Craymondw(at)aol.com Guest
Posted: Thu Sep 06, 2007 11:50 am Post subject: Starter batteries |
When I happened to notice the cowling off a RV7 I spotted a small fire wall mounted battery. I told the builder I found it hard to believe it started his IO 360 engine. He said it easily did. The battery couldn't have been no longer than six inches wide and seven inches high and three inches deep. What interested me the most is that it not only cost half of a Concord battery, it weighed less than half. Has anyone had any experience with this type of battery and will it start an IO 360 200hp? The battery looked like something you would see in a jet ski.
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Bruce(at)glasair.org Guest
robin02(at)mindspring.com Guest
Posted: Thu Sep 06, 2007 12:28 pm Post subject: Starter batteries |
The weight reduction seems worth a look. It should be noted though that the operating environment exceeds the 175 degree limitation for most plastic batteries. With the size though, a vented box is sure possible.
Another good source for batteries is Band C Specialties. I just change one after seven years that was still going strong. RObin
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Thursday, September 06, 2007 4:12 PM
To: glasair-list(at)matronics.com
Subject: RE: Starter batteries
You must mean the Odyssey PC-680 battery. They are used quite often with good results.
http://www.odysseybatteries.com/battery/pc680.htm
Bruce
www.Glasair.org
-----Original Message-----
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com
Sent: Thursday, September 06, 2007 3:50 PM
Subject: Starter batteries
[quote] [b]
