Ray.R.Doerr(at)sprint.com Guest
Posted: Thu Aug 09, 2007 5:17 am Post subject: Troubleshooting a MAG drop. |
Guys, I just wanted to share my recent experience of trouble shooting a MAG drop I was having on my RV-10.
I was flying back from my Canada trip and finished the first two legs without any issue. On my final leg I did the usual engine run-up to 1900 RPM and checked the MAG's. Right side dropped the usual 60-80 RPM while the Left dropped 120 RPM and the engine started to run rough. I leaned the crap out of it on the ground and it got a little better, so I decided to fly the last leg anyway. When I got back on the ground after running it for 2 hours LOP, I checked the MAG's before shutdown, and it was still dropping and running rough on the Left MAG.
My friend, Brian Reiter came over and we pulled/cleaned/gapped the plugs because we were heading to Oshkosh the next day in the RV10. We also swapped the top plugs to the bottom and the bottom to the top. My plugs are all Unison UREM38E. The plugs did not look bad at all. After doing all of this, the MAG drop issue was gone. We flew to Osh, had a great time, and flew back and no problems with MAG drops. Then after putting another 3 hours on the plane, the MAG drops started on the Right MAG (notice before it was the Left MAG, but now the plugs were switched top for bottom). Now I started asking questions and tracing the MAG wires to the Plugs and this is what I learned.
Right MAG runs the Top Plugs for Cylinder #1, 3, 5 and the Bottom Plugs for Cylinder #2, 4, 6.
Left MAG runs the Top Plugs of Cylinder #2, 4, 6 and the Bottom Plugs for Cylinder #1, 3, 5.
With this info, I knew which ones to start looking at. I had just cleaned all the top plugs again, since originally I thought the Right MAG ran all the Top Plugs (NOT), and they were all spotless. Then since the Right MAG also ran the Bottom plugs of Cylinder #2, 4, 6, I cleaned them again (in an ultrasonic bath) and they were spotless, the gap was fine. I re-installed the plugs with new copper washers and the Right MAG was still dropping 120 RPM and running rough. Time to go home for the day.
The next evening, I thought why not start the engine, then immediately switch to the right MAG and watch the Temps on Dynon Engine Monitor to see which cylinder isn't firing. This was the trick, by starting the engine and immediately switching to the bad MAG, it didn't let the EGT's get very hot while the key-switch was on BOTH after starting. Now I observed the EGT of 5 of the cylinders were at 1200 degrees and climbing while my number #2 Cylinder was at 600 degrees and dropping (because this Clyinder was not firing when only on one MAG).
Now that I knew #2 Bottom Plug was bad (285 hours on it), I change it out and my problem was resolved. I then went back and looked at the plug again, and most people I showed it to couldn't see anything wrong with it, but the porclin insulator inside the plug had a black residue (about the size of a pencil eraser end) on the wall about half way down. This plug was arcing across from the spring to the outer shell through the insulator instead of at the tip of the plug.
I learned a lot during all of this, like which MAG runs what Plugs and that having an Engine Monitor on all Cylinders for CHT and EGT is an awesome troubleshooting tool as well. Anyway I thought I would share this with others that may not have grown up with these Engines either.
Thank You
Ray Doerr
40250
N519RV (Hobbs 95)
marc(at)kitplanes.com Guest
Posted: Thu Aug 09, 2007 6:33 am Post subject: Troubleshooting a MAG drop. |
Great post. In fact, I don't really watch the actual mag drop in rpm
anymore, but instead just look for each cylinder's EGT to rise during
one-mag operation. That tells me 98% of what I want to know.
--Marc
On Aug 9, 2007, at 6:16 AM, Doerr, Ray R [NTK] wrote:
Quote: |
<Ray.R.Doerr(at)sprint.com>
[snip]
tip of the plug.
Engines either.
Thank You
Ray Doerr
40250
N519RV (Hobbs 95)
n212pj(at)gmail.com Guest
Posted: Thu Aug 09, 2007 7:23 am Post subject: Troubleshooting a MAG drop. |
Nice post, Ray, and nice sleuthing.
John J #40328
Deems Davis
Posted: Thu Aug 09, 2007 7:46 am Post subject: Troubleshooting a MAG drop. |
I love hearing about these type of events! THANKS for taking the time to
post this. For me it was very educational and well within the context
and framework of what I've come to hope for and expect from the RV10
community. GOOD Job !. For most of us still building, the events that
can/will occur when flying are still unknown, and tips and experience
like this related goes a long way to keeping the 'fleet' healthy.
Deems Davis
#406
:"it;s all done.... just not put together yet!"
of keeping us a
Thank You
Ray Doerr
40250
N519RV (Hobbs 95)
LloydDR(at)wernerco.com Guest
Posted: Thu Aug 09, 2007 8:39 am Post subject: Troubleshooting a MAG drop. |
Ray
Great write up and outstanding technical troubleshooting. These types of
stories should be collected and archived so that we all can learn from
each others experiences. I have heard many people having this same
problem and spending large amounts of money to get it corrected. Nice,
easy and well thought out solution.
THX for sharing
Dan
N289DT RV10E Flying
Tim Olson
Posted: Thu Aug 09, 2007 9:25 am Post subject: Troubleshooting a MAG drop. |
Awesome that you took the time to write that up Ray, you did just great
on your troubleshooting.
What I've learned over the past years is that the RPM drop is usually
(not always) pretty irrelevant to the run-up, but more importantly
that you're getting near normal RPM's, and that it runs smooth, and
especially that you don't see any cylinders dropping in EGT with the
mag off.
You're absolutely correct that on a 2-mag system the system is wired
so that the plugs are split top and bottom across the mags, so it isn't
as simple as Right mag on top, Left on bottom, or vice versa...it's all
mixed up as you listed below. But, for those of us who have Lightspeed
ignitions, normally we're set up so that the top plugs are the
automotive plugs, and those are run by the Right mag (which is actually
the LSE), so the Left mag runs all the bottom plugs. It's perhaps
a simpler layout, but either should be easy to troubleshoot.
Your plug failure was one of those fairly rare occurances, but proves
that you must inspect the entire plug. It would be interesting to
hear if you've ever dropped the plug, because I've heard that if you
drop an aviation plug, you are best off just throwing it away. (not
insinuating that you did, just illustrating how important it is for
everyone to be careful with your plugs) The most common failure I've
seen (not on my RV-10) is to see a pile of crusty lava looking gunk
in the lower plugs, down at the base of the insulator. All that
fouling eventually piles up until it shorts or runs bad. It should
be fully cleaned out perhaps every 50-100 hours when you yank the
plugs. (Tip: Buy the el-cheapo Harbor freight spark plug bead-blasting
cleaner and it works great after you chip some of the stuff manually)
My most recent troubleshooting was when a nice young lady (it's
always nice to help those. ) came to our airport and after
parking all day, had a rough running engine. Nobody was around
at the FBO to help, and she got on the cell phone (constantly) to
call the people back at her flying club or FBO for advice.
I told her I could help troubleshoot the glass-cockpit equipped
piper and bet we could find the problem quickly. All I had to
do was have her run it up and do a mag drop. When she selected
one of the mags, the EGT on one cylinder dropped way down to
nothing....ah ha, then you know the plug and the mag, right away.
Although those on the phone were unsure they should trust
a goofy looking chubby bald guy with their plane, she let me
pull the plug and we found just a tiny salt-grain sized piece
of stuff between the center and side electrodes. I cleaned the
plug thoroughly, put on a new gasket and anti-seize, and it
was installed and running great in minutes and she and the
club was very greatful when she arrived safely home.
The moral of the story is, we have a HUGE benefit over our
normal certificated brothers in that we can install some of
the nicest engine monitoring equipment around, that would cost
a lot for them to install. Using that equipment makes
troubleshooting such problems a breeze. Also, in reading a
recent article about TAA (Technically Advanced Aircraft) it was
stated that one area where TAA's have virtually dropped a common
problem out of existence is fuel starvation problems, all because
of the fuel totalizer and integrated flight range displays.
Anyway, sorry for being long, but you did a great job identifying
the issues and opened the door to educating a lot of people,
so that's a great story for you to share.
PS: Always carry a spare plug (I carry one of each type).
Thank You
Ray Doerr
40250
N519RV (Hobbs 95)
Posted: Thu Aug 09, 2007 11:44 am Post subject: Troubleshooting a MAG drop. |
This is a common failure mode for plugs that got dropped. I got some
advice on what to do with dropped plugs. If you drop a plug, pick it up
and drop it again ...... real hard ...... and then trash it. Don't
re-use a plug that's been dropped. I don't anymore.
Linn
Quote: |
--> <Ray.R.Doerr(at)sprint.com>
what I learned.
Thank You
Ray Doerr
40250
N519RV (Hobbs 95)
Dick Sipp
Posted: Thu Aug 09, 2007 7:44 pm Post subject: Troubleshooting a MAG drop. |
Good job Ray,
On the old RV-4, my standard practice was to switch the engine monitor to
the expanded/normalized EGT mode for the runup and mag check. Normal
indication on ether single mag by itself would be a relatively uniform rise
in all EGTs due to slower combustion process with one ignition source. Any
abnormal cylinder becomes readily apparent.
With a single electronic ignition, the change will not be as dramatic but
should still register.
Dick Sipp
RV10 N110DV
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Fri Aug 10, 2007 8:07 am Post subject: Troubleshooting a MAG drop. |
Very nice write-up. Thanks.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
AV8ORJWC
Posted: Fri Aug 10, 2007 8:52 am Post subject: Troubleshooting a MAG drop. |
Excellent post on the problem, troubleshooting and eventual solution.
Everyone should remember the little ditty from Champion at OSH and that
I first learned in A&P school. "Drop it Once, Drop it twice!" The
second time into the trash.
These plugs are expensive and there is a desire to shrug off the slight
shock which can contribute to a cracked insulator. Your's was probably
not from handling, installation or shipping, just bad luck.
The second point is that the copper crush rings should be installed New
each time. Being cheap, many mechanics will recycle them which Champion
says creates a 0.004" movement of the plug deeper into the combustion
chamber. Cracked heads are more expensive than the crush rings.
Fly Often, Fly Safe, Live Long
ddddsp1(at)juno.com Guest
Posted: Fri Aug 10, 2007 11:14 am Post subject: Troubleshooting a MAG drop. |
John,
I have a question on the copper washers for the plugs...............an ole A&P told me you can clean them, heat them up, and reuse them? Any truth to that? I know it is best to replace them as they cost very little. .......for airplane parts!
DEAN
/2-2125045-32">Get Juno DSL - the easier, safer broadband!
AV8ORJWC
Posted: Fri Aug 10, 2007 1:18 pm Post subject: Troubleshooting a MAG drop. |
One of my oldest IA buddies would always collect them and then anneal them (In mass) so they became more supple and malleable. I was taught to discard and use new. They are not unreasonably expensive when purchased in quantities of 100.
The Champion sparkplug seminar confirmed the annealing process but countered that each time they are compressed they not only harden (reason for annealing), but they flatten out – never to retain the original “build height”. With higher performance engines (you be the judge) the reuse of pre-used copper crush rings were allowing the plug to extend into the combustion cylinder and hinder the event. Results ranges from Detonation to cracked heads radiating from the sparkplug hole.
On lower compression engines I have seen widespread use of the annealing process and yes, I do collect the discarded ones.
Another important technique is to use the correct tools to adjust the gap. Use the wrong tool and you will crack the insulator.
Just repeating what they showed at the Champion OSH seminar.
I will always use “New” with my paying customers and as an EAA Tech, I can only share information for mass distribution that is not my typical wild A%% speculation. Kelly, help me out here….
John Cox
EAA #5242
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com
Sent: Friday, August 10, 2007 12:12 PM
Subject: RE: RV10-List: Troubleshooting a MAG drop.
John,
DEAN
/2-2125045-32">Get Juno DSL - the easier, safer broadband! [quote] [b]
Posted: Fri Aug 10, 2007 6:49 pm Post subject: Troubleshooting a MAG drop. |
Maybe I'm wrong, but I have never replaced mine..... in my Cherokee for 5 years and in my RV-4 for 5 years..... Just clean them off and re-torque the plugs. Never seen an exhaust leak around them....
Your mileage may vary, maybe I've just been lucky...
-Mike
apilot2(at)gmail.com Guest
Posted: Fri Aug 10, 2007 7:23 pm Post subject: Troubleshooting a MAG drop. |
Wellllll, for a long time annealing was a time honored chance to play with
your torch, make things glow cherry red and warm things up a bit in a cold
hangar. However, today, copper scrap is worth so much you maybe get more for
selling them than reusing.
I personally doubt there is any significant flattening of the washers unless
you use the upper limit of the torque spec and like using your breaker bar
with cheater to see whether you can get the helicoil out with the plugs or
not. Personally, I don't care what TCM and Lyc say...I'm not going over 25
ft.lbs on a plug, period. It is plenty, still takes a lot of force to remove
the plug, etc.
What I do see is the washers dishing a bit...so put the concave side toward
the cylinder to reverse that. Nary a problem doing it that way for 32 years
