rv7ator
Posted: Sat Jul 21, 2007 7:04 am Post subject: Avionics master switch/relay |
I am wanting to use an avionics master switch or relay with my electrical system. My question is: Do I need to put all of my avionics on a separate bus then control the power to that bus by the avionics master? Also,what if I want just a portion of my avionics on my endurance bus? I have looked at all of the Z figures and cannot find an example.
Thanks in advance for your help.
Ed
RV-7
About to hang the engine
aurbo(at)ak.net Guest
Posted: Sat Jul 21, 2007 7:22 am Post subject: Avionics master switch/relay |
Ed,
Go to the archive search engine and type in avionics master switch. Lots of info. It may change your mind.
If not do it your way and put in an avionics master switch and a separate bus for avionics.
If you decide to go with out an avionics master than just put what you "need" to successfully land after the "dark and stormy night" episode on the endurance bus and put the rest on your main bus.
For an example take a look at the Z-11 schematic. Notice the way the main and endurance buses are laid out.
Mike Ice
Hanging the motor
Steve Glasgow
Posted: Sun Jul 22, 2007 2:01 am Post subject: Avionics master switch/relay |
Why not make the endurance bus and the avionics bus one and the same. On a friends RV7 we are doing this. He has a 60 A B&C alternator and a 20 A B&C standby alternator. The avionics/endurance bus is fed from the Main Bus through a diode and a S704-1 B&C relay switching circuit. Additionally, the avionics/endurance bus can be fed from the Battery Bus through another S704-1 relay switching circuit.
Schematics available on request.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
peter(at)sportingaero.com Guest
Posted: Sun Jul 22, 2007 1:14 pm Post subject: Avionics master switch/relay |
Ed,
If you still want to use an avionics master after reading all Bob has written you could try using 2 avionics buses, each energized by a relay both of which are switched by one double pole switch. Put your essential avionics on one bus and provide that with power direct from the battery via an emergency switch and diode. If the emergency switch is a double pole item also it could control power to your essential/endurance, non avionic, bus as well. Please be aware that the parts count has gone up and reliability has probably gone down, and I have not tried this set up.
Yours, Peter
nuckollsr(at)cox.net Guest
Posted: Tue Jul 24, 2007 1:47 pm Post subject: Avionics master switch/relay |
At 10:07 PM 7/22/2007 +0100, you wrote:
Or how about wiring per figure on page 4 of
http://aeroelectric.com/articles/avmaster.pdf
[quote]Ed,
Yours, Peter
