jfitzsy(at)stny.rr.com Guest
Posted: Wed Aug 08, 2007 12:38 pm Post subject: Gonna be |
All pts. well taken, WOW. OK ,I've got a friend who has a Knight -- its a trainer. Not completely. Some parts missin. He let me run it up an dwn his strip a few times. He has a friend who is a Pilot and has trainer cridentials. Who said would help. Agree would not want to be a statistic or contribute a bad name to the sport. Have been interested in this long enough to have spent considerable time reading Flyin inst. books. Also have spent some time talkin with this fellah. I guess you'd call it ground trainin. So, other than takin flight lessons - which would be cost prohibitive- I'm doin the best I can. Had a ride in the Knight - back seat of course. And the other day, had the Kolb runnin and taxied it up ah dwn a strip there- tryin to get the feel of its controls. Did'nt know it had heel peddals for braking - rudder worked for turnin but do'nt slow ya dwn. Figured out the heel peddals after that.
Went to aircraft spruce and found good pins and keeper clips -- thanks all.
Guess the planes coming with a book and pilots log so info on oil mix and such are probably there. Still not sure what mix oil to use as you fellas seem to be at odds on that subject. Thanks fer yer responses and concerns. Oh and the Iife ins. response --- gotch ya.
Posted: Wed Aug 08, 2007 1:26 pm Post subject: Gonna be |
James
One more time. I'm trying to help. The FAA has a open window were you can get your plane registered. It's available till 12/31/07 after that you don't have a chance to get it registered. There might be something but it would very difficult. Unregistered it will be illegal and worth much less not registered your choice. Check the Kolb-list(at)matronics.com (Kolb-list(at)matronics.com) archives on Light Sort and LSA registration.
What is a Knight? Is it going to fly like a Kolb? We can't force you to get proper training but nothing less than light sport training as part of the Light Sport license program will be legal for that airplane. Get caught and you will be charged flying without a license and flying a unregistered airplane. Get killed flying illegal and your life insurance policy may be void. The Light Sport license is fairly easy and inexpensive to get. It is still allot of work and beyond some people but one heck of allot easer and less expensive than the private license I had to get at the time.
Rick Neilsen
Redrive VW powered MKIIIC
jlsk1(at)frontiernet.net Guest
Posted: Wed Aug 08, 2007 2:31 pm Post subject: Gonna be |
If taking Flying lessons is cost prohibitive, sell the plane. Coming from a CFII, there is too much to learn about safely flying a Kolb, or any other airplane, in the time you have left after you go to full throttle the 1st time, despite everything you have read about flying.
We don`t even know you & we are trying to help you> : ) Jim
a58r(at)verizon.net Guest
Posted: Wed Aug 08, 2007 2:59 pm Post subject: Gonna be |
In the hope that by just mentioning this, it wont be tried. I'm not in favor of the old self-teaching method of "crow-hopping." I say this because it frequently comes up. The sometimes fatal outcome of crow-hopping comes when the learner, doing a little fast taxiing, gets light on the tires, then a foot up, and a sudden gust or movement of the stick, and wheeee, yer up 50 ft and don't really know how to get down. Panic closes the throttle, pulls the nose up, and it's Lawn Dart City. And, No, I haven't done it!
regards,
Bob N. FireFly 070 Old Kolb
Posted: Wed Aug 08, 2007 3:23 pm Post subject: Gonna be |
OK Rick, Got my attn. LSA reg's must be posted at their web site. The Knight is also an UL some diffs. Are you sayin to find specific Kolb trainin. And if so how would I go about findin that.
Hav'nt seen any new regs at their site. ?Thought I read everythin there???????/
worrybear(at)verizon.net Guest
Posted: Wed Aug 08, 2007 4:24 pm Post subject: Gonna be |
Welcome to the list. Where are you located? There may be someone on the list close to you who would be willing to help. The Cayuna uses a 50 to 1 mix.
We also have a feature on the list that keeps the archives from becoming too cluttered to search, so if you feel that a post does not need to be kept for ever you just type in (do not archive).
Dan Walter
Ultrastar, UL202
Palmyra, PA.
Thom Riddle
Posted: Wed Aug 08, 2007 4:57 pm Post subject: Re: Gonna be |
James,
As you should be able to tell from the responses you are getting, we Kolbers care about each other and you. TELL US WHERE YOU ARE LOCATED, so perhaps we can get you in touch with a Kolber near you to help you through this process.
Registering you airplane must be started very soon to meet the deadline because there are several steps including getting the registration number and getting it inspected for airworthiness. One way to do this is to order from EAA their E-LSA registration information kit which outlines all the steps required to make your Kolb legal.
Do NOT try to fly your Kolb without proper instruction.
I've been flying for over 40 years since I got my private certificate. I've flown dozens of different airplanes and NONE of them fly like any other. In fact I'm now on my second early model Kolb Firestar and its flight characteristics are markedly different from the first one I had. I built neither of these. These are EXPERIMENTAL AIRCRAFT built by individuals in their garages. Every builder does something different from the plans which are sometimes sketchy leaving a lot to the imagination of the builder. Some builders have some pretty wild imaginations and make modifications that are really dangerous.
Since you are not an experienced pilot, and I assume not an aircraft mechanic, how in the world do you know if it is a safe flying machine? If you've seen it fly, great, but that does not mean it is safe to fly. Do you know how to do a proper weight and balance calculation and why your life could depend upon it? Do you know if the wire ropes in the Kolb have properly swaged fittings? Do you know what to do if you get carburetor ice? Do you know what carburetor ice is and how to detect it? Do you know what a stall is? Do you know what causes a spin? Do you know to recover from a spin? Do you know what aileron flutter is? Do you know what adverse yaw is and how to correct for it?
I'm not asking these questions to make you feel stupid. But you are ignorant. We all began totally ignorant of the things we MUST know to fly safely. Not a single pilot was born with this knowledge. We all learned it over time. And it does take time but not as long as you might think to get to the point that you can fly in relative safety.
Please take the time required to learn to fly safely. If you do, you will have embarked upon an avocation that will reward you in ways that you cannot even begin to imagine. If you try to take shortcuts there is a good chance you will be dead before year end.
On average one pilot in the USA dies every day in their airplanes. Most of these are in Certificated Standard Category Aircraft built buy factories approved by the FAA, flown by very experienced pilots and the airplanes are maintained by FAA approved Airframe and Powerplant Mechanics. Approximately 80% of these are caused by some form of pilot error or poor judgment.
The ultimate in poor judgment is the decision to teach yourself to fly. Don't do it.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
jindoguy(at)gmail.com Guest
Posted: Wed Aug 08, 2007 6:01 pm Post subject: Gonna be |
James, There is an old adage you might wish to contemplate. Gallows humor, but true nonetheless.
"Aviation is like a self cleaning oven."
Rick
On 8/8/07, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:[quote] --> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
James,
Thom in Buffalo
N197BG FS1/447
"Blind respect for authority is the greatest enemy of truth."
Albert Einstein
http://forums.matronics.com/viewtopic.php?p=128192#128192
Richard Pike
Posted: Wed Aug 08, 2007 7:12 pm Post subject: Gonna be |
James, all the comments I have read so far are dead on the money, but let me add something a bit different - Kolbs are great flying airplanes, I love mine and promote Kolbs, but so far, the only one I have flown that would fly hands off was a Firestar II with bunches of dihedral. My MKIII will not fly hands off even with all the dihedral I could wedge into it. (So I put it back stock. Why look odd if it doesn't help anything?)
When I first met John Hauck, within the first three minutes he told me that a Kolb would not fly hands off, and that is true.
Think about that very carefully.
Some of the guys on the list might call this heresy, but a standard Kolb WILL NOT FLY hands off. It will figure out a way to depart from straight and level flight. Do you really want to learn to fly in such a device?
Stock, it is a neutral stability airplane. Which make it delightful to fly, but probably the world's worst choice to teach yourself to fly in. Learn to fly first, get good at it, and then fly the Kolb, and you will love it. Try to teach yourself to fly in it, and you will scream at it. But probably not for long.
End of sermon.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
