UVTReith(at)aol.com Guest
Posted: Thu Sep 20, 2007 12:50 am Post subject: Dive to Vne |
Michael,
That's correct.
Herzliche Grüße aus Deutschland,
Bruno
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Thu Sep 20, 2007 6:46 am Post subject: Re: Dive to Vne |
I don't understand this one. How does the PFA know to what speed you did the test? If there's no enforcement mechanism, this is ludicrous. I cannot think of any gov't requirement here where we must certify the unprovable and the authorities are perfectly OK with that.
Fred F.
wdaniell(at)etb.net.co Guest
Posted: Thu Sep 20, 2007 8:04 am Post subject: Dive to Vne |
Ah thanks now I get it next question
It seems at first sight a sensible thing to do – rather than trying to do it in flight. I would be interested to know what everyone else thinks. Of course there is always the possibility that your pride and joy breaks. But probably better this than it breaks in the air…
Is there an instruction manual on how to go about it?
Can one simulate the dive to Vne? – I would assume not but perhaps some parts of it can be simulated in separate operations as it were??
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Michael Grass
Sent: Wednesday, September 19, 2007 23:06
Subject: Re: Dive to Vne
William,
If you do the math:
2 times 1350Kg = 2700 kg or around 5940pounds
This would be about the designed max +3.8 G as specified by Europa plus about a 15 % safety factor
Just guessing
Michael Grass
----- Original Message -----
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Sent: Wednesday, September 19, 2007 10:15 PM
Subject: RE: Europa-List: Dive to Vne
Forgive my ignorance but why 1350kg…?
Will
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTReith(at)aol.com (UVTReith(at)aol.com)
Sent: Wednesday, September 19, 2007 16:35
Here in Germany we do not do that Vne Dive Test, we are making the static wing load test with maximum 1.350 kg laod on each wing (upside down). On the tailwing we put 100 kg on one side and 150 kg on the other side and swap that then.
This is a requirement from the OUV (the German PFA).
Bruno
| Quote: | | http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.com |
9/18/2007 11:53
9/18/2007 11:53 | Quote: | | href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 0123456789 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 0 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 1 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 2 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 3
9/18/2007 11:53
9/18/2007 11:53
Posted: Thu Sep 20, 2007 10:01 am Post subject: Dive to Vne |
There is a significant risk of invisible damage imho so I would not want
to test to more than 3 G. Check for any permanent deflection unloaded
then retest and check again that deflections remain the same.
Graham
William Daniell wrote:
[quote] Ah thanks now I get it next question
Will
[mailto:owner-europa-list-server(at)matronics.com] *On Behalf Of *Michael Grass
*Sent:* Wednesday, September 19, 2007 23:06
*To:* europa-list(at)matronics.com
*Subject:* Re: Dive to Vne
William,
If you do the math:
Just guessing
Michael Grass
asarangan(at)YAHOO.COM Guest
Posted: Thu Sep 20, 2007 10:17 am Post subject: Dive to Vne |
Vne is not always an airframe limitation. Under FAR 23.33 (U.S. regs),
the propeller speed should remain within 110% of the max rpm at Vne. I
know that the Diamond Katana aircraft had such a Vne. It had nothing to
do with the airframe. Also, experimentals do not have to comply with
Part 23, and for that matter, I don't think there is any requirement to
even have a Vne.
Even in the case of airframe-limited Vne, it may not be a load factor
limit. The 3.8G someone else mentioned is for Va. Vne could be, for
example, the speed at which the windows blow out; or the antennas get
ripped out. It may have little to do with wing loading.
willie.harrison(at)tinyon Guest
Posted: Thu Sep 20, 2007 3:17 pm Post subject: Dive to Vne |
or flutter?
On 20 Sep 2007, at 19:16, Andrew Sarangan wrote:
<asarangan(at)yahoo.com>
nothing to
requirement to
even have a Vne.
craigb(at)onthenet.com.au Guest
Posted: Fri Sep 21, 2007 7:51 pm Post subject: Dive to Vne |
Just a thought, but if everyone is so concerned about VNE, Flutter etc
would it not be worth commisioning a computer modeling simulation for a few
thousand dollars, as was done with the lancair, and find all the sortcomings
in one go and be handed the solutions, if memory serves this type of
modeling
on the lancair took the theoretical max speed up to over 500kts, and the
solutions were as simple as a few extra layups of uni in the correct spots.
just a thought
I for one would pay for a share in such a study, if just to have the
knowledge i am safe at 150kts or 180kts or ..... etc
2:02 PM
josok-e(at)ukolo.fi Guest
Posted: Sat Sep 22, 2007 1:03 am Post subject: Dive to Vne |
Craigh,
It is a gross misunderstanding that anybody should be worried about flutter, VNE etc. The Europa is a wonderfull design, and is better tested then most kit planes. I thind we are under-appreciating the lot of work that Ivan and his friends have put in to it. After that, the type has tens of thousands of flying hours without any structural problem. Most of that worrying seems te be done by folks who are not flying their plane yet. Don't! Enjoy the build, and you will enjoy the result. Your sign-off makes me frown, you can fly today if you want, rent-a-plane or so. Don't hurry the build, it leads to frustration, and you will finish building before the plane is ready.
Computer modelling is fine, maybe there are areas where improvement is possible. But i doubt it will return anything usefull for the money.
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Sat Sep 22, 2007 5:23 am Post subject: Dive to Vne |
Thanks for the reply, as far as my post goes, I have no problems with flying
at VNE, When i did my licence it was mostly in a Piper Tomahawk, most tomies
are slow and predictable except for the stall, (I flew a few different ones)
but the main one had a different prop and would run through VNE in cruise
flight if you didnt watch it, which IMHO was a good thing as it meant you
had to slow down to VA if things got bumpy, so it taught you be concious of
your airspeed at all times, not just takeoff landing etc. My main reason
for suggesting the modeling was to maybe see if the VNE could be increased
at reduced MTOW. Sort of working backwards from the ultimate load of 8.55g
suggested by europa at the standard MTOW of 1300 or 1370 a reduction of
about
40 lbs would seem to suggest a new ultimate load of 9.0 g which is what is
required for a full aerobatic rating in australia of 6.0g (+50% safety
margin) which would intern mean an increase in VNE provided no flutter
issues
are a problem, which is where the computer modeling comes in. As far as the
signoff goes, dont get me wrong I am enjoying the build, seeing it grow, and
getting satisfaction from each bit i finish, but all my spare cash goes into
the plane so flying for the moment is not happening, thats why i wish it was
built, especially when we get a day thats almost calm with unlimited vis
and temps in the 20's it makes me want to be up there.
Richard_Pottorff(at)msn.c Guest
Posted: Sat Sep 22, 2007 5:26 am Post subject: Dive to VNE |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> There was a Wind Tunnel column in Kit Planes magazine a few months ago about Vne. The upshot was that you don't use indicated or calibrated airspeed to determine Vne. You use TAS. For those of you who have to dive to Vne, if you do your calculations ahead of time, and start high enough, you could actually reach Vne well before you exceed the structural cruising speed.
Vne is concerned with the actual speed of the air molecules hitting the control surfaces, not the number of air molecules that hit the airplane per second.
Hope this helps.
Posted: Sat Sep 22, 2007 4:33 pm Post subject: Dive to VNE |
Not exactly Richard,
The main issue is mass times velocity squared, so it's both speed and
number of molecules
Viscocity comes into it too becaues flutter is a resonance issue.
Graham
Richard Pottorff wrote:
per second.
Posted: Mon Sep 24, 2007 8:05 am Post subject: Dive to Vne |
Will
