Re: Rusty Wing Strut Cross Brace Reply with quote
download copy of AC 43-13 from faa.gov it shows many repairs.
David kelm do not arcive
PostPosted: Sat Nov 03, 2007 4:30 pm    Post subject: Rusty Wing Strut Cross Brace Reply with quote
Lowell
Thank you. That is great information. I certainly agree that where else
may be rusted does indeed have me concerned. As much as I dread it I am
planning on taking off the fiberglass fairings and having a look at the
whole strut unless someone knows a way to check it without taking off the
fairings.
Please correct me if I am wrong, but I do not recall anyone have this kind
of issue with the struts. Will keep all posted on what I find. I do not
want to even think about a strut failure.
Thank again Lowell.
Jimmie
avidfox
PostPosted: Sat Nov 03, 2007 5:24 pm    Post subject: Rusty Wing Strut Cross Brace Reply with quote
A common and simple method for inspecting for internal corrosion in
aircraft steel tubing and structures is to use a small pin punch and a
hammer. Yes, it will leave small punch marks on good strong metal but
if the material is corroded ...you will know.
How hard you strike the punch is a judgement call...but don't be shy.
There are ultrasonic methods of NDT also available to determine
material thickness but it will cost $$.
Here is a link to corrosion from FAA 43.13 1B, CHAPTER 6. CORROSION,
INSPECTION & PROTECTION
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2006.pdf
akflyer
PostPosted: Sat Nov 03, 2007 6:17 pm    Post subject: Re: Rusty Wing Strut Cross Brace Reply with quote
take a look in the phone book and see if there is an industrial xray company in your area. You should be able to get the struts xray'd for a 4 hour call out. UT may be a bit cheaper but I can see either one running you more than 2-300.. a heck of alot cheaper than folding a wing or taking the time to pull the fairings.. plus, you still wont know what the ID looks like unless you have some form of NDE done. Make sure you tell them it is experimental, and they dont have to be an FAA licensed station to perform the inspections.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
jose_m_toro(at)yahoo.com
PostPosted: Sun Nov 04, 2007 5:06 am    Post subject: Rusty Wing Strut Cross Brace Reply with quote
Jimmie:
I had a corrosion problem with the wing struts of my ex KF II. However, the problem was at the point where the jury struts attaches to the wing strut. I fixed the problem by ordering two new wing struts. Since the Kitfox factory do not have the jigs for the earlier model, I had to send the old, rusty struts in a wooden crate. The new struts were shipped back in the same crate. I'm very pleased and grateful of the support that I got from John and Debra McBean. If yours is a model IV, they most likely have the jig.
On the old Kitfox, the fairings are wooden like in the Avids. I recently learned that Kitfox went back to that method. The rust in my struts was due to water trapped near the jury strut attachment due to the wooden fairing. The new struts were installed without fairings. I flew the plane yesterday, and I can't tell any difference in speed. Seems to me like 70 mph is adequate for a model II. I'm not the owner anymore, but am still in love!!!
Hope this help,
José Toro
ex KFII/582
Float Flyr
PostPosted: Sun Nov 04, 2007 7:19 am    Post subject: Rusty Wing Strut Cross Brace Reply with quote
AC 43 is the basis on which all certified maintenance is accomplished. You
will find there are things in it that don't seem, on the surface, to be
related to homebuilt aircraft. Never the less those things are worth while
keeping in mind. If you have time, and a printer I would suggest you print
out each chapter as you use it and put it in a loose leaf binder. That
binder is a lot easier to carry to the plane when you want to refer to
something. Invariably when you want to do something the last thing you will
think of is searching AC43 for the right page(s) and then printing them.
There is w real wealth of information there. It took almost a century to
build and it's free... What more could you ask for???
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sun Nov 04, 2007 7:49 am    Post subject: Rusty Wing Strut Cross Brace Reply with quote
I used to use an awl. I would put it on the tube I wanted to test and push with about a hundred pounds of force or enough to lift the part. If the part is weak the awl will penetrate it if not it only leaves the tiniest marr of the finish which you can touch up with clear nail polish. If it penetrates the tube don't worry that part of the tubing would have to be replaced any way. The neat thing about this test is it can be done through the cloth skins.
Any one starting form scratch should inhibit their frame before doing any thing else. This involves drilling a very small hole somewhere in the lower part of the frame, at a corner and injecting about a cup of double boiled linseed oil. Seal up the hole with a PK screw and rotate the frame over the next few days to allow the linseed oil to penetrate through out the interior of the frame. Finally remove the screw and allow the oil to drain out over a day or two. Then replace the screw and paint over it.
A word of warning linseed oil in a rag can easily spontaneously combust when you do any wipe ups dispose of the oily rags in a good metal garbage can.... Don't ask how I know but a small rag will fill a good size hangar with white smoke to the point it is difficult to see. The more oil the more smoke.
[img]cid:436212215(at)04112007-1461[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  444 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
BTW if you do the inhibiting procedure I mentioned in the last post if you
have any small cracks in the welding the linseed oil will seep out at that
point and show you exactly where the crack is. It takes years for the oil
to dry in the presence of oxygen. Sealed inside your frame it should never
dry so any time you see the wet form the oil you will know there is a crack
in that place. Also there won't be enough seepage to have to worry about
spontaneous combustion.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sun Nov 04, 2007 12:16 pm    Post subject: Rusty Wing Strut Cross Brace Reply with quote
Wow! I have sure received a lot of good information from this question. My thanks to each of you. The knowledge and experience on this list makes it possible for me to have fun with my Kitfox.
Again, I am most appreciative of each of your great suggestions.
Jimmie
do not archieve
