terrys(at)cisco.com Guest
Posted: Mon Sep 24, 2007 8:22 am Post subject: Monowheel speed kit |
I neglected to mention that when we closed off our gills we also opened
up the lower cowl exit area and baffled the area between the foot wells
to force air from the eye ball inlets down past the cylinders, then the
muffler, and finally out the bottom of the cowl. This dropped in-cowl
temps from 450 deg F to about 250 max and lowered oil temps in climb by
20 deg F.
Terry
josok-e(at)ukolo.fi Guest
Posted: Mon Sep 24, 2007 9:34 am Post subject: Monowheel speed kit |
Hi Terry,
[quote:ffc914ab8d="terrys at cisco.com"]
-----[/quote:ffc914ab8d]
Interesting,
How did you do that opening up, is it possible for you to attach a picture (or 2)
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Mon Sep 24, 2007 9:59 am Post subject: Monowheel speed kit |
Hi Jos,
I don't have any pictures, but I will try to describe the mod to you.
The top of the radiator duct is a sheet of aluminum (lets call it the
'separator') that splits the cowl into two areas, the lower area is for
the radiators, the top area contains everything else (engine, muffler,
etc.). The lower area has the big square inlet opening, the top area
has two eyeball inlets. In the stock condition, the lower aft exit is
used for both (ignoring the gills), strongly favoring the lower radiator
area, with just small openings in the sides for air to exit from the top
area.
Lying under the rear of the cowl, I used a 'nibbler' to remove
material from the rear of the 'separator', allowing more air from the
top area into the common exit. I probably removed about three inches
off the rear of the 'separator'. The intent was to provide an exit area
for the top portion of the cowl that was about 150% of the eyeball inlet
area.
I hope this helps,
Terry
jeff(at)rmmm.net Guest
Posted: Tue Sep 25, 2007 4:19 am Post subject: Monowheel speed kit |
| Quote: | Lying under the rear of the cowl, I used a 'nibbler' to remove
Hi Terry,
I am in the middle of fighting this same cooling issue but I have a
tri-gear. I'm sure I need more air coming out the bottom as so, but
help me understand what a nibbler is.
Jeff R.
A258 - N128LJ / Gold Rush 84 hours and climbing slowly.
[quote] Terry
topglock(at)cox.net Guest
Posted: Tue Sep 25, 2007 6:17 am Post subject: Monowheel speed kit |
Jeff,
A nibbler is a hand held tool, usually air powered, which contains a
small punch and anvil. When used, it "nibbles" away at the aluminum,
creating small crescent-shaped bits as it eats through the material.
It's used to cut out areas that would be difficult to get to with
shears, or other tools...
Jeff - Baby Blue
329 hrs
Hi Terry,
Jeff R.
> Terry
Posted: Tue Sep 25, 2007 8:17 am Post subject: Monowheel speed kit |
The nibbler is a small metal cutting tool available at Radio Shack, for
example (Google 'Radio Shack nibbler'). It is a convenient way to
remove small bits of metal from the cooling duct without removing it.
Terry
