sam(at)fr8dog.net Guest
Posted: Fri Oct 26, 2007 1:59 am Post subject: Fuel Valve Problem |
I expected a lot more from Van's.
bob.kaufmann wrote:
Not that far along but did you expect anything less from Van’s. It’s
not a Lycoming so no help from the factory, and wish that I was that
far along. Bob K
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Sam Marlow
*Sent:* Thursday, October 25, 2007 5:02 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Fuel Valve Problem
Thanks again, this list has been very gracious.
Sam
William Curtis wrote:
Sam,
Not a problem, that question was posed with tongue planted firmly in cheek:-)
Do not archive.
William
http://wcurtis.nerv10.com/
Posted: Fri Oct 26, 2007 2:05 am Post subject: Fuel Valve Problem |
Well, yes, anything to verify where the fuel is coming from, but I
already know the fuel valve is bypassing internally. That's the only
place fuel can travel from one side to the other. The question is why.
Chris and Susie McGough wrote:
<VHMUM(at)bigpond.com>
Sam would you think this might help to verify the source of the
problem if you did it.
regards Chris
Posted: Tue Oct 30, 2007 8:37 pm Post subject: Fuel Valve problem |
Just wanted to let everyone know, I changed the fuel selector, and that fixed the fuel shutoff problem as well as the venting overboard after refueling. Everything was plumbed properly, it was a defective valve, part #V407P-4, that is standard issue in the RV-10 kit supplied by Van's.
I would suggest everyone test there valve periodically for proper operation! Be safe, stay informed, this forum is a valuable resource!
Sam Marlow
#40157
Dave(at)AirCraftersLLC.co Guest
Posted: Tue Oct 30, 2007 9:41 pm Post subject: Fuel Valve problem |
Sam,
Did you take apart the faulty valve?
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Tuesday, October 30, 2007 9:19 PM
Subject: Fuel Valve problem
Sam Marlow
#40157
Posted: Wed Oct 31, 2007 5:07 am Post subject: Fuel Valve problem |
Idid, and it looked perfectly normal. No cracks in the plastic, smooth operation, nothing one could see.
Dave Saylor wrote: [quote] Sam,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sam Marlow
Sam Marlow
#40157
_popupControl();[b]
