FireFly Landing Gear Leg Strength Improvement
Goto page Previous  1, 2
PostPosted: Tue Oct 09, 2007 12:48 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Hi Chris:
All the newer Kolb models have much stronger wings than the old 5 rib FS. You don't have to worry about pulling a wing off a FF. It has 22' wing span, very short wing panels, and lots of ribs. Very similar to the Sling Shot.
John , Just a question after reading the distuction of those "tiny wings" on your firestar, Chris
capedavis(at)yahoo.com
PostPosted: Tue Oct 09, 2007 1:15 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
John , I knew you were the right man to ask thank you Do you know where on can find a picture of the plan or a description of the wing from TNK itself ? Thanks again for the reassuring description , the slingshot is quite a rugged model . Chris
PostPosted: Tue Oct 09, 2007 1:27 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Chris:
Call Travis, or maybe one of the guys on the Kolb List will send you a scan of the wing plans.
[quote] Thanks again for the reassuring description , the slingshot is quite a rugged model . Chris
PostPosted: Tue Oct 09, 2007 1:45 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Hi Will:
I am sure Thom can reuse his H brace. However, I would not consider it, even if it had not taken the hit it did.
Glad you got to fly over Niagra Falls.
First time I flew over Niagra Fallls was 1988. Departed the Falls, flew back up the river, over Grand Island, and lost the engine halfway between the island and the mainland. Elected to force land on Grand Island. Got really busy just prior to touch down, division of attention, stalled the FS and dropped in left wing low. Got the left gear leg socket which was ripped right out of the gear leg socket tube cluster. Did not take a whole lot to do this on an original FS. Also, the lower rear longerons always bent out of column as the result of a hard landing, or striking an immoveable object on the ground.
I went back and took a look at the tailboom photo again. No way would I even consider reusing that H brace.
Thom said he will trace the holes on to a paper and use it on the tailboom as a stencil, sounds like a good idea.
[quote] Yesterday I got to fly with him over Niagara Falls.
tkrolfe(at)usadatanet.net
PostPosted: Tue Oct 09, 2007 2:55 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
John Hauck wrote:
Hi Will:
Guy's,
>From one who has experienced his own personal disaster with a Kolb, I would recommend that you take heed of someone who has much more experience in the field of wrecking planes. I'm surprised that he tries as hard as he does to share his experience with the group, since many tend to ignore what he has learned. I found that John will share any and all knowledge he and his brother Jim have acquired over the years to this groups benefit.
Discount this advice at your own peril !!!
If you aspire to be the new test dummy that is you prerogative. I would rather learn as much as possible from those before me so that I might fly incident free!
Terry - FireFly #95 750 hr.s
jbhart(at)onlyinternet.ne
PostPosted: Tue Oct 09, 2007 5:01 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
jindoguy(at)gmail.com
PostPosted: Tue Oct 09, 2007 5:45 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Anecdotal evidence to be sure, Jack, but consider this. Back in the beginning days of hang gliding, some manufacturers got the idea of using 1/8" cable as a hang strap for the pilot. Less drag was the big selling point, although worrying about drag on a standard Rogallo just seems retarded, now. But, the few who touted it went ahead and installed them. Why, the breaking strength is 2,000lb., so strong you don't even need a backup. We were all 170 lb. FAA size people then as we were still eating food at that time. Heck, this thing is good for nearly 12G's. Within weeks, several pilots had fallen from their wings. It seemed it really didn't take a big negative G going over the falls coming out of a thermal to produce one heck of a momentary load and *SNAP*. 1" tubular nylon hang straps, with a 5,000 lb. breaking strength and the ability to take a generous stretch became the norm after that, with hefty backups, too. Drag be darned. Just a thought, it is experimental aviation, after all.
Rick
On 10/9/07, Jack B. Hart <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)> wrote:[quote] --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
From: "Ron Hoyt" <rrhoyt_list(at)msn.com (rrhoyt_list(at)msn.com)>
WhiskeyVictor36(at)aol.co
PostPosted: Tue Oct 09, 2007 8:04 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
In a message dated 10/9/2007 1:37:46 P.M. Eastern Daylight Time, riddletr(at)gmail.com writes:
I understand why the boom broke the way it did but could not communicate it effectively to Bob Bean even when he saw the whole thing so I'm not sure I can communicate it to you and the rest of the group.
Thom,
My flying buddy has an original FireStar with the 5 rib wing.  One day while parked, not tied down, the wind picked up the left wing and tipped the plane until the right wing hit the ground. The left main wheel came off the ground. Now the right wing tip, right main wheel and the tail wheel were supporting the plane on the ground. The wind continued to push the plane over onto its back. Damage was quite extensive and very similar to yours. The tail boom broke at the rear of the H section.
You may have seen my report a year or so ago. We rebuilt it and modified the wings by installing 10 ribs, along with the 1/2" aluminum angle braces John h. talks about.
Bill Varnes
Original Kolb FireStar
Audubon NJ
See what's [quote][b]
slyck(at)frontiernet.net
PostPosted: Wed Oct 10, 2007 4:55 am    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Thom may be right about the vertical impact force bending the
tailboom as there is
zero evidence of bruising at the tail top parts.
The sequence went as follows: high stall, left wheel snaps on
impact, wheel zips across to the right.
(at this point one would think that the tail would hit too, causing
an UPWARD bend in the tailboom)
But since my boggled brain was focussing on staying out of the errant
wheel trajectory I completely
missed that part of the action.
Anyway the plane continued sliding, nose down for another 15' until
the stub picked a favorable
point to dig in and over Thom went. Outside half loop.
As far as the H-tube goes, I would give it a close inspection when it
is revealed.
When I rebuilt my bent left wing I had to replace its H-tube because
it was one of the
all aluminum types. The rivets go into a blind hole on them and
there is NO way to get them out.
BB
WillUribe(at)aol.com
PostPosted: Thu Oct 11, 2007 1:22 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
Hi John,
I'm sure John will inspect it after it is removed and will replace it if needed.
Why did you loose your engine and how did you get your FS back home?
Will Uribe,
FireStar II N4GU
El Paso, TX
In a message dated 10/9/2007 5:46:21 P.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes:
Hi Will:
See what's new at .
PostPosted: Thu Oct 11, 2007 3:06 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
At 01:23 PM 10/9/07 -0700, you wrote:
I have tried the cables between the wheel axles on a Mark III Classic.
They work great. I am sure that some cruising speed is lost. I intend
to put a fairing over them. I now use one 7/64" and two 1/16" cables so
that they will break at different times when overstressed. On one
landing recently, I did not account for the wind gradient cause by a 25
mph headwind and dropped it in hard. Both 7/64" tension wires ripped,
but the gear leg did not bend. That proved a point to me. Most agree
that wheel landings are the way to go. I definitely agree. These hard
landings are probably having a negative effect on the boom tube. I was
wondering how to inspect it. Vic in Sacramento
Vic,
You were the one that triggered me to look at cables. You mentioned a
Challenger, and I took some time in a Challenger to be sure that I did not
do something stupid when I flew the FireFly for the first time. I asked the
instructor for lots of emergencies, and he gave them to me. One was and
engine out and I had to land on a grass strip that crossed an asphalt
runway. I got down ok, but as we passed over the asphalt runway, the cable
broke between the gear legs. That was the end of my flight time. The
owner had a jig on which he made these cable sets.
Jack B. Hart FF004
Winchester, IN
PostPosted: Sun Oct 14, 2007 2:29 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
home?
| Will Uribe,
Hi Will:
Because I had fouled a BR8ES early on with the new FS, I was running
BR8EV fine wire plugs. Remember, this was 1988. Ran great on the
EV's until halfway across the Niagra River from Grand Island to the
mainland north of Buffalo, NY. All the sudden the 447 shut down on
one cylinder. I new there was no need to try and nurse a one cylinder
447, so I elected to glide back over Grand Island where I had seen
some overgrown weed fields near the highway. Decided to land on the
highway right of way, but changed my mind at the last moment to land
over the fence in the field. Was concerned I was over Canada, because
I had seen Canadian flag flying at a toll booth on the highway, had
diversion of attention, stalled the airplane about 10 or 15 feet above
the ground.
Was saved by a young man that heard my plea on a local radio station.
The crash site was covered up with law enforcement, reporters, TV and
radio, newspaper, straphangers, and on and on.
I rented a uhaul truck, dismantled the aircraft and hauled it to
Niagra International Airport. A gentleman there had a hanger and
repair shop. We patched the FS back together enough to fly. The
airplane controls were out of rig, the landing gear was bent, both of
them, the nose cone was busted up and taped back together with duct
tape. Fabric on the fuselage was patched and replaced. Polybrushed
and not paint or polyspray. I flew it out of Niagra International
Airport and back to Gantt International Airport, Alabama. Took me
three days to get home.
Take care,
PostPosted: Sun Oct 14, 2007 2:30 pm    Post subject: FireFly Landing Gear Leg Strength Improvement Reply with quote
home?
| Regards,
| Will Uribe,
Will:
Forgot to mention how I lost the engine. An electrode tip off the
BR8EV seperated and failed that plug. The tips were fine wire and
fused or cemented to the plug core. I never ran another EV plug after
that.
Page 2 of 2
