tdawson-townsend(at)auror Guest
Posted: Wed Aug 22, 2007 9:41 am Post subject: Shower of Sparks |
Bob:
In discussing Shower of Sparks ignition, you have mentioned Unison Slick Start. On the Aircraft Spruce webpage, then imply that Slick Start is only for use with Slick magnetos, not Bendix units. Do you think there’s a technical reason, or that’s just certification/lawyer talk?
Tim Dawson-Townsend
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
nuckollsr(at)cox.net Guest
Posted: Thu Aug 23, 2007 5:00 am Post subject: Shower of Sparks |
At 01:40 PM 8/22/2007 -0400, you wrote:
| Quote: | Bob:
only for use with Slick magnetos, not Bendix units. Do you think there s
a technical reason, or that s just certification/lawyer talk?
Shower of Sparks or "SOS" enhancement to magneto performance
still stands out in my mind as one of those extra-ordinary
examples of clever design from the CSP era (copper, steel
phenolic). Contemporary designers can select from millions
of commercial off the shelf parts and in particular, little
chunks of multi-legged plastic offering functionality from
"simple" amplifiers (20 transistors!) to gigaflop-fast
super-processors (tens of thousands of transistors).
In the time when Shower of Sparks was crafted, the catalog
of materials available to our creative ancestors was limited
to a relatively few, rudimentary components. Yet, by understanding
the simple-ideas for the materials at hand and the task to
be accomplished, devices like . . .
http://www.aeroelectric.com/Pictures/Regulators/ALTREG2.jpg
were produced with out-the-door performance on a par with
the later . . .
http://www.aeroelectric.com/Pictures/Regulators/Ford_SS_Reg_open.jpg
or most modern incarnations like . . .
http://www.aeroelectric.com/Pictures/Regulators/Alternator_Regulators.jpg
Shower of sparks was conceived as a melding of magneto
and Kettering ignition systems for battery enhancement
of spark energy during low speed operations (cranking).
The enhancement had two important features . . . a
battery excited, electromechanical "buzzer" that would
supply the magneto primary with a rapidly repeating
pulse of energy from the battery and a second set of
delayed-timing, cranking-points temporarily switched
in parallel with the advanced-timing, running-points.
See:
http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf
I've not been made privy to the simple-ideas that support
functionality of the Slick Start. My present
understanding of the product suggests that it does not
require a second set of points. From this I infer
the device is fitted with some intelligence that
delays delivery of battery enhanced pulses by some
amount which emulates the delayed-timing points common
to the earlier system.
Assuming my understanding is correct, then I can
deduce no reason why the product (or one exceedingly
similar to it) wouldn't function with any brand
of magneto. But without the support of the designers
or a cognizant technician, we'll not have enough
information to craft a definitive answer to your
question. Perhaps someone on the List has a lead
on the details of this systems design and operation.
bakerocb
Posted: Thu Aug 23, 2007 5:03 am Post subject: Shower of Sparks |
8/23/2007
Hello Tim, Will you permit a non Bob to answer?
Unison originaly built the SlickSTART P/N SS1001 for only Slick magnetos. In
1998 they added SlickSTART P/N SS1002 for use with TCM/Bendix magnetos.
So which version of the SlickSTART Magneto Start Booster (solid state
ignition starting vibrator) you use will depend upon which brand of magnetos
you use.
The Unison Service Letter L-1492 (Revision D is current) contains a caution
that says using P/N SS1001 with Bendix/TCM magnetos may result in magneto
damage and engine stoppage.
There are some fairly recent postings in the aeroelectric archives that may
be of value or interest to someone considering SlickSTART. I suggest that
you search for SoS Vibrator Recommendations, or Slick Start. You can also
pick out the pertinent items if you search for bakerocb.
Please let me know if you have any further questions.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PS: It would be more precise if we used the generic term "starting vibrator"
when writing in general about this subject and reserve "Shower of Sparks"
for referring specifically to the TCM/Bendix mechanical vibrator and
"SlickSTART" for referring specifically to the Unison solid state starting
vibrator.
---------------- RESPONDING TO ----------------------------------------
Time: 10:41:48 AM PST US
Subject: Shower of Sparks
Bob:
there's a technical reason, or that's just certification/lawyer talk?
Tim Dawson-Townsend
tdt(at)aurora.aero
retasker(at)optonline.net Guest
Posted: Thu Aug 23, 2007 9:35 am Post subject: Shower of Sparks |
Nothing to do with shower of sparks, but you should be aware that the
"gigaflop-fast super-processors" now include over one "billion"
transistors, and fast approaching tens of billions!
Dick
<nuckollsr(at)cox.net>
bakerocb
Posted: Fri Aug 24, 2007 5:07 am Post subject: Shower of Sparks |
8/24/2007
Hello Bob,
1) You wrote: "Perhaps someone on the List has a lead on the details of this
systems design and operation."
Looking at the patent for the Unison SlickSTART Magneto Start Booster may
provide some helpful information. See this link:
http://patft.uspto.gov/netacgi/nph-Parser?u=%2Fnetahtml%2Fsrchnum.htm&Sect1=PTO1&Sect2=HITOFF&p=1&r=1&l=50&f=G&d=PALL&s1=5630384.PN.&OS=PN/5630384&RS=PN/5630384
If that doesn't work just Google "US Patent 5630384" (thanks to Eric).
2) You wrote: "My present understanding of the product suggests that it does
not require a second set of points. From this I infer the device is fitted
with some intelligence that delays delivery of battery enhanced pulses by
some amount which emulates the delayed-timing points common to the earlier
system."
You are correct that the solid state SlickSTART unit does not require a
second set of points, but it does not incorporate any internal delayed
timing.
To explain: To take best advantage of the SlickSTART's longer duration and
higher peak voltage sparking over that provided by just an impulse coupled
magneto a magneto with a set of retard breaker points is required. However,
if the SlickSTART unit is used with an impulse coupled magneto with a single
set of points there will still be an increase in both peak output voltage
and sparks per sequence over that which would be provided by the impulse
coupling acting alone.
A copy of Unison's SlickSTART brochure and its claims can be found at this
link:
http://www.unisonindustries.com/docs/Slickstartflyer_1493.pdf
3) You wrote: "Assuming my understanding is correct, then I can deduce no
reason why the product (or one exceedingly similar to it) wouldn't function
with any brand of magneto."
I can't offer any technical reason, but can only repeat what I posted
earlier on this specific point:
"The Unison Service Letter L-1492 (Revision D is current) contains a
caution
damage and engine stoppage."
Unison does provide SlickSTART P/N SS1002 for use with the TCM/Bendix
magnetos.
Some general comments:
A) I have been operating my amateur built experimental aircraft equipped
with a TCM IO-240 B9B engine and a SlickSTART P/N SS1001 magneto start
booster for over 185 hours.
B) The left magneto is a Slick P/N 4310 with a set of retard breaker points.
The SlickSTART booster is connected to this magneto. The right magneto is a
Slick P/N 4309 direct drive with no impulse coupling or retard breaker
points.
C) The engine is cranked with the right magneto grounded out during
cranking.
D) I had difficulty in obtaining enough information on the functioning of
the SlickSTART unit from Unison to make my initial wiring installation. This
was because all of their installation information was based on the
assumption that one was removing a TCM/Bendix "Shower of Sparks" unit and
replacing it with the SlickSTART unit. It was difficult to reverse engineer
their instructions into a "start from scratch" situation. After a false
start response from the Unison marketing department, and follow up detailed
correspondence with their tech support people, I was able to make the
installation.
E) I am very satisfied with the performance of my SlickSTART unit and would
highly recommend it to anyone using conventional magnetos instead of
electronic ignition in their Lycoming or TCM engine.
------------------ RESPONDING
TO ----------------------------------------------
Time: 06:00:17 AM PST US
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Shower of Sparks
| Quote: | Bob:
the later . . .
See:
