av8rps(at)tznet.com Guest
Posted: Tue Aug 14, 2007 12:38 pm Post subject: Broken Kitfoxes everywhere at OSH! |
Hi Gang,
Check out EAA's web videos to see a couple of our very own making the
spotlight.....well, sort of. I'm sure not in a way they would like to be
known for, but attention just the same. The direct link is
http://link.brightcove.com/services/link/bcpid626910413/bclid1119199227/bctid1137752093
(works poor at best on dial up, so hopefully most of you have high
speed.....unlike me)
I'm not just picking on these guys, as my Kitfox also got a little video
attention at the seaplane base (see the EAA Seaplane Base web video) by
having some mechanical difficulties as well. I was somewhat spared as you
can't tell my Fox is broken by seeing it sit on the wooden seaplane ramp,
but it was for sure broken at the time. Nothing major, but broke just the
same...
I guess all we can all do now is just laugh at all of it. Even though it's
probably not the best kind, at least we gave the world a little more
exposure to a Kitfox (chuckle)
Paul Seehafer
Model IV-1200 912ul IVO on amphibs
if for any reason the link doesn't work for anyone, try
http://www.airventure.org:80/video/index.html?videoId=1127687111
Guy Buchanan
Posted: Tue Aug 14, 2007 8:49 pm Post subject: Broken Kitfoxes everywhere at OSH! |
At 01:37 PM 8/14/2007, you wrote:
| Quote: | Check out EAA's web videos to see a couple of our very own making
the spotlight.....well, sort of. I'm sure not in a way they would
like to be known for, but attention just the same.
Hey that's our own Lynn Farnsworth! He's a star! (I wonder what was
wrong with the Jab?) (Man that guy gets around. Last I saw him he was
at Lowell's in Cameron Park, CA.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Wed Aug 22, 2007 9:54 am Post subject: Broken Kitfoxes everywhere at OSH! |
I just got back to dealing with my email, and the 200+ messages. Is
there another Lynn with a "broken" Kitfox? Who is Lynn Farnsworth? Is
he the yellow 'fox with the broken prop? Good to see that he got it
going again. I'm still downloading the video called "Emergency
Aircraft Repair" and it's taking FOREVER on this dial-up line.
If you're referring to me, Guy, I had the battery die on my plane
while lining up for the "Homebuilder's Review". I had them tow it
over to Emergency Aircraft Repair so I could charge the battery. It
started just fine later that evening.
What happened was that during the looooooooong taxi down to the
threshold of 36, I had to taxi slowly behind other planes, and my
engine loaded up, and I couldn't very well clean it out without
revving it up and taking a chance on gobbling up somebody's rudder in
front of me. Then when I went to shut it down, I usually shut off the
main fuel valve and let the engine run for a few minutes to lower the
amount of fuel in the bowl. Then during a restart, the engine will
start immediately. If I miss doing this (and I did), I have to treat
it like a flooded car engine, and hold full open throttle 'til it
starts...about 10-15 seconds. When it didn't start right away, I went
to "choke mode" and this only worsened the problem, then the battery
began to get low, and finally gave up the ghost. I had left the
master on the night before, charging my cell phone, and this took a
little bit out of the battery, but it started fine just before
heading for the Homebuilder's Review. It was just all that taxiing,
loading up of the engine, and neglecting my normal shutdown/starting
procedures that caused that embarrassing scene in front of the
"amassed thousands" who had all come to see the #3 fly....yeah,
RIGHT!! : )
Lynn Matteson
flying w/369+ hrs
On Aug 15, 2007, at 12:48 AM, Guy Buchanan wrote:
was at Lowell's in Cameron Park, CA.)
Guy Buchanan
San Diego, CA
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Wed Aug 22, 2007 11:02 am Post subject: Broken Kitfoxes everywhere at OSH! |
On Aug 22, 2007, at 7:58 PM, Lynn Matteson wrote:
| Quote: | Then when I went to shut it down, I usually shut off the main fuel
valve and let the engine run for a few minutes to lower the amount of
fuel in the bowl. Then during a restart, the engine will start
immediately.
That's interesting, Lynn. I also need a few seconds on the starter if I
stop my Jabiru then start it again say, ten minutes later. I thought it
was the opposite happening; the heat of the engine evaporates the fuel
in the carburettor. But your experience is that it is flooding.
I think I will try your method the next time I know I have to start
again a warm engine.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Guy Buchanan
Posted: Wed Aug 22, 2007 2:00 pm Post subject: Broken Kitfoxes everywhere at OSH! |
At 10:58 AM 8/22/2007, you wrote:
| Quote: | If you're referring to me, Guy, I had the battery die on my plane
LOL! Man I could screw up a wet dream! Sorry Lynn. I thought of you
and another name popped out. I'm glad to hear it was no big deal. It
was a nice video, though.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
kirkhull(at)kc.rr.com Guest
Posted: Wed Aug 22, 2007 6:20 pm Post subject: Broken Kitfoxes everywhere at OSH! |
I flew in to Brodhead and then on to OSH the next day stayed the week and
made it home to Kansas City with no problems other then weather. 205AK (red
classic 4 with a Subaru) performed flawlessly.
Lynn Matteson
Posted: Thu Aug 23, 2007 2:42 am Post subject: Broken Kitfoxes everywhere at OSH! |
I got that hot tip from somebody on the Jabiru List, I think. What I
usually do is to land, taxi toward a parking place, and when I'm
about a minute or two from there, or about 200 feet short of parking,
I shut off the main fuel valve on the console. I've even had it quit
a few feet from the parking place, in which case I'll just turn it on
again, start it and shut off the main valve again, and continue to
taxi. Since I started to do this, it starts every time. If I forget
to do this, I have to treat it like a flooded engine, and give it
full throttle until it starts.
I can't figure out how you can flood an updraft carburetor, but this
system cures it, whatever is happening.
Lynn Matteson
flying w/369+ hrs
On Aug 22, 2007, at 3:01 PM, Michel Verheughe wrote:
> of fuel in the bowl. Then during a restart, the engine will start
> immediately.
if I stop my Jabiru then start it again say, ten minutes later. I
thought it was the opposite happening; the heat of the engine
evaporates the fuel in the carburettor. But your experience is that
it is flooding.
Cheers,
Michel Verheughe
Norway
N369LM |
Lynn Matteson
Posted: Thu Aug 23, 2007 2:47 am Post subject: Broken Kitfoxes everywhere at OSH! |
Nice video, except for that old bald guy who was working on my plane!
Wonder who that was...I thought all this time that all pilots were
young and handsome, like John Wayne and Errol Flynn...
Lynn Matteson
flying w/369+ hrs
On Aug 22, 2007, at 5:42 PM, Guy Buchanan wrote:
It was a nice video, though.
Guy Buchanan
San Diego, CA
N369LM |
Lynn Matteson
Posted: Thu Aug 23, 2007 2:49 am Post subject: Broken Kitfoxes everywhere at OSH! |
Well, in our campsite we had one "faulty" Jabiru (mine) and another
non-starting Rotax, who I will not name...I'll let him 'fess up.
Lynn Matteson
flying w/369+ hrs
week and
205AK (red
N369LM |
Michel
Posted: Thu Aug 23, 2007 3:55 am Post subject: Broken Kitfoxes everywhere at OSH! |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Thanks, Lynn, I'll try that too. Funny that good Jabiru tips must come from ... the Kitfox list!
Cheers,
Michel Verheughe
Norway
PS: Yes I also thought that all pilots were handsome; what's why I started flying in the first place but ... looking lately at the mirror ... I have doubts!
