		jodel(at)nildram.co.uk Guest
				 Posted: Fri Feb 17, 2006 1:47 pm    Post subject: Question for xs Trigear owners |
				How the f#(at)%~g hell do you get the bottom half of the cowl on with a 3 blade
 prop in place?
 I gave up in the end and took the prop off but this surely can't be
 necessary????????????????????
 Simon
 Speed kit, finger brake master cylinder and upholstery left to do.
		rholder(at)avnet.co.uk Guest
				 Posted: Fri Feb 17, 2006 2:07 pm    Post subject: Question for xs Trigear owners |
				Simon Smith wrote:
  	  | Quote: | 	 		   How the f#(at)%~g hell do you get the bottom half of the
  cowl on with a 3 blade prop in place?
  surely can't be necessary????????????????????
 You need to take the top cowl off first ! But I assume you
 have done this !
 Actually it is easiest if you remove the exhaust stub. And
 be sure you have a blade vertical so that the other two
 are equally angled downwards.
 And if this doesn't work you will have to relieve
 fibreglass until it does ! Taking the prop off every time
 you take off the lower cowling is NOT sensible !
 HTH, tongue in cheek !
 Richard Holder
 G-OWWW High Cross
		flyinggpa(at)comcast.net Guest
