nuckollsr(at)cox.net Guest
Posted: Fri Aug 24, 2007 5:42 am Post subject: Strobes - Light Plane Maintenance Article |
At 05:52 PM 8/23/2007 -0700, you wrote:
<mwcreek(at)frontiernet.net>
The Sept 2007 edition of LPM has an article on strobe lights. I'm curious
as to how accurate the following excerpt is:
"A strobe power supply that has been left "off" for long periods - weeks or
months - is subject to eventual failure because the electrolytic capacitors
used in the device will loose polarity formation. As a rule, a strobe that
has been inactive for one year can be considered eligible for sudden
failure"
I have two Areoflash power supplies that were purchased new six months ago
and have since been waiting for final installation. Do I need to "exercise"
this strobe system to keep it from going bad?
There have been some excellent responses to this
so I'll offer only the following:
Articles like this are a disservice to the community
because they are non-quantified. I.e., no data followed
with logical deductions which lead to repeatable experiments
(recipes for success). This topic has been raised many
times over the years on the various aviation forums. On
one occasion in years past, I scrounged around in my
junk box for a high voltage electrolytic capacitor that I
KNEW had not been powered up for decades.
I connected it to a supply equal to it's rated voltage
(450 volts if I recall correctly). On initial power up,
the capacitor did what every capacitor does . . . draw
whatever current the source will deliver until equilibrium
is achieved. After several seconds, the capacitor's
"draw" was measured in a hand-full of milliamps and
after a minute, charging was essentially complete
and "leakage" was under 1 mA. After ten minutes,
leakage dropped to about 100 microamps.
I then did a measurement of apparent capacity. The
device was within 10% of rated value. I left the
capacitor connected to the power supply for several
days and measured apparent capacity again. It's
increase was so tiny as to make measurement
problematic.
Bottom line: In days of yore when capacitor
technology and fabrication techniques were in a
relative state of infancy, the devices were indeed
subject to deleterious effects of long term,
dormant storage.
But "modern" capacitors (meaning those built in
the last 20 or so years) have exhibited great strides
in operating performance and service life. Here's
an exemplar article on the topic:
http://www.aeroelectric.com/articles/Long_Term_Stability_Aluminum_Electrolytics.pdf
This article addresses an expected elevation of
leakage currents in the first few minutes of a long
term storage but that, "no damage to the capacitor
is to be expected".
This article is consistent with my own experience
and in particular, with an experiment conducted on
the bench. If anyone has data from an experiment arguing
with the foregoing deductions, it would be interesting
and useful for us to examine it for new understanding.
echristley(at)nc.rr.com Guest
Posted: Fri Aug 24, 2007 6:56 am Post subject: Strobes - Light Plane Maintenance Article |
The electrolytics I have had to replace have been cheap ones in consumer
products that experience continuous elevated temperatures. Computer
motherboards and stereo equipment stored in closed cabinets, for the
most part. This is consistent with the article Bob presented. Cheap
caps could be expected to possibly include more defect producing
contaminants, and the article makes note that high heat tends to be
detrimental.
-A strobe power supply may or may not be stored in a way to control
temperature. Ambient temps have exceeded the 25C that the article
suggest for weeks now here in NC. If it were buried in a wing stored in
the rafters of a hanger, the temps could be much higher still. Could
that be the nexus of the problem?
-If the strobe is using cheap caps...well, I'd just be upset about that one.
Posted: Mon Aug 27, 2007 9:57 am Post subject: Strobes - Light Plane Maintenance Article |
At 09:23 AM 8/27/2007 -0500, you wrote:
| Quote: | I called Wheelen when I had a "new in the box" twenty year old power supply.
I was told three volts for an hour, then six, nine, twelve. Each for one
hour. That was three years ago, still works fine.
Kevin Boddicker
Tri Q 200 N7868B 63.5 hours
Luana, IA.
On Aug 27, 2007, at 8:06 AM, John McMahon wrote:
>Just an additional comment.. In the Whelan strobe installation manual it
>cautions you not to apply full voltage to a power supply that has not
>been charged for a long time, such as on initial installation. If I
>remember correctly it says to start by applying half power initially. I
>am on the road so cannot look it up until the end of the month, maybe
>someone else can confirm my recollection.
It never hurts to do a 'reforming' exercise on a strobe
supply that has been in storage for a long period of time.
What is not known . . . and will never be known without some
judicious data gathering and analysis is whether or not
the device really benefits from this exercise. It's doubtful
that any of the big dogs in the strobe business will come
forward with real data . . . it's pretty hard to find capacitors
that have been in storage for 20+ years.
The 'reforming' routine has been a standard fixture in
the installation manuals for 40 years. Some folks still
recommend avionics master switches for radios. But when asked
to supports the validity of the exercise with simple-ideas
and repeatable-experiments, the standard response is "that's
the way we've always done it."
If anyone is worried about it, by all means do the extended
spool-up exercise.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
Eric M. Jones
Posted: Tue Aug 28, 2007 6:48 am Post subject: Re: Strobes - Light Plane Maintenance Article |
Check--http://industrial.rell.com/pdfs/IPG_AN_appguide.pdf
Excerpt from above:
"Aluminum electrolytic capacitors stored for more than 5 to
10 years may have increased levels of DC leakage current.
Check if DCL meets application requirements before placing
in service. Recondition high DCL units by applying
rated voltage through 1,000 ohm resistor for 30 minutes.
Shelf life is a measure of how the capacitors will withstand
storage for long times especially at high temperature. To
test shelf life place the capacitors in an oven set to the
shelf-life test temperature –0 +3 °C for the shelf-life test
period. Upon completion of the test stabilize the capacitors
at 25 °C for 24 h or more. Apply the rated voltage for 30
minutes, then verify the post test limits. Unless otherwise
specified the capacitance, DCL and ESR will meet initial
requirements."
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
