lamphere(at)vabb.com Guest
Posted: Fri Aug 24, 2007 1:59 pm Post subject: KX125 Wiring / Nav Com Question |
I'm in the process of rewiring the connectors on a used King KX125 nav/com
and am puzzled by a couple of pins that were previously wired.
Connector P501 pins H and J are labeled (according to pinout I got from the
aeroelectric website):
(H) VOR/LOC COMPOSITE IN and (J) VOR/LOC COMPOSITE OUT
These were previously jumpered together with a wire leading off from the
pair..
Would someone who is familiar with NAV/COMS please explain what these pins
are used for and a guess as to where they could have been connected to (in
it's previous life)??
Dave
rjquillin
Posted: Fri Aug 24, 2007 6:08 pm Post subject: KX125 Wiring / Nav Com Question |
At 14:54 8/24/2007, you wrote:
| Quote: | Would someone who is familiar with NAV/COMS please explain what
these pins are used for and a guess as to where they could have
been connected to (in it's previous life)??
External RMI perhaps?
Melvinke(at)coho.net Guest
Posted: Fri Aug 24, 2007 6:21 pm Post subject: KX125 Wiring / Nav Com Question |
The wiring diagram for the KX125 shows these connections drive an external
indicator such as KI208, KI209.
Kenneth Melvin
N669TJ
mlas(at)cox.net Guest
Posted: Fri Aug 24, 2007 6:52 pm Post subject: KX125 Wiring / Nav Com Question |
Those pins are used to drive certin CDIs, RMIs or HSIs that accept a
single composite line. Older unites require the older style of direct
analog signaling. With the composite signal you can send the
information over one wire instead of the 6-10 from the analog style.
Both sides have to be able to interpret a composite signal. Hope this
helps!
Posted: Sat Aug 25, 2007 3:21 am Post subject: KX125 Wiring / Nav Com Question |
Thanks to all that responded. Due to another persons kindness, I obtained an
installation manual for the KX125. You guys are correct in that the vor/loc
composite signal pins are used for driving an indicator. What isn't clear or
mentioned in the manual, is whether these two pins need to be jumpered (even
if you are not using an external indicator).. if there is an output AND
input involved, then does the unit need this jumper for it to function
properly?
I would guess that it won't hurt to put this jumper in anyway..
Dave
deene(at)austin.rr.com Guest
Posted: Sat Aug 25, 2007 6:10 am Post subject: KX125 Wiring / Nav Com Question |
The jumper is required (and I know as I just spend several weeks debugging a KX125 installation in which the internal VOR indicator would not work). I had to talk to the factory tech guy to get this info as the installation schematic shows the jumper as part of a connection to an external indicator but DOES NOT have a note indicating that the jumper is required for the operation of the internal VOR indicator.
Deene Ogden
EAA Tech Counselor/Flight Advisor
Posted: Sat Aug 25, 2007 8:06 am Post subject: KX125 Wiring / Nav Com Question |
Whoops! Make that thank you Deene
... eyes must be going!
Dave
AHAH!!! Thanks Duane!
without an external indicator, there aren't too many connections required.
Dave
