shankeroid(at)verizon.net Guest
Posted: Thu Aug 23, 2007 10:54 am Post subject: Marion Air Filter Base |
Does anyone know of a firewall-mount base for the Marion S-28 MG oil filter? Also any benefit of going with an ADC or Airwolf? Thanks.
Jim Shanks
shankeroid(at)verizon.net (shankeroid(at)verizon.net)
Dale
Posted: Thu Aug 23, 2007 1:16 pm Post subject: Re: Marion Air Filter Base |
I installed a Airwolf filter on my 52, Airwolf has the photo's of the install I did and the modifications to the oil system to make it fit. Airwolf will explain why a filter is better than a screen and the benefits. Filter install should be on the outlet side of the engine so that hot oil flows through the filter and then filtered oil on to the cooler. I had to make two fittngs and hoses. The photo's are self explaining. Works great.
cpayne(at)joimail.com Guest
Posted: Thu Aug 23, 2007 5:00 pm Post subject: Marion Air Filter Base |
I sell a Marion-compatible base as well as 10 micron paper elements. My base sells for 1/10 the price of the Air Wolf but does not come with a cute animal decal. Still working that angle so I can raise my prices :>) See it on my website: http://home.joimail.com/~cpayne1/
Craig Payne
cpayne(at)joimail.com (cpayne(at)joimail.com)
brian-1927(at)lloyd.com Guest
Posted: Thu Aug 23, 2007 5:18 pm Post subject: Marion Air Filter Base |
I'm thinking that a buzzard or a Dodo would be nice and in keeping
with the use of the product.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
nc69666(at)aol.com Guest
Posted: Thu Aug 23, 2007 7:35 pm Post subject: Marion Air Filter Base |
Contact Bill Blackwell at Deer Valley on Phoenix,, He has been using them for several years... Gary Gabbard CJ N22YK... I have had one on mine for several years...
JBernier(at)dart.org Guest
Posted: Fri Aug 24, 2007 5:00 am Post subject: Marion Air Filter Base |
Jim
I have been using the Marion filter for 65 hours engine time and find no fault. In fact, the placement that I choose makes it easy and clean to change the filter and oil. It also helps the CG location. I bought the filters from Craig a couple of years ago. Initially, Craig didn't have the mount for the filter, just the filters. And cheap. The filter needs to be place on the oil line that is from the output side of the pump. Taking the input line off the oil cooler and swinging it 90 degrees to port gives you an idea of were to place the filter. All that you need is another short oil line from the filter to the cooler. Doug or Craig can help with that. This new line needs a 90 degree fitting and one straight fitting.I have attached some photos of the belly placement that I used. The mount that I used has a 25 lbs. by-pass valve. Ask Craig if his has the same.
Why pay more when you can have the same for less. If I remember correctly, my mount came from Arizona. Some auto racing supply house. I would buy Craig's.
I hope that this gives you another avenue.
Jim B
Quote: | >> "Jimbo Shanks" <shankeroid(at)verizon.net> 8/23/2007 1:53 PM >>>
Jim Shanks
nics.com
Description: |
Filesize: |
90.56 KB |
Viewed: |
342 Time(s) |
Description: |
Filesize: |
90.35 KB |
Viewed: |
349 Time(s) |
Description: |
Filesize: |
105.37 KB |
Viewed: |
354 Time(s) |
