gfmjr_20(at)hotmail.com Guest
Posted: Sat Feb 18, 2006 3:43 pm Post subject: Voltage from fuel sender |
List--
I'm trying to set up the Dynon EMS fuel level senders in parallel with my
regular analog gauges. To do this I need to know the voltage that the
level senders "output". It should be somewhere around 0-5 volts but I'm
not sure and my wings are stored where I can't easily access them.
If anyone knows this info I'd much appreciate it
George May
601XL 912s
Posted: Sat Feb 18, 2006 3:58 pm Post subject: Voltage from fuel sender |
I may be wrong here but I'll give it a try. If you have capacitive senders
then the voltage should range between 0 and the supply voltage to the sender
(12v?).
If you have a conventional resistive "float" sender then it does not produce
a voltage. It is just a variable resistor. The input you connect it to will
supply the current and measure the flow (in thousandths of an amp) to
measure the level.
-- Craig
Posted: Sat Feb 18, 2006 6:42 pm Post subject: Voltage from fuel sender |
Craig--
Sorry I wsn't quite clear. I have resistive senders in the tanks. In
order to parallel
the existing senders with the Dynon inputs, I'll need to define the dynon
inputs
as capacitive in their setup menu(otherwise I'd have resistors in parallel
giving miss info).
My understanding is that these Dynon inputs function from 0-5 volts. I want
to insure
I do not overdrive these inputs, thus the question.
George
[quote]From: "Craig Payne" <craig(at)craigandjean.com>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: RE: Re: Voltage from fuel sender
Date: Sat, 18 Feb 2006 16:54:01 -0700
sender
(12v?).
produce
measure the level.
-- Craig
btucke73(at)yahoo.com Guest
Posted: Sat Feb 18, 2006 7:49 pm Post subject: Voltage from fuel sender |
George,
Look here:
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=115+400267+301970&autoview=sku
If you have the sender recommended by Zenith, it
is 10 - 180 ohms, but there are others as well. You
have to know which you installed.
R/
Brandon
