sarg314(at)comcast.net Guest
Posted: Fri Aug 31, 2007 4:48 pm Post subject: spade lug failure. |
I have been wiring my plane using some high quality (well, at least
they're expensive - $0.65 each) T&B insulated fast-on type connectors
and an Ideal crimping tool (not expensive as crimpers go - about $50).
A couple days ago I found a #22 ground wire that simply didn't conduct.
I removed it from the plane and sliced away insulation near each end to
expose the wire just before the connectors and determined which one
wasn't conducting. It looked fine. The wires were just visible
sticking out of the spade lug end and I could touch them directly with
my continuity tester, but they weren't connected to the rest of the wire.
Using a dremel tool, I removed the plastic covering and part of the
crimp. A little bit of the insulation extended into the part of the
barrel that crimps the copper wire. Apparently what happened was that
the act of crimping it cut thru the wire, but NOT thru the insulation.
The connector was held on by the insulation. That tefzel is pretty tough
stuff.
I made a new wire and got things working, but I have to wonder if more
of my wires aren't in the same or nearly the same condition. Am I doing
something wrong here or was this probably just a 1 in a 1000 fluke? Do
I need to check the connections that seem to be working? If so, how?
Tom Sargent, RV-6A
Electrical system
Posted: Sun Sep 09, 2007 2:09 pm Post subject: spade lug failure. |
I didn't get any responses to this, but I found an explanation for it
that I thought I should post. After carefully examining the bad female
lug, I noticed that it was of a different design than all the others.
It had had the same plastic insulating shrowd on it, but the metal
connector itself was different. I could not find one like it in all my
parts bins. I was also unable to duplicate the problem by crimping a
dozen test connectors trying to make every mistake I could think of.
So, I'm concluding that it was one of a different design that the
manufacturer or seller (Allied Electronics) got into the wrong parts bag
by mistake. It is probably designed for a different crimping tool and
the one I have crimped it differently and caused bad results. I have
yet to check all the connectors in the plane to verify that there were
no others like it that got installed. But I think my crimper is OK and
my connectors are OK too. Testing of the electrical system is going well.
sarg314 wrote:
insulation. The connector was held on by the insulation. That tefzel
is pretty tough stuff.
Tom Sargent, RV-6A
Tom Sargent, RV-6A, electrical system
nuckolls.bob(at)cox.net Guest
Posted: Mon Sep 10, 2007 6:44 am Post subject: spade lug failure. |
At 05:44 PM 8/31/2007 -0700, you wrote:
they're expensive - $0.65 each) T&B insulated fast-on type connectors and
wasn't conducting. It looked fine. The wires were just visible sticking
out of the spade lug end and I could touch them directly with my
barrel that crimps the copper wire. Apparently what happened was that the
stuff.
I made a new wire and got things working, but I have to wonder if more of
something wrong here or was this probably just a 1 in a 1000 fluke? Do I
Good question. What you're experiencing is a demonstration
of the fact that there is a menage a trois to be
crafted between wires, terminals and tools that apply them.
Some time ago I crafted some articles on terminal and tool
performance. I'll suggest you review:
http://www.aeroelectric.com/articles/terminal.pdf
http://www.aeroelectric.com/articles/CrimpTools/crimptools.html
http://www.aeroelectric.com/articles/rules/review.html
Your reported experience does raise some questions. I'd
do a pull-test on a terminal crimped to a wire. When
it fails, there should be a clean break between the loose
strands and where the closed barrel turns them into
a solid mass. You should not pull any strands out of
the crimp.
I did some tests on AMP tools putting AMP terminals
on 22AWG Tefzel a few years ago and found that you could
put a terminal on an UNSTRIPPED wire. When you think
about the pressure (tens of thousands of PSI) it takes
to bring the copper barrel into intimate contact with
the copper strands, there's no way some layer of plastic
is going to figure in a discontinuity. The plastic
extrudes out of the joint like toothpaste.
Having offered all this, I'll have to confess that
what you've stated does give rise to some concerns.
If one terminal was found to be insufficiently installed
by ACCIDENT, what might you find if other terminals
were investigated deliberately. I wish I could give
you some warm fuzzies about this . . .
