Posted: Sun Sep 02, 2007 12:38 pm Post subject: Was RE: FW: FS 02 Now fuel float balls ! |
Hi! Duncan
Not a clue! I just bought it from Vance.
But I do have one if you should want to analyse it and make me a
replacement!
Bob H
ami(at)mcfadyean.freeserv Guest
Posted: Sun Sep 02, 2007 1:04 pm Post subject: Was RE: FW: FS 02 Now fuel float balls ! |
I'll make you a replacement from cork, probably the most reliable of
materials! I suppose a cut-up carb float would do it too.
The difficulty is colouring it, and it staying that colour in Mogas.
Rgds.,
Duncan
do not archive.
Posted: Sun Sep 02, 2007 1:36 pm Post subject: Was RE: FW: FS 02 Now fuel float balls ! |
I'd buy one from Vance, he's been doing it for 15 years or more and
there's no substitute for experience!
plus he's a good bloke!
Graham
Duncan & Ami McFadyean wrote:
| Quote: | Bob,
Rgds.,
Duncan
Posted: Sun Sep 02, 2007 11:59 pm Post subject: Was RE: FW: FS 02 Now fuel float balls ! |
Hi! Duncan/Fred
I think I recall that Vance makes 5mm dia. And 3mm dia. Balls Also that
he sent me three of the small ones (one for good measure ...pardon the
pun!) for about USD $ 10 plus postage. Not a really big outlay ! but
about 10 years ago.
Seems to be a bit of debate about his latest e-mail address though.
Graham Singleton is advising his new address is :- nostromo56(at)tx.rr.com
I've just Googled "Vance Atkinson Fuel Sight Gauges" and there is a host
of pages recommending his gauges.
However Initially I Googled "Fuel Floating Ball Level Gauges" or
thereabouts and came up with an AAIU Formal Accident Report (Not Vances
Gauge) about such a float ball gauge where the ball had stuck and given
a false reading but probably due to aging of the tubes discolouring the
real meniscus level of the fuel couldn't be seen either! So my points
about stainless wire wool or some such facility to stop the ball
becoming stuck at the top is quite relevant.
Of course it's not possible to weight the damn thing otherwise it will
sink.
I used the 3mm diameter one in the standard Europa plastic fuel tube.
Bob H
