Posted: Sun Sep 30, 2007 10:10 am Post subject: AeroElectric-List: |
John Burnaby wrote:
| Quote: | *Yes, another motor moves the sheet.*
*RE the wiper motor being unidirectional, The thought was, as Charlie suggested,*
* to stop the motor at BDC, when S2 opened, and when the sheet moved from*
* contact with S2, now closed, the motor would continue to run back to the "Park" position. *
*The departure from Charlie's example is that the cycle shouldn't require any*
* other operator input beyond depression of S1. This being a DC motor, *
*could not the power leads be swapped for the motor to run in reverse, if desired?*
*Here's the motor and its terminals. *
http://www.scary-terry.com/wipmtr/wipmtr2.htm
snipped
If something else is moving the sheet, allowing S2 to close, then the
motor should restart & run back to 'home' position.
