cedavis
Posted: Sun Jul 22, 2007 5:39 pm Post subject: Seized 447 |
Well, it finally happened. Yesterday, while going enjoying a late afternoon / sunset flight, I noticed two items slightly out of the ordinary:
While climbing out, the engine CHT's were higher then normal, approaching 400. When I throttled back, they dropped to around 300. This is still about 25-50 degrees higher then normal. Also, there was a slight "burp" in the engine, which lasted just a second. Other then that, every this was normal.
This morning, I returned for some early morning flying. CHT's we once again higher then normal, but well under the 400 red line. After a quick landing to adjust rudder trim, I took off again. Once again, CHT's went back up to 400. This time, the engine hick-uped, and dropped power on climb out. Immediately suspecting a seizure, I throttled back to idle and did a 180 and landed back on the runway. Total time from initiating take off to throttle back was probably 30 seconds.
When I throttled back, the CHT's continued to go up probably to around 500. Other then noticing, I didn't get much details, as I was focused on flying the plane and making what was essentially a deadstick landing (one of my better ones...)
EHT's were normal, 850-900, climbing to 1100 - 1200 if left in an extended 4000 rpm descent. Air temps were around 70.
Other obligations prevented me from doing any investigation, but I strongly believe it was a seizure. Then only clue I have is that I noticed the cooling fan was not turning when I pulled the engine through (after the seizure). Did the fan lock, or belt break? I don't know yet. Did it fail and cause the problem, or did the heat cause it to fail, resulting in the 500 CHT? Or did the seizure simply become worse, resulting in the 500 CHT's?
The engine has approximately 120 hrs. I pulled the exhaust at 50 hrs and the rings and pistons visible were loose and spotless. The engine had new gas and has always flown with Penzoil Aircooled.
Not much to do at this point, other then install the "spare" 477. Other then this detail, Lancaster County remains beautiful from 1000 feet.
Chuck
WhiskeyVictor36(at)aol.co Guest
Posted: Mon Jul 23, 2007 5:42 pm Post subject: Seized 447 |
In a message dated 7/22/2007 9:40:20 P.M. Eastern Daylight Time, ceddavis(at)gmail.com writes:
Quote: | Then only clue I have is that I noticed the cooling fan was not turning when I pulled the engine through (after the seizure). Did the fan lock, or belt break? |
Hi Chuck,
It would appear that the fan belt either broke or was slipping (check the fan holding nut to see if it is tight) for the fan not to turn with the crankshaft. That would result in getting the high CHT, as no cooling air would be coming across the heads.
Bill Varnes
Original Kolb FireStar
Audubon NJ
JetPilot
Posted: Tue Jul 24, 2007 1:12 pm Post subject: Re: Seized 447 |
The belt breaking would cause High CHT's, and probably overheat the engine.
An overheated engine like you are describing would not cause the belt to fail or stop working. Its a good idea to check that belt from time to time, for tension, slippage, and wear.
That belt failure is going to be expensive for you, but just be glad it did not result in any damage to your plane or you.
Mike
Kolb MK-III Xtra, 912-S |
possums(at)bellsouth.net Guest
Posted: Tue Jul 24, 2007 2:10 pm Post subject: Seized 447 |
At 05:12 PM 7/24/2007, you wrote:
Quote: | --> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
Mike |
Beauford Tuton described a similar problem with his 447 fan assembly. Something about the weld coming loose.
I can't find it in the achives.
beauford173(at)verizon.ne Guest
Posted: Tue Jul 24, 2007 4:00 pm Post subject: Seized 447 |
Possum, Sir:
That problem was with the weld on the recoil starter, not with the fan... my little
"overheat" was gummed up rings during the 447 Nazi Carbon Festival, Spring of '05,
it was... led directly to the "green dot" piston epiphany over at the Lockwood Castle...
As I recollect, a minor part malfunction with the famous Bing Brothers apparatus brought
about that particular episode...
(same engine though.... gotta love them there 447's... real character builders)
Anyone care for another glass of Seafoam...?
Beauford
FF076 / N173BW
Brandon, FL
Posted: Tue Jul 24, 2007 5:03 pm Post subject: Seized 447 |
They are "character builders" that's for sure. Mine used to hunt like a bird dog
any where under 5400 rpm. It was the old point ignition system though.
It is amazing to me what a difference a dual carb 503 made in my life.
I don't know if it's because of the two carburetors or just because it's a bigger engine
(the extra 10 hp come in handy too). Still set up like it cam out of the box.
Mine just stays put unless you pull the nose up or down, of course.
Have 738 hours now - and I know it needs a rebuild, but
I think it'll make it to 800 hours - then I'll throw it away and buy a new one.
I can still get'um wholesale, so it's worth it just for the new muffler and shiny carbs. [quote][b]
lucien
Posted: Tue Jul 24, 2007 6:09 pm Post subject: Re: Seized 447 |
FWIW, the 503 gives the wandering midrange RPM too when it's configured with a single carb.... it may be slightly better with the 503, but it'll still give you fits. I was never able to cure it on my early 503 that had a single carb.
Sure agree about the dual carbs, though, when I finally got my dual carb motor it was rock steady... heaven....
I loved my 447, though the single ignition had me even more attentive about those landing spots
LS
_________________ LS
Titan II SS |
Posted: Tue Jul 24, 2007 8:34 pm Post subject: Seized 447 |
At 10:09 PM 7/24/2007, you wrote:
character builders)
LS
Well ...there you go - that's the answer - put another carburetor on
it and be done with it!
See, it's not so hard when we put our heads together. Problem solved!
And that's how we do it right here in the good ole USA.
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Fri Jul 27, 2007 6:38 am Post subject: Seized UL II-02 repair questions |
I was just taking the cuyuna UL II-02 out of my Kolb Ultrastar last evening and preparing to put in the spare Cuyuna 430 that came with the deal.
The UL II-02 had a probable seizure on the #1 (PTO side) cylinder.
Examining the piston and cast iron liner its amazing how the piston top by the exhaust port had melted and eroded and that whole exhaust port side of the piston just lost its metal onto the liner wall making one hell of a mess.
The rings were intact but frozen in that side of the piston.
I was trying to dtermine if I could hone the liner smooth again, but it just looks like an awefull mess and I think I better replace the liner.
Anyone know how to remove a cylinder liner from a Cuyuna UL II-02?
When replacing Pistons, is that normally done in pairs or can I do just the seized one?
Ray
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
herbgh
Posted: Fri Jul 27, 2007 7:31 am Post subject: Seized 447 |
Ray
The ugly mess of aluminum on the wall needs to be etched away by using
muratic acid before you get too concerned about the liner.. That will
give you a better view of the damage the rings may have done ..
Careful...I use long q tips and eye protection.. Herb
On Fri, 27 Jul 2007 07:38:36 -0700 "jb92563" <jb92563(at)yahoo.com> writes:
the deal.
liner.
Ray
Ray
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=125885#125885
jb92563
Posted: Fri Jul 27, 2007 10:18 am Post subject: Re: Seized 447 |
Thanks for that tip about the acid.
I was thinking that the cylinder liner would be a lot harder than the aluminum and is probably servicable after removing the aluminum and honing a bit.
Now I just have to find the acid.....Home Depot carries it?
Looking at the cylinder shows the rings very recessed into the piston....probably melted into the piston allowing the piston skirt to hit the liner and the resulting mess.
Im optimistic that the rings were not able to contact the liner and do much damage.
Moni MotorGlider
Do Not Archive |
herbgh
Posted: Fri Jul 27, 2007 12:05 pm Post subject: Seized 447 |
Hi Ray
Building supplies companies... Used to clean brick etc.. Etches
aluminum quickly.. Does not hurt the steel liner.. Herb
On Fri, 27 Jul 2007 11:18:46 -0700 "jb92563" <jb92563(at)yahoo.com> writes:
and honing a bit.
Ray
http://forums.matronics.com/viewtopic.php?p=125919#125919
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Sat Jul 28, 2007 6:32 am Post subject: Re: Seized 447 |
Ray,
Herbs right , you can buy the acid at home depot or a pool store. I take the jug off before I acid so I don't drip any in the case, you have to take it off anyways to hone or replace. try not to get it on ANY aluminum you don't want damaged. It will stop foaming when all the aluminum is gone from cylinder.
Fly Safe,
Wade
jb92563
Posted: Mon Jul 30, 2007 6:50 am Post subject: Re: Seized 447 |
I found Muriatic Acid at the Do-it-center.
Well, I managed to disolve all the aluminum from the liner and found it looks pretty smooth and clean underneath that mess.
There were a couple bits that did not come off with the acid and does not foam when I apply more.
I think it might have been some carbon.
I managed to gently scrape it off with a knife however in one area and have a bit more to do just below the exhaust port.
After this I intend to finish the cylinder with a cylinder hone putting in the 60 degree cross hatch with the hone.
The piston that seized was at the PTO end so I think I ought to remove some of the cooling fins on the cylinder head next to the fan to make it of the "Flow Though" type to get more air to the rear cylinder head.
I noticed that they have these "flow though" heads for sale so it must help some.
Any suggestions, opinions or comments are welcome.
Ray
Moni MotorGlider
Do Not Archive |
bklebon(at)aol.com Guest
Posted: Fri Aug 03, 2007 5:59 am Post subject: Seized 447 |
I'm getting into this discussion a little late, but having worked with muriatic acid on swimming pools, make sure you are in a well ventilated area (preferably outside) and upwind. Don't get any on you!
jb92563
Posted: Fri Aug 03, 2007 6:49 am Post subject: Re: Seized 447 |
Fortunately I followed everyone advice and handled the muriatic acid with goggles and latex gloves. The fumes are nasty so I did it outside and was also aware of the Hydrogen gas fumes flamability so I keep the smokers away.
I soaked small bits of paper towel in the acid then layed them on top of the aluminum and watched it bubble away into nothing.
Took a little while and multiple applications but after probably 30 minutes it was all gone except for what looks like some carbon on the cylinder wall.
Gently scraped that carbon stuff off with a knife.
I still need to find the right hone and hone the liner.
Moni MotorGlider
Do Not Archive |
