wgill10(at)comcast.net Guest
Posted: Sat Sep 29, 2007 10:22 pm Post subject: AF-2500 Calibration |
I’m trying to calibrate the AF-2500 and have questions regarding the Manifold Pressure and Amps process. It seems that two known data points must be entered for each and I’m unsure how to do this. I appreciate any suggestions from those experienced using the AF-2500. Thanks.
Have a great weekend,
Bill Gill
RV-7 (preparing for inspection)
Lee’s Summit, MO
bobbyhester(at)newwavecom Guest
Posted: Sun Sep 30, 2007 4:45 am Post subject: AF-2500 Calibration |
My came with those setting already set, your should be also.
William Gill wrote: [quote] <![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]-->
Bill Gill
Lee’s Summit, MO
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
Posted: Sun Sep 30, 2007 5:25 am Post subject: AF-2500 Calibration |
Hello Bobby,
AFS said to set the first cal point for manifold pressure to the ambient condition. Then, pull a KNOWN vacuum with corresponding baro pressure for the second cal point. When I start the engine, my manifold pressure reads “9” at idle. What data appears in your cal menu for the second data point for manifold pressure?
I believe a similar process is necessary for the Amp sensor.
-----Original Message-----
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobby Hester
Sent: Sunday, September 30, 2007 7:44 AM
To: rv-list(at)matronics.com
Subject: Re: AF-2500 Calibration
My came with those setting already set, your should be also. <![if !supportLineBreakNewLine]> <![endif]>
William Gill wrote:
<![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]-->I’m trying to calibrate the AF-2500 and have questions regarding the Manifold Pressure and Amps process. It seems that two known data points must be entered for each and I’m unsure how to do this. I appreciate any suggestions from those experienced using the AF-2500. Thanks.
Bill Gill
Lee’s Summit, MO [quote] href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com - The RV-List Email Forum - --> http://www.matronics.com/Navigator?RV-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com [b]
RobHickman(at)AOL.COM Guest
Posted: Tue Oct 02, 2007 10:22 am Post subject: AF-2500 Calibration |
The system is sent out calibrated so you should not have to do anything. Yo can check it by setting your altimeter to zero feet and then seing if the setting matches the manifold pressure.
We have our new forum up and running just for this type of question:
http://www.advanced-flight-systems.com/forum/
Sincerely,
Rob Hickman
See what's new="_blank">Make AOL Your Homepage.
