Primer preparation question
egodfrey(at)ameritech.net
PostPosted: Mon Oct 29, 2007 6:46 am    Post subject: Primer preparation question Reply with quote
Listers,
For all of you who have primed your parts with Akzo, how did you
deal the steel parts, such as the nut plates and the WD-415 Trim Cable
Anchor Bracket?
Ed Godfrey
40717
rv10(at)sinkrate.com
PostPosted: Mon Oct 29, 2007 7:52 am    Post subject: Primer preparation question Reply with quote
Bad Gas?
Eric_Kallio
PostPosted: Mon Oct 29, 2007 8:30 am    Post subject: Re: Primer preparation question Reply with quote
I roughed the WD-415 with medium grit sandpaper then wiped with acetone then a clean dry cloth before priming. Almost 2 years since completing that section and still have good adhesion. As for the nutplates I have been using the same old scotchbrite scuffing method that we are all SOOOOO familiar with. Good results so far.
Eric Kallio
40518
