Dale Ensing
Posted: Tue Oct 09, 2007 10:50 am Post subject: Sealing fuel tank inspection plate & sender |
You might consider using SS Allen head cap screws on the inspection plates
and the sender mounts in lieu of the Phillips head screws. In my opinion; 1.
They make it easier to more evenly torque the screws. 2. The bottom of the
head of the cap screws have a slight undercut which makes a sealing edge out
at the periphery of the screw head. 3. And, if you need to remove or
re-torque the screws with the wing on, it is much easier to do with a short
Allen wrench segment in one of the very small right angle ratchet
screwdrivers handles.
I had done my 6A tanks with the cap screws and when Van's came out with the
SB, getting the screws out and reinstalling them was very simple.
Dale Ensing
| Quote: | Part of your decision may have to do with what happens if you have to
remove the sender. It's a lot easier just unscrewing and pulling it off if
all you've used is cork. When meetingthe Van's SB, I pulled both access
plates off -- one with cork and proseal and one with just proseal -- and
found both were quite an exercise.
// Rubber gaskets - just in case they don't work and I have to remove the
sender, I intend to use the provided rubber gaskets without sealer, but
put plenty of sealer on the screws before assembly. Good idea?
I did not use the rubber gasket because I found it quite difficult with
the screws on the call-out to get the sender attached. To me, it seemed
the rubber gasket was too think. I just ProSealed.
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Oct 09, 2007 2:15 pm Post subject: Sealing fuel tank inspection plate & sender |
Just another data point...
When I performed the work for the service bulletin, I had a nightmare of a
time with the Stainless Steel fasteners I planned to use as replacements for
the Phillips screws. I stripped out several of the heads (Allen Wrench
type) before I went back to the Phillips screws.
KB
Dale Ensing
Posted: Tue Oct 09, 2007 5:22 pm Post subject: Sealing fuel tank inspection plate & sender |
Kyle
Was wondering.....did the socket heads of the Allen head cap screws strip
out because of the initial torque when first installed? Or, where there
other factors? It is easy to over torque them because of the hex socket vs.
the Phillips.
Dale
for the Phillips screws. I stripped out several of the heads (Allen
Wrench type) before I went back to the Phillips screws.
KB
| Quote: | >
> plates and the sender mounts in lieu of the Phillips head screws. In my
> opinion; 1. They make it easier to more evenly torque the screws. 2. The
> bottom of the head of the cap screws have a slight undercut which makes a
> sealing edge out at the periphery of the screw head. 3. And, if you need
> to remove or re-torque the screws with the wing on, it is much easier to
> do with a short Allen wrench segment in one of the very small right angle
> ratchet screwdrivers handles.
> the SB, getting the screws out and reinstalling them was very simple.
> Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Oct 09, 2007 5:42 pm Post subject: Sealing fuel tank inspection plate & sender |
It has been a couple of years since my bad experience, but my recollection
is that the heads stripped simply because of the torque required to run the
screws down into the platenuts. They were not even snug when they stripped.
I was very surprised that they stripped out in platenuts that had already
been run-in.
KB
rv8a2001(at)yahoo.com Guest
Posted: Tue Oct 09, 2007 7:29 pm Post subject: Sealing fuel tank inspection plate & sender |
I beleive socket head cap screws are recommended here.......if memory serves, much harder to strip than phillips.
Scott Bilinski
RV-8a
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
mike109g6(at)insideconnec Guest
Posted: Tue Oct 09, 2007 10:42 pm Post subject: Sealing fuel tank inspection plate & sender |
Dale,
Try SS Torx screws, www.microfasteners.com they take a #20 6 point torx bit,
at any hardware store. Same driver as premium deck screws. You cannot strip
them.
Mike H
acepilot(at)bloomer.net Guest
Dale Ensing
Posted: Wed Oct 10, 2007 5:49 am Post subject: Sealing fuel tank inspection plate & sender |
Good point Jim. The round and button head screws have a much smaller hex
socket relative to the screw size than do the Allen heads (which is what I
was suggesting and used on my tanks).
Dale
| Quote: | Dale and others,
I bought some SS 8X32 round or button head screws that had the annoying
habit of stripping out during installation.
The Allen wrench key socket size was 'about' 3/32" ..(Its been a while)
Later I bought a box of SS 8X32 "Allen head' screws. These required an
Allen head socket wrench size of 'about' 3/16" and are plenty strong
enough to be used in places such as the fuel tanks etc.
I have yet to strip out one of these Allen head screws even when being
deliberately abusive during a test to see what they could take.
They have been holding back fuel for a year so far and they offer far
better access in tight quarters than their Philips head type cousins.
Jim in Kelowna
> Kyle
> vs. the Phillips.
> Dale
>> <kboatright1(at)comcast.net>
>> a time with the Stainless Steel fasteners I planned to use as
>> replacements for the Phillips screws. I stripped out several of the
>> heads (Allen Wrench type) before I went back to the Phillips screws.
>> KB
>>> The bottom of the head of the cap screws have a slight undercut which
>>> makes a sealing edge out at the periphery of the screw head. 3. And, if
>>> you need to remove or re-torque the screws with the wing on, it is
>>> much easier to do with a short Allen wrench segment in one of the very
>>> small right angle ratchet screwdrivers handles.
>>> Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Dale Ensing
Posted: Wed Oct 10, 2007 5:56 am Post subject: Sealing fuel tank inspection plate & sender |
I have never had any problems stripping the sockets on Allen head cap
screws. Matter of fact- I run a Allen head cap screw into new plate nuts to
establish a "thread" before inserting Phillips head screws to reduce the
wear on the Phillips head.
Dale
RV-6A
Aero Plantation
Weddington NC |
jim jewell
Posted: Wed Oct 10, 2007 9:44 am Post subject: Sealing fuel tank inspection plate & sender |
Hi Dale,
I to have often used the Allen head cap screws breaking in new plate nut
threads.
Way back when ordering tools etc. I bought a small container of Beolube from
Avery tools. I have used this product on every screw in my 6-A. It
conditions the plate-nut threads increasing their overall utility without
unduly reducing the plate-nut's grip .
I have used this product as suggested as a cutting agent when drilling holes
with the drill press and the lathe.
I have loaned out the small plastic tube of soft waxy soapstone like Beolube
to others and still have about two thirds of the original container left.
A must have product for me.
Jim in Kelowna
_________________ "I never make mistreaks" |
