pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Fri Aug 03, 2007 7:23 pm Post subject: Andair valves |
You folks that have used the andair fuel valves in your Lightning, can you tell me which model you used?
Also, what fittings did you use?
Jim! [quote][b]
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
mark.stauffer1(at)gmail.c Guest
Posted: Sat Aug 04, 2007 5:29 am Post subject: Andair valves |
Jim,
Consider the FS20x3 and FS20x7. I believe that both Linda Mathais and Joe Cooper used the FS20x7.
Go to their web site http://www.andair.co.uk/system/index.html and you can configure the valve just about any way you like. I suggest that you configure it with either 1/8 NPT or ¼ NPT female fittings on all sides. This way you can use inexpensive brass elbows (90 & 45 with a ¼ barb on the other end) to connect up to the fuel line supplied with the kit. If I had my choice I’d use the 1/8 NPT fitting at least on the inlets because the 1/8 brass elbows are smaller and you’re working with limited space in the center console.
These options weren’t available when working with Joe and Linda’s planes. We had to buy reducers from AN6 fittings to ¼ barbs. It works just fine but is bulky and adds weight.
Hope this helps.
Mark
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Jim Langley
Sent: Friday, August 03, 2007 10:22 PM
To: lightning-list(at)matronics.com
Subject: Andair valves
Jim! Quote: | http://www.matronics.com/Navigator?Lightning-List | 01234
N1BZRich(at)AOL.COM Guest
Posted: Sat Aug 04, 2007 5:50 am Post subject: Andair valves |
I used the new FS20x7 model and think it is the way to go. The difference is it only requires a 90 degree turn from left to right tank, verses a 180 degree turn on the FS20x3. I think I got one of the first ones of these, but had to get it directly from England as they were not yet available in the US at the time. Works great.
Another thought - the practice of using two "ON -OFF" fuel valves leave the possibility of having two tanks on at the same time. OK in a high wing aircraft, but a potential problem in a low wing aircraft. Low wing aircraft should generally not have a both position. Why? If you have both tanks selected on a low wing aircraft and one tank runs dry the engine will likely starve for fuel. Why? Well, which is it easier for the engine fuel pump to "suck" to the engine, air or fuel? You "flame out" with perfectly good fuel on board.
Blue Skies,
Buz
dashvii(at)hotmail.com Guest
Posted: Sat Aug 04, 2007 6:28 am Post subject: Andair valves |
Buz,
I can certainly tell you that I wished that I had that fuel selector. On
one of my Lightning flights I had left both fuel tanks to the open position
and ran for about 3-4 hours, then did a touch and go and rolled onto
crosswind and the engine started to go at 500 feet. Rolled wings level and
it smoothed out, made that my final stop. On the ground I found one tank
dry and one tank nearly completely full, so it really doesn't even burn from
both very evenly if you leave it in that config.
Also, don't you have on that fuel selector something that keeps it from
rotating if you bump it? Like you have to pull out and rotate or push a
button or something? Just thought I remembered that. Brian W.
Reply-To: lightning-list(at)matronics.com
Subject: Re: Andair valves
Date: Sat, 4 Aug 2007 09:49:36 EDT
but
US at
aircraft
selected
"suck" to
board.
Blue Skies,
Buz
http://discover.aol.com/memed/aolcom30tour
See what you’re getting into…before you go there
http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_preview_0507
N1BZRich(at)aol.com Guest
Posted: Sat Aug 04, 2007 8:00 am Post subject: Andair valves |
Hi Brian,
What you are remembering is the pull knob that you must pull to select the off position. When selecting right or left tank you don't need to pull it, but there is a definite detent feel when you are in the correct left or right position.
How are things in Texas? Doing any flying?
Buz
lbmathias(at)verizon.net Guest
Posted: Sat Aug 04, 2007 2:42 pm Post subject: Andair valves |
[quote] Jim,
Mark and Buz' info was right on; one further suggestion: buy it from Aircraft Spruce if you can. We ordered ours from the UK and with the weak dollar, it cost us a lot more than we would have paid in the US.
Linda
pequeajim
Posted: Sat Aug 04, 2007 2:43 pm Post subject: Andair valves |
Thanks guys. That is what I will order.
Jim!
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Mark Stauffer
Sent: Saturday, August 04, 2007 9:24 AM
Subject: RE: Lightning-List: Andair valves
Jim,
Hope this helps.
Mark
Posted: Sat Aug 04, 2007 3:39 pm Post subject: Andair valves |
Buz,
Yes, that was it, so that you didn't accidentally put it in the off
position. Knew I remembered something like that and that would make sense.
I am doing some flying here. Right now I'm working doing aerial photography
part time. I also am biting the bullet finally and am going to finish my
CFI. I already have a job lined up when I finish that. I am lacking about
50 hours multi time to go to the regionals, but will probably do a lot of
dual given and work towards one day doing Southwest Airlines. I know a
couple of SWA pilots here and I do a lot better with their personalities
than airline pilots of other airlines. Instructors get paid really well
here though and there seems to be great demand, and I'm okay with teaching
for a few years to come.
I do have to admit, I am missing going from a sporty performer like the
Lightning to a heavy handed plane like the Arrow, or the Cessna Skychicken.
They're good solid planes and have never let me down, but just don't have
the performance and manueverability like the Lightning. Still, can't
complain too much, it's going to keep me flying for years to come and bring
in a little money too! Thanks for asking, Brian W.
Date: Sat, 4 Aug 2007 11:49:57 EDT
Hi Brian,
right position.
Buz
Messenger Café — open for fun 24/7. Hot games, cool activities served daily.
Visit now. http://cafemessenger.com?ocid=TXT_TAGHM_AugHMtagline
pequeajim
Posted: Sat Aug 04, 2007 5:33 pm Post subject: Andair valves |
Buz:
What size fittings and type, (male/female) did you put in?
I like the idea of female on the valve.
Jim!
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Saturday, August 04, 2007 9:50 AM
Subject: Re: Lightning-List: Andair valves
Blue Skies,
Buz
href="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-List
Posted: Mon Aug 06, 2007 12:21 pm Post subject: Andair valves |
In a message dated 8/4/2007 9:34:21 P.M. Eastern Daylight Time, pequeajim(at)gmail.com writes:
Quote: |
What size fittings and type, (male/female) did you put in? |
Jim.
I have racked my brain, and just can't remember right now. I will have to look through my many photo files to see it I have one that shows. But my suggestion would be to go with what Mark mentioned in his answer. They are the guys that work with this kind of thing all the time.
Blue Skies,
Buz
pequeajim
Posted: Mon Aug 06, 2007 7:01 pm Post subject: Andair valves |
Mark:
Will the 1/8 NPT fittings still allow enough fuel flow?
Linda; do you remember what size fittings are on your selector valve?
Jim!
Jim,
Hope this helps.
Mark
pequeajim
Posted: Mon Aug 06, 2007 7:02 pm Post subject: Andair valves |
Sorry, scratch that last question to Linda. Mark you had already answered it.
Jim!
Jim,
Hope this helps.
Mark
pequeajim
Posted: Mon Aug 06, 2007 7:53 pm Post subject: Andair valves |
Thanks Buz. I think I am going to go with the one that Mark mentioned, but would like to stay with the larger female fittings. I’m afraid to go to osmall with the fittings as I do not want to cut down on the fuel flow.
Jim!
Sent: Monday, August 06, 2007 4:20 PM
Jim.
Blue Skies,
Buz
Posted: Mon Aug 06, 2007 9:24 pm Post subject: Andair valves |
Jim,
The Facet fuel pump has 1/8 fittings in which you’ll install the 1/8 NPT to ¼ barb. I’ve installed these fittings on 10 planes so far with no problems. It shouldn’t be an issue to use the 1/8 NPT fittings on the fuel selector valve. If you’d like a point of reference take a look at the ¼ NPT 90 elbows compared to the 1/8 NPT to 90 elbows. Both have ¼ barbs on the other side. In tight spaces such as the center fuel console I think the 1/8 NPT will give you a little more space to work with.
Hope this helps.
Mark
Sent: Monday, August 06, 2007 10:52 PM
Subject: RE: Andair valves
Jim!
Jim.
Blue Skies,
Buz
Quote: | href="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0123456789
pete(at)flylightning.net Guest
Posted: Tue Aug 07, 2007 5:50 am Post subject: Andair valves |
Jim,
There are 1400 Jabiru airplanes flying around the world with 1/8 NPT fittings plus several hundred Zenith 601’s with our FWF kit that uses the same size. In fuel flow tests we see a flow of twice the expected high use. 1/8 NPT x ¼ hose is sufficient.
Pete
Sent: Monday, August 06, 2007 10:01 PM
Mark:
Jim!
Jim,
Hope this helps.
Mark
Quote: | http://forums.matronics.com | 0[/b] [/quote]12http://forums.matronics.com[/b] [/quote]3456789012345678
pequeajim
Posted: Tue Aug 07, 2007 11:14 am Post subject: Andair valves |
Ok, thanks for the update Pete.
On 8/7/07, Pete <pete(at)flylightning.net (pete(at)flylightning.net)> wrote: [quote]
Jim,
There are 1400 Jabiru airplanes flying around the world with 1/8 NPT fittings plus several hundred Zenith 601's with our FWF kit that uses the same size. In fuel flow tests we see a flow of twice the expected high use. 1/8 NPT x ¼ hose is sufficient.
Pete
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com)] On Behalf Of Jim Langley
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Mark:
Jim!
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com)] On Behalf Of Mark Stauffer
Jim,
Go to their web site http://www.andair.co.uk/system/index.html and you can configure the valve just about any way you like. I suggest that you configure it with either 1/8 NPT or ¼ NPT female fittings on all sides. This way you can use inexpensive brass elbows (90 & 45 with a ¼ barb on the other end) to connect up to the fuel line supplied with the kit. If I had my choice I'd use the 1/8 NPT fitting at least on the inlets because the 1/8 brass elbows are smaller and you're working with limited space in the center console.
These options weren't available when working with Joe and Linda's planes. We had to buy reducers from AN6 fittings to ¼ barbs. It works just fine but is bulky and adds weight.
Hope this helps.
Mark
Jim!012345678901
pequeajim
Posted: Wed Aug 08, 2007 3:24 pm Post subject: Andair valves |
Thanks for your help everyone. I ordered the FS20F7A which has the 1/8” female fittings on the sides. The only option for the back was the AN or ¼” size, so I picked a ¼” female fitting for the back.
Jim!
Jim,
Hope this helps.
Mark
