bbradburry(at)bellsouth.n Guest
Posted: Mon Aug 13, 2007 4:58 am Post subject: Headset plug polarity |
I am amazed at the difficulty in finding the polarity on the internet. Can
someone help me here?
What should be the polarity of the sleeve, ring, and tip on a stereo plug?
Which, ring or tip, is probably right and which is probably left on the
stereo plug?
Also what should be the polarity of the sleeve and tip on the mono plug.
How should I wire a stereo receptacle so that it could be used for both
stereo or mono?
Bill B
rleffler
Posted: Mon Aug 13, 2007 6:02 am Post subject: Headset plug polarity |
My first thought was to quickly reply, but my information is off the top of my head and may not be correct.
My recommendation is to check your headset manufacturer's web site or give them a call. I'm sure in a couple minutes you would have an answer.
My guess would have be tip-right, ring-left, sleeve-ground.
On a mono plug, the tip has the signal and the sleeve is the ground.
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: 2007/08/13 Mon AM 07:57:05 EST
To: <aeroelectric-list(at)matronics.com>
Subject: Headset plug polarity
stereo plug?
stereo or mono?
Bill B
_________________ Bob Leffler
N410BL - Phase I
rjquillin
Posted: Mon Aug 13, 2007 6:43 am Post subject: Headset plug polarity |
At 05:57 8/13/2007, you wrote:
stereo plug?
"Standards" have evolved and changed over the years, and not every
manufacturer follows them anyway, and draftsmen frequently don't know
or care how a jack is drawn and get it wrong. From the audio world:
Tip Right
Ring Left
Sleeve Common
PS-Engineering, and others, agree.
| Quote: | Also what should be the polarity of the sleeve and tip on the mono plug.
Tip hot
Sleeve Common
| Quote: | How should I wire a stereo receptacle so that it could be used for both
stereo or mono?
There isn't any really good, safe and easy way and the method
selected would properly be dependent on what the signal source is,
and how well it may or may not be fault protected.
With two broken wrists in casts, I'm typing challenged. Perhaps
others can elaborate.
Ron Q.
Posted: Fri Aug 17, 2007 7:03 pm Post subject: Headset plug polarity |
Bill Bradburry wrote:
stereo plug?
stereo or mono?
Bill B
Hi Bill,
I think that my email messages have been wandering around in Ted
Stevens' "pipes" for days before being delivered to me.
There's a simple way to check right/left wiring in a connector. Grab a 1
1/2V battery, a couple of clip leads & your stereo headset. Put the
headset on your head, but offset the earcups so they aren't over your
ears. Connect one terminal from the battery to the sleeve (closest to
the insulated end & wire). Touch the other terminal of the battery to
the tip of the connector. The side that clicks as you make & break the
connection is wired to the tip. Assuming that you are wearing the
headset correctly, you now know how the connector should be wired. To
get the right terminal on the jack, just remember that the tip is
farthest from the nut and follow the metal to the solder tab. Same
principle for ring & sleeve in the jack.
There isn't really any practical way to wire a stereo connector for both
stereo & mono. You can set it up with a switch, but then you're
dependent on remembering to set the switch correctly.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sat Aug 18, 2007 7:45 pm Post subject: Headset plug polarity |
In a message dated 08/17/2007 10:06:34 PM Central Daylight Time, ceengland(at)bellsouth.net writes:
| Quote: | There isn't really any practical way to wire a stereo connector for both
dependent on remembering to set the switch correctly. |
My understanding as well. I installed mono & stereo jacks on my plane using a switching mono plug that ties L&R channels together when the plug is inserted, and used a spring-loaded cover on the stereo jack with a lable stating "Stereo Only" on it. One way to git a kitty rug!
Diagram available on AutoCAD if interested...
From The PossumWorks in TN
Mark Phillips
_________________ From The PossumWorks... |
bwolf1(at)tds.net Guest
Posted: Sun Aug 19, 2007 7:50 am Post subject: Headset plug polarity |
Hi Mark
I am totally deaf in one ear and always have trouble with stereo headsets. I feel like I am only hearing half the world! Do you know of a commercially available adapter that would ALWAYS combine the signals on a standard aviation headset? While we are on the subject.....it is even a bigger problem with my MP3 player. It has a little 1/8 (?) inch stereo jack. Do you know of any full time, stereo to mono, adaptors for that?
Brooke
rjquillin
Posted: Sun Aug 19, 2007 8:36 am Post subject: Headset plug polarity |
At 08:47 8/19/2007, you wrote:
| Quote: | I am totally deaf in one ear and always have trouble with stereo
Brooke
One "always works" solution I've seen on at least one commercial
headset was the inclusion of a switch somewhere on/in the headphone
or cable that took the wire normally connected to the ring of the
connector and electrically moved it to parallel the wire connected to
the tip. Both earphone transducers were then parallel on the tip,
with the common return on the sleeve. Downside; the impedance seen
by the intercom/radio driving the headphones in now only half what it
was and this may be a problem, but generally far less than shorting
out the left and right outputs of some amplifier to one another.
A SPDT (3-terminal) switch mounted in an ear cup could easily suffice.
Ron Q.
Posted: Sun Aug 19, 2007 10:11 am Post subject: Headset plug polarity |
Brooke Wolf wrote:
| Quote: | Hi Mark
for that?
Brooke
Google is your friend.
http://www.google.com/search?num &hl=en&q=mono+to+stereo+headphone+adaptor&btnG=Search
Peter Laurence
Rhino
wooody04(at)bellsouth.net Guest
Posted: Wed Aug 22, 2007 10:52 am Post subject: Headset plug polarity |
Says who?????
Peter Laurence wrote: [quote] Mark,
I would be interested in the cad file.
BTW, just recently installed your static ports. My local RV buddies all have static port envy.
send it to : plaurence(at)the-beach.net (plaurence(at)the-beach.net)
Peter
