Carl
Posted: Tue Aug 28, 2007 6:04 am Post subject: Wing wiring conduit |
Has anyone used any sort of wing wiring duct for the menagerie of wires coming from the wing tip lights, antenna, auto pilot, etc. If so could you tell me what and where to find it? Thx CJ
_________________ Carl Bell
Building N947CB
RV 7A |
Bruce(at)glasair.org Guest
Posted: Tue Aug 28, 2007 6:28 am Post subject: Wing wiring conduit |
Local hardware store, flexible PVC tubing.
Bruce
www.Glasair.org
sbuc(at)hiwaay.net Guest
Posted: Tue Aug 28, 2007 6:36 am Post subject: Wing wiring conduit |
Carl Bell wrote:
| Quote: | Has anyone used any sort of wing wiring duct for the menagerie of wires
Lightweight PVC pipe from your local building supply store.
Sam Buchanan
marty_away(at)hotmail.com Guest
Posted: Tue Aug 28, 2007 6:47 am Post subject: Wing wiring conduit |
1" pvc pipe....available in 10' lenghts at the Lowe or Home Depot aviation
isle
| Quote: | From: "Carl Bell" <carlbell(at)gforcecable.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Wing wiring conduit
Date: Tue, 28 Aug 2007 10:03:15 -0400
More photos, more messages, more storage—get 2GB with Windows Live Hotmail.
lifeofreiley2003(at)yahoo Guest
Posted: Tue Aug 28, 2007 7:06 am Post subject: Wing wiring conduit |
Carl,
I like the light weight stuff Van's sells.
Darrell
Posted: Tue Aug 28, 2007 7:47 am Post subject: Wing wiring conduit |
Darrell Reiley wrote:
| Quote: | Carl,
An advantage of the PVC pipe, besides being inexpensive, light, and
readily available, is the smooth interior which makes it *much* easier
to push wire through the conduit. I glued a coupling to each end of the
pipe outboard of the root and tip ribs to hold the pipe in place.
Sam Buchanan
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Aug 28, 2007 8:52 am Post subject: Wing wiring conduit |
I think both ideas are great. The split in the product Van's sell helps with wire drop outs for autopilots, landing lights etc... I just used a vacuum cleaner, taped a ball of cotton to the wires and sucked them through the conduit. A small dab of anti-corrosive silicone holds everything nice and tight.
Darrell
Posted: Tue Aug 28, 2007 12:40 pm Post subject: Wing wiring conduit |
Most of the time wire doesn't like to be pushed. If you have room at
one end, use your shop vac to suck a pulling string through the
conduit. A small piece of foam or even a piece of paper towel tied on
the end of the string is all you need.
Linn
Sam Buchanan wrote:
> Carl,
the pipe outboard of the root and tip ribs to hold the pipe in place.
Sam Buchanan
matronics(at)cencula.com Guest
Posted: Tue Aug 28, 2007 2:11 pm Post subject: Wing wiring conduit |
A few thoughts:
1. If you use the thin walled PVC pipe (7/8 OD), you can slide the conduit
into the wing *after* the bottom skin is on, so you don't have to worry about
bucking around an already in-place conduit.
2. If you plan the location correctly, it should be possible to use a
continuous piece of conduit that goes all the way from the wingtip into the
center of the fuselage. See http://www.our7a.com/20070331.html
3. As others have mentioned, the PVC conduit is smoother and may make it
easier to slide wires through. On the downside, it's heavier though.
Happy building,
Mike Cencula
truflite(at)yahoo.com Guest
Posted: Tue Aug 28, 2007 7:16 pm Post subject: Wing wiring conduit |
To refine your cotton ball "mouse" (that's what we
electricians call it), use a baggie instead. Make a
small balloon in one corner and tie the balloon off
with a piece of string. Leave long tails on the
string and tie the wires to the tails. Poke a small
hole in the plastic bag near the tie. Suck it through
with a vacuum. The suction pressure differential and
the small hole inflate the bag creating a seal. Don't
wrap your fingers around the wire, because that
baggie balloon will fly though the conduit like a
shotand take your fingers with it.
Dave
tight.
Darrell
cjensen(at)dts9000.com Guest
Posted: Wed Aug 29, 2007 5:05 am Post subject: Wing wiring conduit |
Dave is right about the warning " Don't wrap your fingers around the
wire, because that baggie balloon will fly though the conduit like a
shot and take your fingers with it."
Stubby
randy(at)romeolima.com Guest
Posted: Wed Aug 29, 2007 7:51 am Post subject: Wing wiring conduit |
I'll be the odd man out here and say that I prefer NOT to use conduit at all. I use snap bushings through the wing ribs then a small piece of spiral wrap around the bundle between the ribs. This lets you visually inspect the wires, keeps heat from building up, is lighter weight, and lets wires exit the bundle anywhere you like. Yes, you can reach inside through the inspection covers to install/remove the 1-2" pieces of spiral wrap in order to change/add a wire. I've used this with two RVs now and wouldn't consider any other way. Lastly, any of the conduit mentioned gives off nasty fumes if it ever burns which is why we use Tefzel wire. Why add another material with poor fire qualities when you don't need to?
Randy Lervold
www.rv-3.com
www.rv-8.com
bill(at)vondane.com Guest
Posted: Wed Aug 29, 2007 8:52 am Post subject: Wing wiring conduit |
Ok, since I didn't want to be the only one here I waited for Randy to
say something...
I did the same thing; used snap in bushings and no conduit... You can
easily rout wires through the end of the wing and the access panels with
no problem... Why add weight when you don't have to!?
-Bill VonDane
RV-8A - N8WV - 1059 empty weight!
www.rv8a.com
you don't need to?
>> Randy Lervold
>> www.rv-3.com
>> www.rv-8.com
Al.Herron(at)aerojet.com Guest
Posted: Wed Aug 29, 2007 10:09 am Post subject: Wing wiring conduit |
What I like even better than PVC pipe is the black plastic tubing for drip irrigation systems. It’s 5/8” OD, with a very thin wall. It’s tough, lightweight, and flexible enough to go around mild bends (it will kink if you try to go tighter than about a 10” radius). I’ve used it both in the wings and the fuselage.
Al Herron
RV-7A
Been dang near done for some time.
JohnInReno
Posted: Sat Sep 08, 2007 5:40 pm Post subject: Re: Wing wiring conduit |
I used CPVC and 1/2 pipe suspenders. CPVC is thinner and stronger than regular PVC. It is intended for hot water systems. The 1/2 pipe suspension clamps are riveted to the edges of the 3rd lightening hole (from the back).
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
