Posted: Sun Aug 12, 2007 2:08 pm Post subject: Anyone have carb ice with intercooled 914? |
Has anyone ever experianced carb ice on a intercooled 914?
See attached PDF chapter 18.
Rotax has updated website:
http://www.rotax-owner.com/index.htm
Click Support
Click Technical Info
Click Technical articles
Ron Parigoris
Posted: Sun Aug 12, 2007 10:34 pm Post subject: Anyone have carb ice with intercooled 914? |
Hi! Ron
My current assessment is that it is unlikely. I believe the uplift of
the ingoing air temperature is quite high without an intercooler from
info. provided by others. I'm expecting in the region of a drop of 20
deg summer and 25 deg. winter
But from the original figures there's still lots of temperature put in
the air by the turbo.
However since it's the venturi effect and humidity which causes the
icing on the carb throat until mine flies in the next two weeks I won't
be sure.
It is a very relevant consideration, a friend pranged on Saturday, he
had been thermaling ,engine off (not a Europa) re-started to land and
decended maintaining 200deg on his cylinder heads when he needed the
throttle to clear power lines to land the engine quit. Finished up in a
sweet corn/maize field totalled but both walked away. That's in the UK
with present humidity levels ! So much attention needs applying when
doing mods 73 and 74.
Bob H G-PTAG
acrojim(at)cfl.rr.com Guest
Posted: Mon Aug 13, 2007 5:21 pm Post subject: Anyone have carb ice with intercooled 914? |
Ron
We have been running the 914 with an intercooler approx 600 hrs here in
Florida. We have not had any problems with carb ice.
I do have a few observations about the subject.
In normal cruise settings I use 33"MP and 5300 RPM. There is enough heat
going into the airbox at this setting from the turbo, that there has been no
problem with carb ice. However I can see that if one were to spend time in
the pattern at low throttle settings below 28 or 29" of MP carb ice could be
a possibility.
I also can see that things will be different if one has a fixed pitch prop
installed. I would think that since the MP would be tied to the RPM , in
pattern work a very good possibility that carb ice could happen.
Sorry for the ramblings...but your question got me to thinking about how
carb ice could happen in the 914.
Jim Brown
Posted: Mon Aug 13, 2007 11:58 pm Post subject: Anyone have carb ice with intercooled 914? |
rparigor(at)suffolk.lib.ny.us a écrit :
| Quote: | Has anyone ever experianced carb ice on a intercooled 914?
Ron and all,
Never experienced carb ice on the Rotax 914. French dealer Avirex
says it is very unlikely.
In our tightly cowled setup the carbs run really warm so the probability
is low. But in other airplanes things may be different.
Best regards,
Gilles
http://contrails.free.fr
Trevpond(at)aol.com Guest
Posted: Tue Aug 14, 2007 2:40 am Post subject: Anyone have carb ice with intercooled 914? |
Hi Jim,
At 33"mp and 5300rpm, what is your fuel usage?
Trev Pond
G-LINN
Posted: Tue Aug 14, 2007 3:26 am Post subject: Anyone have carb ice with intercooled 914? |
Trevor
Does this mean you had ICE ?
Bob H G-PTAG
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Trevpond(at)aol.com
Sent: 14 August 2007 11:40
Subject: Re: Anyone have carb ice with intercooled 914?
Hi Jim,
Trev Pond
G-LINN
[quote] - The Europa-List Email Forum - --> http://www.matronics.com/Navigator?Europa-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com [b]
Posted: Tue Aug 14, 2007 3:33 am Post subject: Anyone have carb ice with intercooled 914? |
Only with a Gin and Tonic!
Trev
Posted: Wed Aug 15, 2007 3:25 am Post subject: Anyone have carb ice with intercooled 914? |
Trev
I do not have a fuel flow meter installed. However on cross country's over the years, we have found that at these settings we burn 5 gal an hour.
Jim Brown
