Ailerons 101
Goto page Previous  1, 2
jindoguy(at)gmail.com
PostPosted: Sun Sep 23, 2007 9:21 am    Post subject: Ailerons 101 Reply with quote
Mike, Why not just use the MkIII system. Weights and measures won't do you much good except to ball park what you need. The MkIII fittings and the bar may not be the most elegant, but it is adaptable to all different weights of ailerons.
Rick
On 9/23/07, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
Jack,
I'll concede the root cause of aileron flutter. But, I would like to try again. Does anyone have a photo of a balanced aireron, and possibly some weights and dimensions. This improvement seems to be worthwhile, but for those of us wanting to balance our aileron, could a couple of you craftman show us your stuff? Ailerons, that is.  I'm certain this would be greatly appreciated by more than just me.
    Mike in SW Utah
> John, & Kolbers
The root cause of aileron flutter is the lack of wing stiffness. Due to the
fact that the wing can and does flex during flight in response to passing
through unstable air and or roll control movement, it causes the wing to
twist chord wise with the most of the movement taking place at the
unsupported outer wing tip. By doing so this tries to whip the aileron up
and down. The balancing of the aileron puts a mass ahead of the hinge equal
to aileron mass behind the hinge line and so the aileron will bounce up and
down but will not twist about the hinge due to wing twisting.
If you would like to read more about this, Google - 'NACA "aileron flutter"'
Jack B. Hart FF004
Winchester, IN
More photos; more messages; more whatever – Get MORE with Windows Live™ Hotmail®. NOW with 5GB storage. Get more!
= the many List utilities such as the Subscriptions page,
ronics.com/Navigator?Kolb-List" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">
http://forums.matronics.com
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
PostPosted: Sun Sep 23, 2007 9:45 am    Post subject: Ailerons 101 Reply with quote
Rick,
I'd be happy to use the MkIII system, especially since I have a MkIII. But, in my MkIII builder's book (Mar '98 edition), it makes NO mention of aileron balancing, and practically nothing of even the ailerons.
Although I'm quite certain I could come up with something,.
I would still appreciate a photo or two, and if there is a reference to aileron balancing in a later edition, or even better in an XTRA manual, I would greatly appreciate it if someone could scan and send this updated information.
Mike Welch
Date: Sun, 23 Sep 2007 12:21:20 -0500
Subject: Re: Ailerons 101
Rick
On 9/23/07, Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Jack,
Mike in SW Utah
John, & Kolbers
Jack B. Hart FF004
Winchester, IN
Rick Girard
"Ya'll drop on in"
when you live at the airport.
Capture your memories in an online journal!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
biglar
PostPosted: Sun Sep 23, 2007 11:05 am    Post subject: Ailerons 101 Reply with quote
Mike, mine's from about the same era, and if the components didn't come
with your kit, I know they're available from Kolb. There's a "T" that
rivets into the outboard end of the leading edge of the aileron, and a
solid steel rod that slides into that and bolts into place. The only
picture I can find of it is with the wings folded ready to load in the
trailer. It shows the "T" fittings, but the balance weight rods are
removed and a steel bar is replacing them to help hold the wings solidly
while in the trailer. Lar.
Mike Welch wrote:
Rick,
Mike Welch
 Filesize:  73.57 KB
 Viewed:  139 Time(s)
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
PostPosted: Sun Sep 23, 2007 6:11 pm    Post subject: Ailerons 101 Reply with quote
Mike, Sorry about that, I lost track of the type Kolb we were talking about
Page 2 of 2
