MJKTuck(at)cs.com Guest
Posted: Mon Sep 17, 2007 5:42 pm Post subject: Dive to Vne |
Hi Guys,
The 'Dive to Vne' as part of the UK annual inspection was mentioned again.
In my mind Vne is a maximum design speed for the aircraft, first
calculated and then demonstrated by the manufacturer (probably with some
margin) as part of the 'proof of design' test program. It is a test that
takes the airframe close to the outer edge of the envelope and I don't
think one to be undertaken lightly particularly by your average private
pilot.
The test has two possible outcomes and to me a positive result is not
worth the risk of the alternative.
Is there anyway the PFA can persuade the CAA to rethink the need for
this test as part of an annual check - or at least set some standards as
to who can perform the test, no passengers, entry and exit altitudes,
wearing of helmet/parachute in case the test proves negative, etc.
Maybe a requirement to dive to 90% of Vne would be a satisfactory
compromise?
Martin Tuck
N152MT
Wichita, Kansas
ami(at)mcfadyean.freeserv Guest
Posted: Tue Sep 18, 2007 12:20 am Post subject: Dive to Vne |
Martin,
I agree. And it's the reason I don't want to upgrade to 1370lbs, because the
Vne test only has to be then done at 150kts. Although my particular aircraft
was Permit-limited to 155kts when first built and therefore originally
tested at that speed.
Duncan McF
carl(at)flyers.freeserve. Guest
Posted: Tue Sep 18, 2007 1:34 am Post subject: Dive to Vne |
I suspect that those in the know would say that VNE+ dives are nothing to be
worried about. After all the aircraft is supposed to be stressed to about
+5g.
I think that a parachute would be a sensible precaution though I dont know
how easy it would be to wear one (possibly with the cushions removed).
Personally I have always had a "professional" pilot accompany me when I did
the annual flight test. I suspect it is the way the VNE dive is performed
that is crucial.
There were several instances of the wings becoming dislodged during the
testing of the original Europa and no doubt due to the experience of the
test pilots, no one got hurt.
Perhaps someone could look into the possibility of mounting a ballistic
recovery system in the passenger seat (for the duration of the flight test).
If someone was able to design a universal fit for kitplanes I suspect there
would be a good demand for them - subject to cost of course.
Carl Pattinson
G-LABS
willie.harrison(at)tinyon Guest
Posted: Tue Sep 18, 2007 2:37 am Post subject: Dive to Vne |
It's presumably not vne itself which creates the main stress, but the
combination of g pulled by the pilot (can be airspeed-dependent if
the pilot is not super careful) and g generated by rough air (always
dependent on airspeed). Can't help wondering what g loadings the
crash aircraft experienced that day. Has anyone got any info on the
rumour about the GPS having been interrogated during the investigation?
I share the doubts expressed about the real value of repeating the
vne test every year. My own Permit expires every January which means
that I am typically looking for a calm day in the middle of Winter
(note for US cousins - Winter in the UK usually means crappy weather,
low cloud, etc) with the usual anxiety about the expiry deadline
looming. Maybe some folk are tempted to do the test in rougher
weather than they should. Maybe some are also tempted to do the test
from a lower cloudbase than they should, leaving less height to
recover and therefore the need to pull more g...? It makes you wonder.
Willie Harrison
G-BZNY
On 18 Sep 2007, at 10:33, Carl Pattinson wrote:
<carl(at)flyers.freeserve.co.uk>
nothing to be worried about. After all the aircraft is supposed to
be stressed to about +5g.
dont know how easy it would be to wear one (possibly with the
cushions removed). Personally I have always had a "professional"
pilot accompany me when I did the annual flight test. I suspect it
is the way the VNE dive is performed that is crucial.
the testing of the original Europa and no doubt due to the
experience of the test pilots, no one got hurt.
ballistic recovery system in the passenger seat (for the duration
of the flight test). If someone was able to design a universal fit
for kitplanes I suspect there would be a good demand for them -
Carl Pattinson
G-LABS
rampil
Posted: Tue Sep 18, 2007 7:11 am Post subject: Re: Dive to Vne |
Vne is actually 90% of the true max rated speed Vdive.
Pete Clarke actually tested Vd as required. It is simply a
convention that us unwashed masses do not cross the 90% Vd line
Too many flight instructors and pilot texts over simplify the
structural issues
If your plane is built to spec, there should be no issue in flying at
Vne in calm air. Why the PFA wants you to do this annually escapes
me, but it is safe.
Posted: Tue Sep 18, 2007 11:40 am Post subject: Dive to Vne |
<<Why the PFA wants you to do this annually escapes
To check that it is safe!
DuncanMcf
karelvranken(at)hotmail.c Guest
Posted: Tue Sep 18, 2007 1:04 pm Post subject: Dive to Vne |
William and all,
Vne has not directly a relation with pulling g's. You never make high speed
in rough air. To catch up speed you have to dive. This doesn't mean
vertical. You do it smoothly while observing your RPM and intake manifold
pressure. Don't overboost your engine. The Europa is as fast as you want
since the big problem was solved with the tie bar. The big problem was the
displacement of the lift point forwards with higher speeds and caused the
wings to tend forwards and bend the spars. When I purchased the Europa in
1999 the tie bar was standard and I was happy with this solution. During the
test period a friend of mine was filming my passages over the airfield of
Sedan in France. In one of the low passes I observed an IAS of 180 knots
without any difference of those below Vne. My conclusion is: don't be afraid
of Vne, accept it.
Best regards,
Karel Vranken
Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Wed Sep 19, 2007 7:53 am Post subject: Dive to Vne |
"<<Why the PFA wants you to do this annually escapes me, >>
To check that it is safe! DuncanMcf "
Duncan, I admire their interest, but it DOES incur two thoughts:
[1] If they are interested, whu don't THEY do it? I would be prepared to
accept an apology if it splats all over Cheshire, and
[2] What is the result of discovering it isn't safe? Back to the drawing
board?
Wouldn't that reduce medical practice to striking the temple with bigger
hammers to establish good bone structure?
Cheers, Ferg
wdaniell(at)etb.net.co Guest
Posted: Wed Sep 19, 2007 8:24 am Post subject: Dive to Vne |
2 was going to be my question...
High and with a parachute I think... or is there some other way of testing
this like the static testing on someone's website (can't remember where)
with the bags of cement on the upturned wings.
Will
Posted: Wed Sep 19, 2007 9:01 am Post subject: Dive to Vne |
"Tut Tut" Ferg .....now that really is "agricultural" thinking!
I will say however there are some damn fine engineers who commenced
their active life on farms getting the rudiments of engineering
experience prior to graduating to more sophisticated engineering later
like planting seeds, they need a good foundation!
BTW.....
It is necessary to be at MTOW on take off for these tests and they do
advise to pull out gently and be sure to not exceed the Vne and not to
overspeed the engine ...oh! and to remember to try small manoeuvres
whilst doing it and report any shortcomings !!!!!!
Bob H
Do not archive.....
Robt.C.Harrison
kheindl(at)msn.com Guest
Posted: Wed Sep 19, 2007 9:36 am Post subject: Dive to Vne |
And what about the maximum +- g. How come the PFA don't need to have that
tested ? Shouldn't we pull maximum g at VNE and at MTOW, and if nothing has
fallen off, then you are good for another year.
Karl
Reply-To: europa-list(at)matronics.com
Subject: RE: Dive to Vne
Date: Wed, 19 Sep 2007 18:01:17 +0100
BTW.....
Bob H
Do not archive.....
Robt.C.Harrison
Mark Burton
Posted: Wed Sep 19, 2007 10:14 am Post subject: Re: Dive to Vne |
What is bizarre about the PFA's vne dive requirement is that if the small print on the the permit renewal form is true, the permit renewal will fail to be accepted if you admit to either exceeding vne or failing to reach vne. Not a lot of margin for error there. I think that says something about the PFA's confidence in our piloting skills and the accuracy of our speedos.
I wonder how many Europa operators know what the position error of their ASI is at 150+ knots?
Which begs the question, why isn't vne specified as a RAS rather than an IAS because the IAS could be way out due to instrument and position errors? I think this question may have been asked before, sorry for the repeat.
Mark
josok-e(at)ukolo.fi Guest
Posted: Wed Sep 19, 2007 10:39 am Post subject: Dive to Vne |
There are at least 3 types of limits.
Calculated limits, Prooven limits and PFA limits.
The calculated limits, which include prooven and tested safety margins, lead to testing, and if nothing breaks, flutters or otherwise falls apart, we have prooven limits. Then the PFA comes along and add their own safety factor on the calculated and prooven limits. I have not been able to find any justification for that PFA safety factor, other then the general fit-all: Amateur builders make mistakes. How on earth the PFA can stick a number to these mistakes i do not understand.
All in all: Diving to PFA-Vne should be absolutely safe, it's some 20 knots slower then the calculated an prooven Vne. The Pfa knows it's safe, because they did the bad builder calculation!
Is the same bad-builder safety margin enforced on glasairs and vans and the like? Are they to do that Vne dive, while their Vne is probably for real?
Jos Okhuijsen
Visit - www.EuropaOwners.org
rampil
Posted: Wed Sep 19, 2007 12:15 pm Post subject: Re: Dive to Vne |
I like Ferg's analogy to destructive skull testing!
Despite being an engineer in former life, I still don't get it.
Do we require testing of homebuilt sailboats to hull speed
annually? How many green pilots will die from misadventure near
Vd relative to the number weak wings destructively detected?
(I know I have a thick skull, bring a bigger hammer Ferg)
Posted: Wed Sep 19, 2007 12:38 pm Post subject: Dive to Vne |
Would that there was some way to filter this thread so that wives and
significant others and those faint of heart would not have access to
it...(sigh!)
Fred
believed to be clean.
UVTReith(at)aol.com Guest
Posted: Wed Sep 19, 2007 1:36 pm Post subject: Dive to Vne |
Here in Germany we do not do that Vne Dive Test, we are making the static wing load test with maximum 1.350 kg laod on each wing (upside down). On the tailwing we put 100 kg on one side and 150 kg on the other side and swap that then.
This is a requirement from the OUV (the German PFA).
Bruno
tony.bale(at)virgin.net Guest
Posted: Wed Sep 19, 2007 1:43 pm Post subject: Dive to Vne |
All the correspondence on "dive to vne" has been quite interesting. But
having done the last two annual flight tests on our XS mono including the
vne test, the term dive suggests (to me anyway) everything firewalled and
point the nose at terra firma.
In reality it is nothing like that, I accept most - including our aircraft,
have over reading ASI's (can't remember what the flight test results were)
but with 5400 rpm and probably 25"/26" map the actual nose down attitude is
not very steep at all. It goes without saying this is commenced at high
level on a smooth day, acceleration is strictly limited, the controls are
only moved very smoothly and only to restriced amounts (never need much
deflection anyway !). As an indicator of the scale of the test, our
straight and level speed at full throttle and 5400 rpm is the thick end of
150 knots. (and I bet the turbo boys can see mid to high 150's if they try).
As a point of comparison, with Airmaster cruise setting, and 25" map,
straight and level at circa 2000 ft we indicate 128 Kts +/- (just below the
yellow). Having flown in formation with an Arrow and RV9, our ASI's at this
cruise all read within one or two knots of each other.
My two penny worth anyway.
ATB
Tony.
Original Message:
Date: Wed, 19 Sep 2007 13:15:11 -0700
Subject: Re: Dive to Vne
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=135336#135336
mail2web.com – Enhanced email for the mobile individual based on Microsoft®
Exchange - http://link.mail2web.com/Personal/EnhancedEmail
Posted: Wed Sep 19, 2007 6:17 pm Post subject: Dive to Vne |
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of UVTReith(at)aol.com
Sent: Wednesday, September 19, 2007 16:35
Bruno
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
9/18/2007 11:53
9/18/2007 11:53
Forgive my ignorance but why 1350kg…?
Will
Bruno
9/18/2007 11:53
9/18/2007 11:53
M.Grass(at)comcast.net Guest
Posted: Wed Sep 19, 2007 8:08 pm Post subject: Dive to Vne |
William,
If you do the math:
2 times 1350Kg = 2700 kg or around 5940pounds
This would be about the designed max +3.8 G as specified by Europa plus about a 15 % safety factor
Just guessing
Michael Grass
