roger.mills(at)btinternet Guest
Posted: Tue Aug 07, 2007 1:47 am Post subject: BATTERY MASTER SWITCHBATTERY MASTER SWITCH |
Rob,
Are you actually using this relay? I suspect it isn't suitable for a DC load (if you look at the laod terminal it says "AC" ). It probably uses a triac as the control element - which depends on the voltage reaching zero to switch off.
Roger Mills
rob(at)hyperion-ef.com Guest
Posted: Thu Aug 09, 2007 1:30 pm Post subject: BATTERY MASTER SWITCHBATTERY MASTER SWITCH |
Roger and Ira:
Thanks for the input. Two “gotchas” have been brought to my attention, fortunately before first flight (which unfortunately is not imminent) . Being an analog guy in a digital world I made the erroneous assumption that solid state relays don’t care about waveform. OOPS. Worse yet, I missed the fact that starter current is just a tad higher than the steady state cruise load. “Lectric Bob’s remotely operated battery switch (9042-100) is looking like a really good device for my purposes.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ROGER MILLS
Sent: Tuesday, August 07, 2007 2:46 AM
Subject: Re: Re: BATTERY MASTER SWITCHBATTERY MASTER SWITCH
Rob,
Roger Mills
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
