baremetl(at)gvtc.com Guest
Posted: Sat Aug 18, 2007 7:36 pm Post subject: LSE Direct crank vs. Hall effect |
After nearly 1400 hrs.and 4 mag failures (Slick), I am considering an LSE unit to replace the right mag. I realize that the direct crank sensor is less expensive and that the Hall effect sensor that mounts in the old mag position is simpler to install. Ignoring the cost difference and initial installation difference, is there any other reason to pick one over the other? I am looking for comments on reliability of one sensor vs. the other and any other pertinent information.
Ivan Haecker -4 1381 hrs. S. Cen. TX
ps 3 failed coils and 1 failed condensor. And yes I used blast tubes (after the 1st failure!)
dcw(at)mnwing.org Guest
Posted: Sun Aug 19, 2007 4:46 am Post subject: LSE Direct crank vs. Hall effect |
