Rudder wiring?
rv9jim(at)juno.com
PostPosted: Tue Aug 07, 2007 12:05 pm    Post subject: Rudder wiring? Reply with quote
I am about to wire the tail light/strobe on the bottom of the rudder.
What is the best direction to run the wires out of the rudder and into
the back of the fuselage. I am inclined to run it out the bottom of the
rudder (maybe 1/2" up) and upward a bit (about 2-1/2") and then into the
back of the fuselage. This will allow for the twisting of the wires
during the usage of the rudder and minimize the stress on the wires in
between the vertical stabilizer and the rudder. Or should I run a loop
going upward and then back down and into the rudder and fuselage.
/\ staying away from the bottom rod end. I can also cover the
wire with the
__/ \__
spiral wrap to protect the cable from abrasion. Any help would be
appreciated.
Jim
RV9-A
N15JN
wgill10(at)comcast.net
PostPosted: Tue Aug 07, 2007 1:53 pm    Post subject: Rudder wiring? Reply with quote
Hello Jim,
Attached are photos of how I accomplished this task -- not the
prettiest, but effective. The slot on the rudder butt allows the wires
to stay put without bending stresses when the rudder is exercised. There
is about 3 layers of heat shrink protection over the wires should
excessive rubbing occur, which I will monitor. In a "static" condition,
there is little if any contact with the wires.
Bill Gill
RV-7 FWF & finishing
Lee's Summit, Missouri
 Filesize:  204.77 KB
 Viewed:  351 Time(s)
 Filesize:  219.64 KB
 Viewed:  374 Time(s)
webmaster(at)flion.com
PostPosted: Tue Aug 07, 2007 8:18 pm    Post subject: Rudder wiring? Reply with quote
I was going to put a connector there, until I realized that it would just be
a flex point. I ended up drilling an opening between the tie-down mount and
the bottom hinge and using a grommet. The wire continues down into the
bottom fairing and there's a fair service loop so I can make the attachment
to the Whelen assembly outside the rear of the mount. Once in place,
there's little movement of the wire at the front of the rudder. I still
intend to install some rubber material, left over from the fairings below
the horizontal stabilizer, into the opening in the rudder leading edge. The
idea another person had of using heat-shrink tubing as anti-chafe protection
is excellent; you could also use some of the nylon woven tubing used in
bundling wires and hold it in place with a little heat-shrink. I don't
think the nylon would wear through and it would look very custom.
Patrick Kelley - RV-6A - still waiting on panel
(Aerotronics is nearly done, ahead of schedule, and it looks great!)
Mark Phillips in TN
PostPosted: Tue Aug 07, 2007 10:32 pm    Post subject: Rudder wiring? Reply with quote
In a message dated 8/7/2007 3:07:49 PM Central Daylight Time, rv9jim(at)juno.com writes:
May not be the best, but this has worked well for almost 450 hours for me so far...
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5415
Mark Phillips
From The PossumWorks...
rv9jim(at)juno.com
PostPosted: Wed Aug 08, 2007 5:10 am    Post subject: Rudder wiring? Reply with quote
Hi Mark,
Did you run the cable into the rudder by expanding the opening
for the bottom rod end? Thus letting the cable just "drop" into the
lower area or did you use a grommet in the rudder to get it into the
lower area?
Jim Nelson
Mark Phillips in TN
PostPosted: Wed Aug 08, 2007 9:08 pm    Post subject: Rudder wiring? Reply with quote
In a message dated 8/8/2007 8:12:31 AM Central Daylight Time, rv9jim(at)juno.com writes:
lower area?
Hi Jim-
The wiring exits the fuse through a grommet in the VS spar. I cut a slot side to side in the rudder bottom that the wires pass through just wide enough to clear them when the rudder moves to each stop. There is maybe 1/2" of glass between the top of the slot to the opening for the lower rod end cutout. The wires just drop down into the rudder bottom and go aft with enough extra length for a "service loop" to allow the strobe/taillight to be removed to expose the wires for disconnection via an AMP connector on a short pigtail from it.
Feel free to contact me off-list if ya'd like a better description...
Mark
