kahamer(at)bigpond.net.au Guest
Posted: Thu Sep 06, 2007 7:49 pm Post subject: Heated pitot retrofit |
| Quote: | | Hi all,Wonder who difficult it would be to fit a heated pito tube once the skins are on the wing (RV7),but wings not fitted to the fuselage as yet.Anyone done this before? RegardsKarl Ahamer7A near Sydney/Australia |
6/09/2007 3:18 PM
6/09/2007 3:18 PM
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Fri Sep 07, 2007 5:37 pm Post subject: Heated pitot retrofit |
In a message dated 9/6/2007 10:50:52 PM Central Daylight Time, kahamer(at)bigpond.net.au writes:
| Quote: | | Anyone done this before? |
I recently installed a Gretz tube in the outboard (aileron bellcrank) cover. I duplicated the cover in .040 2024 and made a doubler a bit larger than the base of the tube with an extension on it on which I mounted the circuit board. Makes for easy connection & inspection. You will have to take care when attaching tiedowns, but I believe the benefits outweigh this. I also discussed this with Warren Gretz and he saw no downside. Photo available if interested...
From The PossumWorks in TN
Mark Phillips
http://websites.expercraft.com/n51pw/
See what's new at AOL.com and Make AOL Your Homepage.
_________________ From The PossumWorks... |
Posted: Sat Sep 08, 2007 4:09 pm Post subject: Heated pitot retrofit |
Hi Mark,thanks for reply.Great idea!
Karl
marty_away(at)hotmail.com Guest
Posted: Sun Sep 09, 2007 7:52 am Post subject: Heated pitot retrofit |
Karl,
Just done it also..... put my Gretz tube in the bay next to the wing
access panel (wingtip side)
- Thoughts to consider..... figure how you will countersink the skin
before doing any riveting. I didn't and a fellow builder recommended I
build a countersunk backplate. By using a countersunk screw I was able to
pull the skin into a somewhat countersunk area.... but it isn't pretty.
- Riveting.... you'll need to poprivet the support brackets....
- The smart chip (circuit board) Seemed to challenging to install the
platenuts on the rib, so I built a raised platform to mount the chip right
on the access panel but ensured the back of the circuit panel didn't touch
the aluminum access plate.
- Connecting the pitot line. Have to move the installed (aluminum) line to
the new position. Bought a 1/4 by 1/4 copper pipe connector in the Home
Depot aviation isle. Haven't bent the copper tube on the Gretz unit yet,
but feel it's necessary to avoid a right angle in the pitot static line.
On the road, so I don't have pictures..... Hope this helps....
Marty
RV-7 (N622HR)
Fitting systems in the fuselog...
| Quote: | From: "Karl Ahamer" <kahamer(at)bigpond.net.au>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Heated pitot retrofit
Date: Fri, 7 Sep 2007 13:48:07 +1000
Hi all,
Karl Ahamer
6/09/2007 3:18 PM
6/09/2007 3:18 PM
Kick back and relax with hot games and cool activities at the Messenger
Café. http://www.cafemessenger.com?ocid=TXT_TAGHM_SeptHMtagline1
Posted: Tue Sep 11, 2007 1:45 am Post subject: Heated pitot retrofit |
Thanks Marty,
I'm still tossing up which way to go.
Karl
dhall(at)donka.net Guest
Posted: Thu Sep 13, 2007 7:27 pm Post subject: Heated pitot retrofit |
I installed my Gretz during wing construction, but I think it would be
simple enough to install it after the fact. The skin dimpling could be done
with a pop-rivet dimple set.
Here's one pic of my gretz install to help you out. There are other pics
also. Fellow builder, Mike Stewart, advised me to use some rubber fuel
line, courtesy of autozone, to connect the gretz copper line to the aluminum
pitot run. Using this flexible line makes it easy to connect everything
without having open access.
http://donka.net/gallery/view_photo.php?set_albumName=rv7leftwing&id=DSC0549
Good luck.
Don Hall
N517DG (registered)
rv7 fuselage
http://rv7.donka.net
Posted: Thu Sep 13, 2007 7:53 pm Post subject: Heated pitot retrofit |
Correction, not fuel, but vaccuum tubing...
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Fri Sep 14, 2007 4:05 am Post subject: Heated pitot retrofit |
Dimpling after an assembly is built is easy and you don't have to compromise on the quality of the dimple by using screws or pop rivet dimple sets etc. If you have the means to drill holes through a bucking bar, you can fit regular dimple dies to a spare rivet set and bucking bar by drilling holes into them and then use the dimple dies with your rivet gun. Fitted with a male dimple die, you can use the female receptacle fitted to many C frame dimplers. It is sized to fit a standard rivet gun. Or you can buy the special tools needed at ATS which are essentially as I just outlined.
http://tinyurl.com/yvvr5v
Rick Galati RV-6A "Darla!"
RV-8 FWF
