WW 601 Fuel and Ign System Parts list UPDATE
Afterfxllc(at)aol.com
PostPosted: Tue Jul 24, 2007 9:34 am    Post subject: WW 601 Fuel and Ign System Parts list UPDATE Reply with quote
I found the coils and the fuel gauges and added them to the bottom.
Corvair_build_sheet.xls
 Filename:  Corvair_build_sheet.xls
 Filesize:  36 KB
 Downloaded:  679 Time(s)
rduns(at)sasktel.net
PostPosted: Tue Jul 24, 2007 6:40 pm    Post subject: WW 601 Fuel and Ign System Parts list UPDATE Reply with quote
Hi:
Thanks for updated list of fuel and Ign system parts.
You list facet fuel pump FP 40108 (at) 13.40. Do you know the difference between an FP 40108 and a plain 40108. Wicks lists FP 40108 and AS lists 40108 (at) 38.50 , no FP 40108. What does the "FP" mean.
Thanks.
Bob D.
601HD/Corvair
PostPosted: Tue Jul 24, 2007 8:10 pm    Post subject: WW 601 Fuel and Ign System Parts list UPDATE Reply with quote
That's just the way they do their part # it is the same pump. The price could be different when you order it but I saw it was cheaper there so I put it in.
Jeff
In a message dated 7/24/2007 10:41:09 P.M. Eastern Daylight Time, rduns(at)sasktel.net writes:
larry(at)macsmachine.com
PostPosted: Wed Jul 25, 2007 6:22 am    Post subject: WW 601 Fuel and Ign System Parts list UPDATE Reply with quote
Hi Bob,
FP could mean Facet Pump,,,, by a supplier that sells more than one mfr
type of pumps.
Larry
Bob Duns wrote:
Hi:
Thanks.
Bob D.
601HD/Corvair
