nuckollsr(at)cox.net Guest
Posted: Sat Jul 14, 2007 8:49 am Post subject: Semi-Custom Products |
I've been working on a line of new products for the
AeroElectric Connection website that will be unique
to AEC. We're going to resist being a dealer for other
folks products.
One project utilizes an ECB and enclosure that has
features described in these two illustrations:
http://www.aeroelectric.com/DIY/A15_Package.jpg
http://www.aeroelectric.com/DIY/Do-Much_Board_Schematic.pdf
The schematic would never have ALL components installed,
and in some cases, components left of are replaced with
solid jumpers. However, depending on what parts are installed,
their values, and what software is installed in the microcontroller,
we can craft a variety of products with 98% commonality
of bill of materials.
The first product to be offered under this design and
marketing philosophy is described at:
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
. . . except that it will have a 15-pin connector on it
instead of a 9-pin.
I'm publishing the schematic for the more technically
inclined. Perhaps the architecture will suggest an application
close to your own wishes for a smart black box to do some
task. If so, let's talk about it and see if my software
guy can't whip it out in reasonably short order and save
you a lot of development time to craft a nicely packaged
electro-whizzy. Or, if you want to do your own byte-pudding
I could offer you a kit of ECB and enclosure from which
you could move your project ahead.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
klehman(at)albedo.net Guest
Posted: Sun Jul 22, 2007 5:27 am Post subject: Semi-Custom Products |
Bob
This may not fit into your philosophy of versatility but FWIW if I were
in the market for the LV/OV control board I would prefer to see the
lights and switch already mounted within the module. Second best would
be a pre-wired remote panel of lights and switch or at least the option
of purchasing those unassembled parts at the same time. I have learned
that it is nice to have all such remote assemblies of switches or lights
easily removeable as a unit for serviceability rather than mounted in
individual holes in the instrument panel. In addition where I've used a
single DB connector on a device for both power and a remote panel, I've
found it difficult to remove the remote panel for service or
modification since the connector is also hardwired to the aircraft.
We have completed 130 flight hours with our Z-14 wired subaru now
without any nuisance OV trips. The only electrical issue is that I
recently purchased a comfortable David Clarke headset and with our
fairly quiet engine, I now hear weak but annoying strobe whine that I
couldn't hear in cruise with other headsets. I have already followed
most of your wiring recommendations so it may take me awhile to solve
this one especially since the strobes operate off a different alternator
and battery as the radio and intercom.
Ken
| Quote: | Time: 09:49:43 AM PST US
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Semi-Custom Products
folks products.
instead of a 9-pin.
Posted: Tue Jul 24, 2007 2:08 pm Post subject: Semi-Custom Products |
At 09:27 AM 7/22/2007 -0400, you wrote:
Bob
This may not fit into your philosophy of versatility but FWIW if I were in
the market for the LV/OV control board I would prefer to see the lights
and switch already mounted within the module. Second best would be a
pre-wired remote panel of lights and switch or at least the option of
purchasing those unassembled parts at the same time. I have learned that
it is nice to have all such remote assemblies of switches or lights easily
removeable as a unit for serviceability rather than mounted in individual
holes in the instrument panel. In addition where I've used a single DB
connector on a device for both power and a remote panel, I've found it
difficult to remove the remote panel for service or modification since the
Keep in mind that the Do-Lots assembly is capable of being configured
for a multitude of tasks . . . many of which may not even have lights
and or switches. If I were addressing the single application cited, then
yes, avoiding the remotely mounted electronics module would be desirable.
One could always configure their own installation with the necessary
and useful in-line connectors to accommodate a maintenance situation.
| Quote: | We have completed 130 flight hours with our Z-14 wired subaru now without
any nuisance OV trips. The only electrical issue is that I recently
purchased a comfortable David Clarke headset and with our fairly quiet
engine, I now hear weak but annoying strobe whine that I couldn't hear in
cruise with other headsets. I have already followed most of your wiring
recommendations so it may take me awhile to solve this one especially
since the strobes operate off a different alternator and battery as the
radio and intercom.
Start with a test battery made up of a couple 6v
lantern batteries to run the strobe supply with a
short cable and batteries located right at the power
supply. You need to deduce the propagation mode. I suspect
it's conducted and a relatively simple filter at the
power supply will fix it.
