milneab(at)onetel.com Guest
Posted: Fri Jul 20, 2007 11:22 pm Post subject: Mod 73 results |
Add:
Alasdair Milne UK G-CBYN Completed None 1.75 (not changed) None
Quoting Richard Iddon <riddon(at)sent.com>:
| Quote: | There has been a suggestion that 'someone' should collate the findings
and results from doing mod 73.
I have also noted the way that the visitors to Oshkosh have added their
names to a round robin list. Maybe we could do something similar on the
forum for the mod.
As an example or to make a start
Name Country Airplane reg.
Progress on mod 73 Disbonding of TP6 pip pins used Any
problems found
Richard Iddon UK G-RIXS
Completed None found 2 in.
Nothing major
If anyone has any better idea, please feel free to add to the above,
modify or offer suggestions. Once most members have done the mod the
results can be emailed to the PFA although I guess that they will be
monitoring this site.
Richard Iddon G-RIXS
18/07/2007 15:30
riddon(at)sent.com Guest
Posted: Sat Jul 21, 2007 12:03 am Post subject: Mod 73 results |
Please check latest postings before adding your own and sending back. Otherwise some data may be missed out as several people send the spreadsheet back to the forum. I have added in everything I can find so far. The complete list is below. If you or any data is missing, please add it in.
Thanks.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Very slight movement in starboard TP12. Present on installing (1998)- no worse
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
These are new replacement tailplanes that had already been built
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
TP5 Port,Moved .25" Outboard
Alasdair Milne
UK
G-CBYN
Tri Gear
Completed
None
original
none
18/07/2007 15:30
pjeffers(at)talktalk.net Guest
Posted: Sat Jul 21, 2007 1:00 am Post subject: Mod 73 results |
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Iddon
Sent: 21 July 2007 09:02
Subject: Mod 73 results
Thanks.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
Original.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
Alasdair Milne
UK
G-CBYN
Tri Gear
Completed
None
original
none
18/07/2007 15:30 | Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
Release Date: 19/07/2007 18:10
20/07/2007 16:39
Trevpond(at)aol.com Guest
Posted: Mon Jul 23, 2007 7:54 am Post subject: Mod 73 results |
st1\:*{behavior:url(#default#ieooui) }
OK. I have transferred the results so far to a spreadsheet which I have copied and pasted below. I am not an expert so hope it works. Please fill in the blanks. And send it back to the forum. If anyone has been missed off I apologise but it is getting a little complicated.
It would be useful to know the total A/C hours and possibly the typical landig surface (grass/paved) to establish a correlation with failures?
Nigel
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
Completed
None found
Original
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
Completed
None found
2in.
none
Graham Drake
UK
G-CCOV
Mono
Completed
None found
1.9in.
Sarah Attubato
UK
G-BXDP
Mono
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
18/07/2007 15:30
18/07/2007 15:30
f="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
.matronics.com/">http://forums.matronics.com
dg.watts(at)talktalk.net Guest
Posted: Mon Jul 23, 2007 8:54 am Post subject: Mod 73 results |
bob.fairall(at)fairalls.c Guest
Posted: Mon Jul 23, 2007 9:46 am Post subject: Mod 73 results |
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of David Watts
Sent: 23 July 2007 17:54
Subject: Re: Mod 73 results
----- Original Message -----
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Sent: Monday, July 23, 2007 4:50 PM
Nigel
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
Completed
None found
Original
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
Completed
None found
2in.
none
Graham Drake
UK
G-CCOV
Mono
Completed
None found
2in.
Sarah Attubato
UK
G-BXDP
Mono
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
TrevPond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Bob Fairall
UK
G-BXLK
Mono
385
Grass
Completed
None found
2”
None
18/07/2007 15:30
18/07/2007 15:30 | Quote: | | f="http://www.matronics.com/Navigator?Europa-List">http://www.matron.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | | 0123456789 | Quote: | | f="http://www.matronics.com/Navigator?Europa-List">http://www.matron.matronics.com/">http://forums.matronics.com | 0 | Quote: | | f="http://www.matronics.com/Navigator?Europa-List">http://www.matron.matronics.com/">http://forums.matronics.com | 1 | Quote: | | f="http://www.matronics.com/Navigator?Europa-List">http://www.matron.matronics.com/">http://forums.matronics.com | 2
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
jron.jones(at)tiscali.co. Guest
Posted: Mon Jul 23, 2007 1:14 pm Post subject: Mod 73 results |
karelvranken(at)hotmail.c Guest
Posted: Tue Jul 24, 2007 1:22 am Post subject: Mod 73 results |
Posted: Tue Jul 24, 2007 1:12 pm Post subject: mod 73 results |
Tuesday 24th. 22:00 This is the full table of results I have compiled so far. If you have sent anything and it has been missed off, please email me directly and I will add it to the list.
Keep the info coming, it is certainly giving me more confidence in my ship.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365.00
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20.00
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
Alasdair Milne
UK
G-CBYN
Tri Gear
Completed
None
original
none
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Robert Marston
UK
G-CDBX
Tri Gear
230.00
Grass
Completed
None
Original
Bob Fairall
UK
G-BXLK
Mono
385
Grass
Completed
2”
None
Geoff Leedham
UK
G-EOFS
tri Gear
320
Grass
Completed
None found
1.9"
None found
Stephen Vestuti
UK
G-CEBV
22.00
Completed
Duncan McFadyean
UK
G-BXII
Tail Dragger
360.00
Mostly grass
Completed
none found
original
none
Karel Vranken
B
F-PKRL
Mono
60
Both
Done 2002
None found
Original
I did exactly what mod 73 prescribes before doing the lay ups.
23/07/2007 19:45
jrgowing(at)bigpond.net.a Guest
Posted: Tue Jul 24, 2007 2:14 pm Post subject: mod 73 results |
Richard Iddon and all
This list must be making everyone feel lots better.
I am not finished the build by a long shot but it is great to see this list of no disbonding of the TP6!
JR (Bob) Gowing in Oz UK Kit 327 with XS mods - starting filling but no instruments, engine etc
carl(at)flyers.freeserve. Guest
Posted: Tue Jul 24, 2007 11:53 pm Post subject: mod 73 results |
Sorry, but I must disagree !
Whilst the list is an interesting idea it proves nothing as regards disbonding or otherwise. I would be surprised even after 6 months if the list reveals any evidence of disbonding tailplanes - but I may yet be proved wrong.
Put yourself in the position of someone who had discovered a poorly manufactured tailplane -would you want the rest of the world to know (especially if you were the builder). What would be the insurance implications of admitting you might have a poorly constructed aircraft ? How might this affect a future claim? Many will take the view that its better to find out why it happened, fix it and say nothing.
Bearing in mind the implications of another failure the "survey" should have been done properly by the regulatory bodies whose mandate is to keep us flying safely. But maybe even they realise that even a "thorough" survey will not guarantee to reveal all cases of poor construction.
On the positive side, this episode has brought to everyones attention the need to have secure tailplanes and highlighted the importance of building to a high standard. If there were any loose tailplanes before it is pretty certain that will no longer be the case.
You know who I am - hard hat donned !
Posted: Wed Jul 25, 2007 12:22 pm Post subject: mod 73 results |
Carl,
Hard doesn't mean right. OK not every one has to recognise that his building was poor practise. We don't wait for a complete listing. At least it may give confidence to those who were reaching a good standard. Why do you think self build is half the price you put in the materials on the second hand market?
My two cents...
Karel Vranken, #447 F-PKRL
keithhickling(at)clear.ne Guest
Posted: Wed Jul 25, 2007 6:01 pm Post subject: mod 73 results |
Carl,
I don't think it is correct to imply that any disbonding is necessarily a result of poor construction. It could simply be a result of the inherent limitations of bonding between stainless steel and epoxy over time. The original design of the pip pin recess was intended to provide some security in the event of any disbonding, and the mod 73 provides additional bonding but also additional security in the event of disbonding. Comments such as yours may indeed inhibit people from providing information which is important for us all.
So guys, please do provide accurate information, then any appropriate mods can be designed to keep us all safe and the insurance companies happy.
Keith Hickling,
New Zealand,
Kit 613
Working on surface finishing and wiring, just doing mod 73, no disbonding but no flying either!
Posted: Wed Jul 25, 2007 7:32 pm Post subject: mod 73 results |
I'll second that...and Richard, "no good deed goes unpunished"...
Fred
a buildin A194
On Tuesday, July 24, 2007, at 03:13 PM, Laptop JR wrote:
| Quote: | Richard Iddon and all
believed to be clean.
Posted: Fri Jul 27, 2007 10:24 am Post subject: Mod 73 results |
All results to date below. I had a problem with my spreadsheet so have saved the results as a Word table. Hope everyone can read it OK now. If I have missed anyone off, please send me your results again off forum and I will add them in.
Richard Iddon G-RIXS.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Mainly Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
Alasdair Milne
UK
G-CBYN
Tri Gear
470
Grass
Completed
None
original
none
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Robert Marston
UK
G-CDBX
Tri Gear
230
Grass
Completed
None
Original
Bob Fairall
UK
G-BXLK
Mono
385
Grass
Completed
2”
None
Geoff Leedham
UK
G-EOFS
tri Gear
320
Grass
Completed
None found
1.9"
None found
Stephen Vestuti
UK
G-CEBV
Tri Gear
22
Tarmac
Completed
Duncan McFadyean
UK
G-BXII
Tail Dragger
360
Mostly grass
Completed
none found
original
none
Karel Vranken
B
F-PKRL
Mono
60
Both
Done 2002
None found
Original
Richard Holder
UK
G-OWWW
Tri Gear Classic
257
70% Grass
Completed
Port side disbonded
2in.
Some movement between left hand TP12 and TP4 – within limits.
Bob Harrison
UK
G-PTAG
Tri Gear
600
Completed
None
Original
Torque tube clamps fitted.
27/07/2007 06:08
nielskock(at)get2net.dk Guest
Posted: Sun Jul 29, 2007 7:50 am Post subject: Mod 73 results |
Richard, here are my mod 73 results:
Country DK
Aircr. reg OY-ODA
Type Mono Classic
Progress Completed
Disbonding TP6 None
Pins Original
Problems No slop
Kind regards,
Niels Kock
Posted: Mon Jul 30, 2007 12:01 am Post subject: Mod 73 results |
Thanks Niels.
Added to the list.
Richard.
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Niels Kock
Sent: 29 July 2007 16:50
Country DK
Aircr. reg OY-ODA
Type Mono Classic
Progress Completed
Disbonding TP6 None
Pins Original
Problems No slop
Kind regards,
Niels Kock
28/07/2007 15:50
28/07/2007 15:50
Posted: Mon Jul 30, 2007 9:09 am Post subject: Mod 73 results |
Dear All,
Below are up to date results of mod 73 implementation.
Please note that I shall be away for about a week from tomorrow but please keep the results coming. I will update the table and re publish on my return.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
Alasdair Milne
UK
G-CBYN
Tri Gear
470
Grass
Completed
None
original
none
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Robert Marston
UK
G-CDBX
Tri Gear
230
Grass
Completed
None
Original
Bob Fairall
UK
G-BXLK
Mono
385
Grass
Completed
2”
None
Geoff Leedham
UK
G-EOFS
tri Gear
320
Grass
Completed
None found
1.9"
None found
Stephen Vestuti
UK
G-CEBV
Tri Gear
22
Tarmac
Completed
Duncan McFadyean
UK
G-BXII
Tail Dragger
360
Mostly grass
Completed
none found
original
none
Karel Vranken
B
F-PKRL
Mono
60
Both
Done 2002
None found
Original
Richard Holder
UK
G-OWWW
Tri Gear Classic
257
70% Grass
Completed
Port side disbonded
2in.
Bob Harrison
UK
G-PTAG
Tri Gear
600
Completed
None
Original
Bruno Reith kit 379
D-EUVT
XS Mono
Just finished
Grass
Completed
Anthony van Eldik
UK
G-FLOR
Mono Classic
217
Grass
Completed
None
Original
None
David Joyce
UK
G-XSDJ
Mono
510
Both
Completed
None found
Original
Nothing significant.
Niels Kock
DK
OY-ODA
Mono
Completed
None
Original
No slop
Roddy Kesterton
UK
G-IKRK
Mon Classic wings
110
Mainly Grass
Completed
None found
2in.
None
29/07/2007 23:14
