matronics(at)cencula.com Guest
Posted: Wed Oct 24, 2007 4:18 pm Post subject: Aileron trailing edge skislope effect |
Greetings listers,
I'm working on my ailerons (RV-7A) and seem to be getting a skislope effect at
the trailing edge near the ribs. Some places are worse than others. You can
see what I mean by checking the third photo here:
http://www.our7a.com/20071015.html
or the second and third photos here:
http://www.our7a.com/20071024.html
Any thoughts on what's causing this?
It seems to like the trailing edge bend may not be in exactly the right
location.
I sent this very question to Van's and got the following response:
"Mike,
I looked at your aileron trailing edge photo and it is not perfect, but it's
acceptable and within tolerance. It will not cause you any flight problems.
Bruce Reynolds
brucer(at)vansaircraft.com"
Although it's nice to know that it's still safe, I really need a *solution*.
Mike Cencula
wgill10(at)comcast.net Guest
Posted: Wed Oct 24, 2007 6:03 pm Post subject: Aileron trailing edge skislope effect |
Mike,
It couldn't hurt to order another rib for the worst ski slope end to see
if that improves the fit.
Bill
rv7(at)b4.ca Guest
Posted: Wed Oct 24, 2007 7:21 pm Post subject: Aileron trailing edge skislope effect |
On 17:15 2007-10-24 "Michael D. Cencula" <matronics(at)cencula.com> wrote:
| Quote: | Although it's nice to know that it's still safe, I really need a
*solution*.
Some alternatives:
1. Make a new rib for the worst location, drilling holes to match the skins.
2. Remove the clecoes from the worst rib, and drill new holes that match
the skins in the spaces between each of the existing holes. When you get
to painting, fill the unriveted holes and then paint over them.
3. (Van's suggestion) Drive the rivets as-is, and rig the plane to fly
straight and true once you're done.
Personally I wouldn't go looking for extra work, but if pushed i'd probably
opt for option 1.
-Rob
Dale Ensing
Posted: Thu Oct 25, 2007 2:22 am Post subject: Aileron trailing edge skislope effect |
Mike,
The trailing edge doesn't look too bad to me. However, you really will not
know if it causes a trim problem until you fly the airplane. The shape can
be perfect to the eye but still require altering because of a "heavy wing".
Initially my 6A flew hands off perfectly until I had the plane painted.
After checking all the alignment points of both ailerons, the gear leg
fairing etc., only thing I found was an impression on the top of the right
aileron midway along the trailing edge. It looked like someone in the paint
shop picked up the aileron by the trailing edge and put a slight
dent/depression in the top skin right where a thump would have squeezed it.
Following Van's procedure for correcting a heavy wing,
http://www.vansaircraft.com/pdf/Wing_Heavy.pdf, I had to reduce the radius
of the right aileron trailing edge and increase the radius of the left
aileron trailing edge to get back to the 'hands off' trim I had before
painting.
Dale Ensing
RV-6A
EAA TC & FA
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Carl
Posted: Thu Oct 25, 2007 5:29 am Post subject: Aileron trailing edge skislope effect |
I believe I have seen this issue before and it was traced to skins that were
bent wrong and Van replaced them. You may want to check with Ken.
Carl W Bell
New Venture Consulting
Mobile: 803.640.2760
www.newventureconsulting.com
carlbell(at)gforcecable.com
_________________ Carl Bell
Building N947CB
RV 7A |
panamared5(at)brier.net Guest
Posted: Thu Oct 25, 2007 12:41 pm Post subject: Aileron trailing edge skislope effect |
After looking at the pictures, I don't see the problem. If this is
all you have to be worried about, then you are building a real fine RV.
My RV has some cosmetic imperfections, dents, smiles, scratches
whatever, now 5 years into flying, things that I thought were so
important, I can not even find them, let alone allow it to bother me.
This is sort of in the category of "who cares?" I would never have
noticed without the straight edge in the picture. If you are
building for flying, then move on, if you are building an Award
Winner that will be exhibited in some technical museum, keep redoing
it until it is perfect.
If after flying the RV for a few years and it still bothers you, then
rebuild it. But, by then you will be having way too much fun to
worry about cosmetic accuracy.
Bob
RV6 "Wicked Witch of the West"
At 07:15 PM 10/24/07, you wrote:
Greetings listers,
effect at
Posted: Tue Nov 06, 2007 10:11 pm Post subject: Aileron trailing edge skislope effect |
RV-Listers,
Thanks all for the comments and suggestions. I thought I'd post my
solution in case anyone runs into the same issue. I ended up ordering
new ribs from Vans that didn't have prepunched flanges, then match
drilled them to the skins. They actually gave me a break on the price,
so all four ribs came to only about $15!
If interested, you can see how the fit compares:
Original prepunched rib: http://www.our7a.com/images/20071024-02-tn.jpg
New non-prepunched rib: http://www.our7a.com/images/20071106-04-tn.jpg
Best regards,
Mike Cencula
RV-7A wings
Bob wrote:
noticed without the straight edge in the picture. If you are building
for flying, then move on, if you are building an Award Winner that
will be exhibited in some technical museum, keep redoing it until it
is perfect.
rebuild it. But, by then you will be having way too much fun to worry
Bob
> Greetings listers,
> effect at
jan(at)claver.demon.co.uk Guest
Posted: Wed Nov 07, 2007 12:23 pm Post subject: Aileron trailing edge skislope effect |
You did the right thing ... !
Jan
