sarg314(at)comcast.net Guest
Posted: Sun Sep 09, 2007 6:00 pm Post subject: VM1000 manifold pressure and CHT sensors - a formula |
I found an absolute air pressure calculator at the link below.
http://www.csgnetwork.com/barcorrectthcalc.html
When I fill in the numbers it gives me a 2.02 in. hg correction, so I
have a 0.7 in. error, not a 2.7 in error.
Tom S.
khorton01(at)rogers.com Guest
Posted: Mon Sep 10, 2007 2:05 am Post subject: VM1000 manifold pressure and CHT sensors - a formula |
On 9 Sep 2007, at 22:00, sarg314 wrote:
I'm not sure this calculator does what you think it does. It seems
to calculate the sea level referenced barometric pressure, which is a
number that the meteorologists like, as it removes the effect of
elevation on the pressures they are analysing.
Look at the standard atmosphere calculator at:
http://www.digitaldutch.com/atmoscalc/
It will show you the pressure that would be present at 2200 ft
elevation, assuming you had a standard atmosphere.
If you want to correct for non-standard pressures, and you have
access to an altimeter setting from a local airport, look at:
http://wahiduddin.net/calc/calc_da.htm
It is really designed to calculate density altitude, so it won't run
unless you also input temperature and dew point. But, it also
displays absolute pressure, which is what your MP gauge is
reporting. The absolute pressure calculation is not affected by
temperature or dew point, so you can input any values for those
parametres.
Kevin
Posted: Mon Sep 10, 2007 6:31 pm Post subject: VM1000 manifold pressure and CHT sensors - a formula |
Kevin:
The DigitalDutch link seems to give results for a standard
atmosphere though - it takes no baro input. It's computing for 29.92
inches Hg. The second link (wahiduddin, where'd they get THAT name?) is
just what I need. Thanks very much.
Kevin Horton wrote:
