Scratchbuilders - Leading Edge Skin Vacuum Forming
sky_ranger161
PostPosted: Mon Aug 06, 2007 5:32 am    Post subject: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Hi all,
I'm also a member of the Sonex builders list and recently there's been some activity about a really cool vacuum-forming technique for bending leading edge skins. This technique may be familiar to some, but just having just completed my wing nose skins, I found myself asking the question - "Is there not a better way to do this?" This looks like a good way to bend just about any skin you need to bend, but especially good for doing the 12-foot wing nose skins.
I have not used this technique myself. I'm only including a link because I think it's a great "thinking outside the box" idea that may help someone else in the Zenith community. Of course you'll need to adjust the bend radius to suit your needs and do your own experimenting, but here's the link to the 3-part series on YouTube. Enjoy.
http://www.youtube.com/watch?v=yqzToYQ765w
Debo Cox
XL/Corvair Scratchbuilder
Nags Head, NC
Wings in progress
Go ahead and archive this one
n4546v(at)mindspring.com
PostPosted: Mon Aug 06, 2007 7:31 am    Post subject: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Listers:
I successfully bent most of my empennage skins by vacuum forming and
wrote a posting to the list about the experience. It's accessable from the
archives by using my name or "vacuum forming" as search words. Message number 10043. The
statement below is "material ruining " accurate. I describe in my post how
to overcome it.
Randy L. Thwing, Las Vegas, NV do not archive
it's very easy to overbend the skin because the shop vac will pull
the air out of the gap much quicker than what you think.
leinad
PostPosted: Tue Aug 07, 2007 3:19 pm    Post subject: Re: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Debo,
Thanks for posting this link. I'm really psyched about bending my nose skins now. I've got this task coming up and I was rather apprehensive. I'd come up with a number of inferior methods and am so glad you posted the yootube link when you did. I only wish I had know about back when I did the stabelizer.
Thanks again!
Dan Dempsey (do not archive)
    Debo Cox
    Nags Head, NC
paulrod36(at)msn.com
PostPosted: Sun Aug 12, 2007 10:35 am    Post subject: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> For some reason, Youtube and I don't get along There is a systwem flaw between the keyboard and the chair. Could someone who's seen the video give a brief verbal rundown on how they do it? Thankya, thankya ver'much.
Paul Rodriguez
601XL/Corvair
larry(at)macsmachine.com
PostPosted: Sun Aug 12, 2007 11:07 am    Post subject: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Hi Paul,
The U-Tube nose skin bending routine starts by placing a 4-mil plastic
on the worktable.
Then the skin is placed at center of the plastic with excess plastic all
around. A piece of pipe longer than the skin is placed exactly at the
center of bend. The pipe is screwed to the table with brackets to secure
position. Edges of the skin are lifted and taped edge to edge and
progressively shortened to bring the skin to a “canoe” shape. The
plastic is pulled up around the skin and taped to seal the overlapping
edges. The ends are closed and a vacuum is used at one end to suck out
the air and bring the sides together. The amazing part is the ability of
the vacuum to pull the skin tightly around the pipes diameter. The
vacuum is held for a few seconds and then everything is reversed
allowing the skins to spread slowly and the tapes are removed. The bend
makes a 70-degree or so angle between the skins and does a remarkable
job of uniform bending.
I did a larger radius type press arrangement, but for the thinner wing
of the XL, this is just the ticket. One could do a piece just 36-inches
long to sample the process and get the radius right.
Paul Rodriguez
601XL/Corvair
Carlos Sa
PostPosted: Sun Aug 12, 2007 11:39 am    Post subject: Re: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Paul, see images attached - I am posting on the forum so it won't bother regular email subscribers.
Part 2 follows, as only 10 attachments are allowed...
Carlos
CH601-HD, plans
 Filesize:  20.83 KB
 Viewed:  787 Time(s)
 Filesize:  21.54 KB
 Viewed:  803 Time(s)
 Filesize:  21.53 KB
 Viewed:  889 Time(s)
 Filesize:  21.51 KB
 Viewed:  807 Time(s)
 Filesize:  21.69 KB
 Viewed:  825 Time(s)
 Filesize:  8.84 KB
 Viewed:  816 Time(s)
 Filesize:  19.65 KB
 Viewed:  842 Time(s)
 Filesize:  20.47 KB
 Viewed:  839 Time(s)
 Filesize:  20.76 KB
 Viewed:  783 Time(s)
 Filesize:  21.6 KB
 Viewed:  857 Time(s)
CH601-HD, plans
Montreal, Canada
Carlos Sa
PostPosted: Sun Aug 12, 2007 11:42 am    Post subject: Re: Scratchbuilders - Leading Edge Skin Vacuum Forming (2) Reply with quote
remainder of the pictures
Carlos
 Filesize:  20.71 KB
 Viewed:  812 Time(s)
 Filesize:  21.15 KB
 Viewed:  752 Time(s)
 Filesize:  12.61 KB
 Viewed:  833 Time(s)
CH601-HD, plans
Montreal, Canada
zodierocket(at)hsfx.ca
PostPosted: Sun Aug 12, 2007 12:15 pm    Post subject: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Gents, David and I spent almost 6 mos trying different processes in which to form the nose skin for our 601’s. We worked on hydraulic systems and vacuume setups and many others. But when it comes right down to it we found a simple, no-cost solution and posted it here on www.ch601.org .
Link is here
http://www.ch601.org/resources/Nose%20Skin/bending_a_nose_skin.htm
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com (president(at)can-zacaviation.com)
www.can-zacaviation.com
Ron Lendon
PostPosted: Sun Aug 12, 2007 6:54 pm    Post subject: Re: Scratchbuilders - Leading Edge Skin Vacuum Forming Reply with quote
Thats the process I used just with a little modification. I didn't need to flip the table over I used 3/4 MDF and bridged it on the table.
Thanks for posting that stuff Mark.
Here is the link to the process used
http://www.mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=27672&row=117
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
