Tim_Lewis(at)msm.umr.edu Guest
Posted: Sun Aug 12, 2007 11:33 am Post subject: Alternator power wiring, alternator whine |
Listers with flying RV-10s,
I'd like some feedback on how you wired your alternator, and how that's
working out.
- Van's wiring kit calls for #8 wire from the alternator to the 60 amp
alternator breaker on the bus.
- Both Aeroelectric Bob and the Blue Mountain guys advocate running the
alternator output directly to the battery, and then wire from there to
the bus (to allow the battery to absorb as much of the alternator ripple
as possible). On my RV-6A I wired the alternator output to the bus (#6
wire), and I do get alternator whine on the audio.
- If I follow the Aeroelectric guidance and use #8 wire I'll see a .71
volt drop between the alternator and the battery at 60 amps. With #6
wire I'd see a drop of .45 volts.
Questions:
1. What approach did you take for connecting your alternator to the
rest of the electrical system?
2. Do you hear any alternator whine when you are running a heavy
electrical load?
Tim Lewis
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 900 hrs
RV-10 #40059 under construction
Tim Olson
Posted: Sun Aug 12, 2007 11:54 am Post subject: Alternator power wiring, alternator whine |
Tim,
I don't think #8 wire is a big drawback on the -10. I think I
might have wired for 6 if I remember right, but in practice
I'm only drawing a max of about 42A, so #8 would have been
fine.
I wired my alternator through an ANL fuse, then to the starter
contactor which had the wire attached that goes back to
the battery also. So, my alternator is *basically* feeding
direct to the battery, but I tapped off that spot to feed my main
bus also. You're tapping off a pretty large wire, so there
really isn't a significant difference in where you tap into
it. I used #2 welding cable for the battery run.
I hear no alternator whine...period.
working out.
Questions: 1. What approach did you take for connecting your alternator
to the rest of the electrical system?
electrical load?
Tim Lewis
Kellym
Posted: Sun Aug 12, 2007 2:39 pm Post subject: Alternator power wiring, alternator whine |
Hmmm,
Relatively standard practice in production aircraft is to run large wire
from master relay at battery up left side to starter relay on firewall,
and connect from there to buss. Alternator connects to voltage regulator
to buss. So battery is connected via master relay to the buss and
through the buss to the alternator.
that's working out.
the alternator output directly to the battery, and then wire from
there to the bus (to allow the battery to absorb as much of the
alternator ripple as possible). On my RV-6A I wired the alternator
output to the bus (#6 wire), and I do get alternator whine on the audio.
alternator to the rest of the electrical system?
electrical load?
Tim Lewis
KCHD |
GenGrumpy(at)aol.com Guest
Posted: Sun Aug 12, 2007 4:24 pm Post subject: Alternator power wiring, alternator whine |
I have whine off of my main 60a alternator.
Have installeed a Lone Star alternator noise filter, but it hasn't helped me much, so if anyone out there has a good idea on noise suppression, I'd appreciate it also.
My problem has been there from day one, and just got worse the last couple of flights, so I replaced the previous Lone Star filter.....but that didn't help.
Grumpy
N184JM
60+ hours
In a message dated 8/12/2007 2:55:57 PM Central Standard Time, Tim(at)MyRV10.com writes:
Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Tim,
fine.
Tim Lewis wrote:
Quote: | --> RV10-List message posted by: Tim Lewis <Tim_Lewis(at)msm.umr.edu>
working out.
electrical load?
Tim Lewis |
dlm46007(at)cox.net Guest
Posted: Sun Aug 12, 2007 5:43 pm Post subject: Alternator power wiring, alternator whine |
Agree. I ran #2 from the primary battery and between the primary and
secondary batteries. There are two master relays connected to grounding
toggle circuit breakers on the panel. The hot side of the starter relay has
a #8 wire running to the primary bus. The alternator #8 B+ runs to a bar
connecting two 30A pull-able breakers on the primary bus. The field toggle
breaker on the primary bus controls the output of the alternator.
ricksked(at)embarqmail.co Guest
Posted: Sun Aug 12, 2007 7:41 pm Post subject: Alternator power wiring, alternator whine |
The only time my alternator whines is if I make it take out the trash...sorry, haven't spun mine up yet.
Grumpy...you using Accuracy's power grid? The alternator feeds the system through that grid and not directly back via a dedicated feed, I installed mine yesterday and have some chin scratching about if I want to do it (alternator) Tony's way or not.
Rick S.
40185
ericparlow(at)hotmail.com Guest
Posted: Mon Aug 13, 2007 11:03 am Post subject: Alternator power wiring, alternator whine |
Tim,
Here's my power system, it's a variation on the Aeroelectric Z14-FADEC.
http://www.aeroelectric.com/Reference_Docs/Misc_PDF/
I have two Concord 28V 17 amp-hr batteries in the rear. (single pilot W&B
needs some rear ballast anyway).
Each has its own contactor, also in the rear near the battery.
They are connected by a cross-feed contactor.
I ran a single #2 welding cable in the tunnel from the rear cross-feed
contactor & "A" battery contactor output to a firewall bulkhead.
At the bulkhead is an isolated 3/8" stud passing thru the firewall on the
left side.
The feed from the cross-over/"A" battery and the main "A" bus behind the
panel attach to the stud on the inside.
The starter contactor and the main "A" alternator (B&C L-60) connect on the
firewall side of the stud.
A second "B" alternator (B&C SD20) connects directly to the output side of
the "B" battery contactor with a mid-wire junction to a "B" main bus behind
the panel.
Each alternator is controlled by a B&C controller (LS-1A)
Each battery contactor and alternator is switched by a three position switch
"OFF/Batt-A/Batt-A & Alt-A" and "OFF/Batt-B/Batt-B & Alt-B"
The contactor has its own three position switch and can be powered by either
battery.
"OFF/X-FEED/START"
I also ran a single #2 welding cable from the ground on both batteries to a
stud on the right side of the firewall.
All the FWF ground and the panel ground bus connect to this single stud.
A second ground using a #10 wire is connected directly from the batteries to
the ground bus.
This is to avoid the single point failure of the main #2 ground lead
connections.
In addition to the #2 main power feed I have two #10 wires direct from each
battery to a switch then to a "A" & "B" engine bus behind the panel.
There is a 40 amp current limiter (B&C C903-1 w/ C905-40) on each wire at
the batteries.
These power the Electronic Engine A & B side and a few essential items and
act as the typical Right mag/Left mag switches.
The power is distributed thru 4 fuse blocks (B&C FH-6 & FH-12) with
appropriately sized fuses.
Five switches in a row control all the power and starting.
Left to Right: "A" Main/Alt, "A" Engine, X-Feed/Start, "B" Engine, "B"
Main/Alt
Questions?
ERic-
RV-10, 40014
N104EP
Posted: Mon Aug 13, 2007 2:11 pm Post subject: Alternator power wiring, alternator whine |
Eric,
You win the "Let's confuse the crap outta everyone using words instead of a schematic" contest.
So your running 24 VDC system? Almost went that way if only for electric AC.
Rick S.
40185
finishing
Posted: Mon Aug 13, 2007 2:46 pm Post subject: Alternator power wiring, alternator whine |
Eric,
Thanks for taking the time to write up your system description. I'm
going over the data in the link you provided right now.
tim
Eric Parlow wrote:
Quote: |
Tim,
W&B needs some rear ballast anyway).
the left side.
the panel attach to the stud on the inside.
on the firewall side of the stud.
side of the "B" battery contactor with a mid-wire junction to a "B"
main bus behind the panel.
switch
either battery.
"OFF/X-FEED/START"
to a stud on the right side of the firewall.
batteries to the ground bus.
connections.
each battery to a switch then to a "A" & "B" engine bus behind the panel.
at the batteries.
and act as the typical Right mag/Left mag switches.
Main/Alt
Questions?
ERic-
RV-10, 40014
N104EP
