goodings(at)yorku.ca Guest
Posted: Fri Sep 14, 2007 6:08 am Post subject: RotaxEngines-List Digest: 912ULS @ XCOM760 Problem |
Tommy: I'm not familiar with the XCOM760. Can you operate it as a
handheld transceiver? You have used a separate battery. It does sound
like the rf noise generated by the engine is picked up by the radio
antenna, from the tests you have done. But, can you remove the XCOM
entirely from the aircraft, run it with a rubber ducky antenna and its own
battery and move it around various distances from the aircraft. This
would, of course, need someone else with a set of headphones plugged into
the XCOM to listen. At least it might tell you whether the noise is
getting in through the aircraft ground side, or strictly as radiation
through the air.
John Goodings, C-FGPJ, CH601HD with R912S and ICOM-A22, Toronto/Ottawa;
and yes, we've had troubles with noise pick-up by the ICOM radio from our
Becker transponder!
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Fri Sep 14, 2007 5:44 pm Post subject: Re: RotaxEngines-List Digest: 912ULS @ XCOM760 Problem |
Hi John,
The XCOM is like the MicroAir, but has VOX intercom. I am still working on this, but I think I'm getting close to making the radio usable. I will post my results.
Thanks for writing.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
