john_graham
Joined: 09 Aug 2007 Posts: 45 Location: Algonquin, IL
Posted: Mon Sep 24, 2007 9:00 am Post subject: Flap storage |
Hello fellow fliers! Quick questions as I continue to
learn about my Yak-52. When done flying, is it better
to leave the FLAP handle in the full forward position
or in the neutral position? Or does it matter one way
or the other? Thanks!
John P. Graham
CubFlyer1940(at)Yahoo.com
Cell phone (847) 641-1330
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more!
_________________ John Graham
N15YK 1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330 |
cjpilot710(at)aol.com Guest
Posted: Mon Sep 24, 2007 9:45 am Post subject: Flap storage |
In a message dated 9/24/2007 1:02:21 P.M. Eastern Daylight Time, cubflyer1940(at)yahoo.com writes:
John,
I would and teach to put the handle back in neutral. Operationally system wise it wouldn't make much difference, if you don't you are simply pressurizing the up side of the flap actuator. If you than select the flaps down, you will have to go passed neutral, to the down side. You could mess up and you could accidentally stop in the neutral position and not get any flaps at all.
Usually it is after landing that the flap handle is moved to the up position. Try using this technic. After landing AND clear of the runway, put your hand on the flap handle. Confirm that you do have the flap handle, by looking at it. Move the handle to the up position and leave your hand on the handle until the flaps are up. Than move the handle to neutral.
Jim "Pappy" Goolsby
| Quote: | --> Yak-List message posted by: John Graham <cubflyer1940(at)yahoo.com>
John P. Graham
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and es Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> ======================
See what's new="_blank">Make AOL Your Homepage.
pa3arw(at)euronet.nl Guest
Posted: Mon Sep 24, 2007 10:34 am Post subject: Flap storage |
John. Ref Pappy’s comment:
Especially the bold part “by looking at it” is important….I know…I found out the hard way…
Hans
Van: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] Namens cjpilot710(at)aol.com
Verzonden: maandag 24 september 2007 19:45
Aan: yak-list(at)matronics.com
Onderwerp: Re: Flap storage
John,
Usually it is after landing that the flap handle is moved to the up position. Try using this technic. After landing AND clear of the runway, put your hand on the flap handle. Confirm that you do have the flap handle, [b]by looking at it[/b]. Move the handle to the up position and leave your hand on the handle until the flaps are up. Than move the handle to neutral.
Jim "Pappy" Goolsby
John P. Graham
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 01234
dsavarese(at)elmore.rr.co Guest
Posted: Mon Sep 24, 2007 11:39 am Post subject: Flap storage |
John,
There is no functional benefit to moving the flap handle away from the UP position. In fact, you are depressurizing the flap actuator which removes all UP pressure on the flaps. Then when you decide to move the flap handle to either the UP or the DOWN position, you consume more air because you have to repressurize the flap actuator. Since the flaps are UP after you put the flap handle in the NEUTRAL position, if you put the flap hand to the DOWN position, the flaps will slam to the down position because there is no pressure in the actuator to act as a cushion when the flaps are moving. Hope this makes sense. Bottom line....obtain a copy of the Russian translated flight manual and you will find there is no mention of putting the flap handle in neutral except to give control to the other cockpit. That is the only reason for the neutral position. If it were a single cockpit airplane, it would not need a neutral position. Dennis
---- John Graham <cubflyer1940(at)yahoo.com> wrote:
John P. Graham
brian-1927(at)lloyd.com Guest
Posted: Tue Sep 25, 2007 10:19 am Post subject: Flap storage |
On Sep 24, 2007, at 11:32 AM, Hans Oortman 1 wrote:
| Quote: | John. Ref Pappy’s comment:
It is funny how so many people have made the same mistake of thinking
they are raising the flaps and instead raise the gear. You would
think that, since there are nowhere near each other, this failure
mode would be infrequent but for some reason it is not. The best
insurance is to ensure that you slide the gear-lock slide in place as
soon as you place the gear lever in the down position regardless of
the reason.
(I *KNOW* that religious use of the gear slide-lock *WILL* save your
airplane's belly. Please do not ask me how I know this.)
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
jorgen.nielsen(at)mweb.co Guest
Posted: Tue Sep 25, 2007 11:10 am Post subject: Flap storage |
My buddy and I hangar together (2 x Yak52) - we have a standing arrangement
that if ever we see the gear slide lock not engaged, a case of beer is
purchased by the culprit...
Bill Tally
Posted: Tue Sep 25, 2007 11:57 am Post subject: Re: Flap storage |
I have to agree with Dennis on this one. The flaps come down very forcefully. (And this is true despite the presence of orfices in each connection to the shuttle valves mounted on the flap actuator.) Having some opposing pressure in the actuating cylinder helps mitigate that.
Also, I would think that there might be some value in maintaining pressure to keep the flaps locked in the up position. There are ball locks inside the actuator to do that, but it seems to me that they will do their job better when the chuck is under pressure, forcing the balls into the groove. (Of course nobody is going to do any tail slides anyway, right? )
wlannon(at)cablerocket.co Guest
Posted: Tue Sep 25, 2007 5:16 pm Post subject: Flap storage |
I too agree with Dennis regarding flap handle position. I see no advantage
in moving to the center after flap retraction.
The flap actuator does not contain nor does it require a ball lock system.
Above comments apply to the CJ6, other models may differ though I doubt it.
Walt
Bill Tally
Posted: Tue Sep 25, 2007 6:26 pm Post subject: Re: Flap storage |
Not to make a big deal of it, but I beg to differ with Walt on the ball lock issue. I have disassembled the flap actuator on my 52, and there is most assuredly a ball lock assembly in there. See also pages 36 and 37 (section 5.6) in Book 3 of the Yak 52 Aircraft Performance Data Specifications, etc. book.
crichka(at)hotmail.com Guest
Posted: Tue Sep 25, 2007 7:04 pm Post subject: Flap storage |
I agree with you, Just service my 52 flap actuator and It have 6 locking balls 5mm dia. and it is a locking unit
Chanock
Born to fly, Forced to work
[quote] Subject: Re: Flap storage
Date: Tue, 25 Sep 2007 19:26:20 -0700
To: yak-list(at)matronics.com
--> Yak-List message posted by: "Bill Tally" <wtally(at)scottsboro.org>
http://forums.matronics.com/viewtopic.php?p=136471#136471
Kick back and relax with hot games and cool activities at the Messenger Café. Play now!
Posted: Tue Sep 25, 2007 7:37 pm Post subject: Flap storage |
Then I humbly stand corrected. The CJ6 manual text and cut-away drawing with
parts list show no ball lock.
Walt
Michael Bolton
Posted: Wed Sep 26, 2007 5:27 am Post subject: Flap storage |
Glad to see that I am not alone in this Club
Michael
steve.fox(at)mac.com Guest
Posted: Wed Sep 26, 2007 5:49 am Post subject: Flap storage |
Bill Blackwell sells a gear knob in bright red that says GEAR on it. Fits both Yaks and CJs. It will not relieve you of your duty to stop, think and look, but it is one extra reminder.
Steve
On Sep 26, 2007, at 9:25 AM, Michael Bolton wrote:
[quote]--> Yak-List message posted by: "Michael Bolton" <mjbjhf(at)truvista.net (mjbjhf(at)truvista.net)>
Michael
Bill Tally
Posted: Wed Sep 26, 2007 5:56 am Post subject: Re: Flap storage |
Walt, a careful reading of your first post shows you were referring to CJ's. It appears that Yaks have the locks and and CJ's don't. So, you really don't need any correcting!
The discussion of ball locks brings up another topic: The presence of the ball locks in the Yak flaps has led many to question why the Russian flight manual forbids tail slides. If the flaps are in fact locked, what is the reason for that prohibition? Is it because of potential flap damage or for some other reason?
JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Wed Sep 26, 2007 6:22 am Post subject: Flap storage |
I agree with Walt, my CJ6 overhaul manual clearly shows the flap actuator
with no ball locks, page 26-1 chapter 26
I assume the CJ6 and the 52 have different actuators.
Joe
_________________ J.C. HOWSE |
JOE HOWSE
Posted: Wed Sep 26, 2007 6:48 am Post subject: flap storage |
Also the CJ6 has a bungee to retract the flap
Joe
rkent(at)wlacrussianeng.c Guest
Posted: Wed Sep 26, 2007 7:24 am Post subject: flap storage |
The CJ6 will have completely different actuators to the Yk-52. The Yk-52 has two flaps controlled by one actuator. The Yk-18T and the CJ6 have the one large ‘barn door’ flap across the wing centre section. The Yk-18T also has the bungees on the flap, I suspect, similar to the CJ6. The actuator for the Yk-52 flap is a double-ended actuator with the shaft protruding from both ends. The Yk-18T (not sure about the CJ6) has two small actuators for the one flap.
Rob Kent
Stores Manager
WLAC – Russian Engineering
www.wlacrussianeng.co.uk
Tel: +44 1628 829 165
Fax: +44 1628 825 975
Mob: +44 7866 438 293
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Joe Howse
Sent: 26 September 2007 15:46
Subject: flap storage
Joe
Posted: Wed Sep 26, 2007 8:00 am Post subject: flap storage |
Ahh So!!! Thanks Rob.
Seems the 52 flap actuator is a totally different animal. "two flaps controlled by one actuator".
I could not see a need for the ball lock in the CJ actuator (there is none) and assumed (bad idea but I am regularly guilty) this applied to other models.
So here we go again - I will suggest that other models with a single piece flap are the same as the CJ and will hazard a guess that the reason for the ball lock in the 52 is to prevent a split flap condition.
Walt
Bill Tally
Posted: Wed Sep 26, 2007 8:43 am Post subject: Re: Flap storage |
The way the Yak 52 flap system works, a split flap condition is impossible unless a component actually breaks (unlikely considering the strength of construction). Flaps on both sides are both connected to a common piston rod which has to be either in the up or down position. Ingenious and dirt simple.
Posted: Wed Sep 26, 2007 11:41 am Post subject: Flap storage |
Flat spin maybe.
Doc
