mwcreek(at)frontiernet.ne Guest
Posted: Thu Aug 23, 2007 4:57 pm Post subject: Strobes - Light Plane Maintenance Article |
The Sept 2007 edition of LPM has an article on strobe lights. I'm curious
as to how accurate the following excerpt is:
"A strobe power supply that has been left "off" for long periods - weeks or
months - is subject to eventual failure because the electrolytic capacitors
used in the device will loose polarity formation. As a rule, a strobe that
has been inactive for one year can be considered eligible for sudden
failure"
I have two Areoflash power supplies that were purchased new six months ago
and have since been waiting for final installation. Do I need to "exercise"
this strobe system to keep it from going bad?
Mike Creek
matronics(at)rtist.nl Guest
Posted: Thu Aug 23, 2007 11:34 pm Post subject: Strobes - Light Plane Maintenance Article |
In the radio tube era (when Lycoming engines were designed this was true
for equipment that was shelved for many years, but with modern parts this is
not true anymore. Elco's are indeed getting worse when left without power
for extended periodes of time, but not in the 'weeks or months' timeframe.
All electronic equipment has electrolytic capacitors in them, and if this
was the general timespan for elco's then you'd also have to replace your ELT
transmitter every so many weeks or months. They have elco's too, and I hope
for your sake you do not have to run them every six months...
I think the article has been inspired by an over-active marketing department
who would like to see you replace perfectly good parts. Can you imagine
their revenue increase if their 'rule' would be mandatory? Every owner who
doesn't fly their plane for 6 months (winter or so) replacing all
electronics with elco's in them? I'm gonna buy me some stock...
Rob
wrmaxwell(at)bigpond.com Guest
Posted: Fri Aug 24, 2007 12:31 am Post subject: Strobes - Light Plane Maintenance Article |
I doubt it. The message is greatly exaggerated. Electrolytic capacitors
will eventually lose their capacitor ability if left on a shelf for a long
time, but that is many years in my experience. They rely upon being
connected in circuit with a voltage across them, so an oxide layer can form
on the aluminium foil from which they are constructed. It provides the
necesary dielectric layer. However, a capacitor which has lost that layer
can be re-formed by connecting them up andprogressively increasing the
voltage to the rated working voltage.
If the LPM article were correct, every set of strobes would need to carry an
"instal by" date. I imagine that most would have a period between
manufacture and sale of greater than 12 months.
Bill
blackoaks(at)gmail.com Guest
Posted: Mon Aug 27, 2007 5:08 am Post subject: Strobes - Light Plane Maintenance Article |
Just an additional comment.. In the Whelan strobe installation manual it cautions you not to apply full voltage to a power supply that has not been charged for a long time, such as on initial installation. If I remember correctly it says to start by applying half power initially. I am on the road so cannot look it up until the end of the month, maybe someone else can confirm my recollection.
On 8/24/07, Robert L. Nuckolls, III <nuckollsr(at)cox.net (nuckollsr(at)cox.net)> wrote:[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net (nuckollsr(at)cox.net)>
At 10:54 AM 8/24/2007 -0400, you wrote:
| Quote: | --> AeroElectric-List message posted by: Ernest Christley
<echristley(at)nc.rr.com (echristley(at)nc.rr.com)>
<snip>
| Quote: | -A strobe power supply may or may not be stored in a way to control
temperature. Ambient temps have exceeded the 25C that the article suggest
for weeks now here in NC. If it were buried in a wing stored in the
rafters of a hanger, the temps could be much higher still. Could that be
the nexus of the problem?
-If the strobe is using cheap caps...well, I'd just be upset about that one.
Which speaks to the value of conducting tests per DO-160.
One cannot attract many customers in the type certificated
aircraft world without jumping these hoops. Further, given
the exceedingly small fraction of the world represented by
aviation circles, it's impossible to keep the astute mechanics
from knowing about poorly crafted products or less than
helpful customer support. Stack these notions with the
idea that really good capacitors are not that much more
expensive than mediocre devices. Given the blood, sweat and
tears sacrificed to the altars of regulation, it's
unlikely that a company like Grimes or Whelen is going
to compound their grief-to-market by cutting corners in
Lancair Super ES, S/N 170, N9637M (Reserved) [quote][b]
Posted: Mon Aug 27, 2007 6:19 am Post subject: Strobes - Light Plane Maintenance Article |
Just looked at the manual, and it does indeed hold a warning for older units
only. Below is a quote from the manual.
Rob
WARNING: Strobe light power supplies are meant to be used, not to
remain in an inactive state. Use them at all times, this will improve their
proper functioning. Any strobe light power supply that has been out of
service for a long period of time is subject to failure because the
electrolytic
condenser loses the polarity formation. A strobe light power
supply not having been used for one year or longer is vulnerable to
failure, applies to 1993 & older units.
If this is the case, it is recommended to start operating the system on
a voltage that is reduced by 25 percent for 10 to 15 minutes before putting
the power supply into normal service. This will prevent overheating
of the condenser while they reform. If the power supply, after a long
period of non use, is operated at full voltage immediately, there is an
excellent possibility that the condenser will become overheated.
trumanst(at)netins.net Guest
Posted: Mon Aug 27, 2007 6:22 am Post subject: Strobes - Light Plane Maintenance Article |
I called Wheelen when I had a "new in the box" twenty year old power supply.I was told three volts for an hour, then six, nine, twelve. Each for one hour. That was three years ago, still works fine.
Kevin Boddicker
Tri Q 200 N7868B 63.5 hours
Luana, IA.
On Aug 27, 2007, at 8:06 AM, John McMahon wrote:
[quote]Just an additional comment.. In the Whelan strobe installation manual it cautions you not to apply full voltage to a power supply that has not been charged for a long time, such as on initial installation. If I remember correctly it says to start by applying half power initially. I am on the road so cannot look it up until the end of the month, maybe someone else can confirm my recollection.
On 8/24/07, Robert L. Nuckolls, III <nuckollsr(at)cox.net (nuckollsr(at)cox.net)> wrote: | Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net (nuckollsr(at)cox.net)>
<snip>
Lancair Super ES, S/N 170, N9637M (Reserved) | Quote: |
