asav8tor(at)hotmail.com Guest
Posted: Fri Jul 20, 2007 10:39 pm Post subject: Water in Master switch |
Vans old 35 amp Honda alt
External Regulator
Split "Cessna" type master switch
During rainy weather canopy was opened and water got on the master switch.
Tried to mop it up but looked like some went down in the switch.
Next day started the aircraft and no amps charging after engine start.
Normal bus voltage with engine running is 14.2v now showing 12.2 ( no alt
power )
Shut down and blew compressed air into master switch.
Restarted amps charging and normal bus voltage 14.2 noted.
Flew a series of orientation flights. (kids summer camp) After the 6th
flight noticed a hum/beat sound in the radio/intercom. Bus voltage was
15.8v
Shut off alt on split master, voltage went down to 12.6v then turned alt
switch back on voltage returned to normal 14.2 hum/beat went away.
After engine start the higher voltage was noted several times but could be
fixed by turning the alt switch off then back on. It would then stay at the
normal 14.2v for the rest of the flight.
Should I:
(1) Replace the Master switch and recheck.
(2) Replace the Master switch and Voltage Regulator
(3) Replace the alt with a new plane-power 60amp int reg with overvoltage
protection
I don't want smoke in the cockpit. If the Voltage regulator was damaged I
don't want to start the engine again on the old unit.
Thanks in advance guys,
Mike
http://im.live.com/messenger/im/home/?source=hmtextlinkjuly07
docyukon(at)ptcnet.net Guest
Posted: Sat Jul 21, 2007 10:06 am Post subject: Water in Master switch |
Change master sw. Regulator side of switch is creating a voltage drop,
and telling regulator to increase output voltage. 99.9% sure it will cure
your problem of over voltage Bill
Posted: Sat Jul 21, 2007 6:08 pm Post subject: Water in Master switch |
New switch installed. All is good. Rock steady again at 14.2v
Took the old switch apart. Looked like a whole lot of junk in there. AL
dust and junk from when the acft was built? It was moist and almost pastey.
Mike
http://newlivehotmail.com
jabowenjr(at)hotmail.com Guest
Posted: Sat Jul 21, 2007 7:05 pm Post subject: Water in Master switch |
Hey Mike, If this is about your RV-4 I think you should just give up and
consider just giving it to me.
Jim Bowen -
Hope ya get it
figured out.
| Quote: | From: "Mike Adams" <asav8tor(at)hotmail.com>
Reply-To: aeroelectric-list(at)matronics.com
To: AeroElectric-List(at)matronics.com, asav8tor(at)hotmail.com
Subject: Water in Master switch
Date: Fri, 20 Jul 2007 23:37:18 -0700
External Regulator
power )
15.8v
the normal 14.2v for the rest of the flight.
Should I:
protection
Mike
