Thom Riddle
Posted: Thu Jul 19, 2007 7:08 am Post subject: flasher for landing lights |
I'm pretty good with things mechanical but admit to being rather ignorant about things electrical. So here is a question from the ignorant gallery:
My FS 1 has two little "landing" lights, one each mounted on a gear leg next to the cabin. There is no strobe light on the airplane. I'd like to become more obviously visible without the trouble and extra weight of adding a separate strobe light system. Could I install a flasher of some sort in the landing light circuit to increase visibility? If so, would it do much good for my intended purpose and how should it be done?
Any and all thoughts with as much detail as you care to offer will be appreciated.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Thu Jul 19, 2007 7:49 am Post subject: flasher for landing lights |
Thom,
I think Will U has a flasher system on his bird. Look in the archives i believe that he gave the details a while ago...
Good Luck
Mike
Oak Grove MO.
Mark III Classic.....
Thom Riddle <riddletr(at)gmail.com> wrote:
[quote]--> Kolb-List message posted by: "Thom Riddle"
My FS 1 has two little "landing" lights, one each mounted on a gear leg next to the cabin. There is no strobe light on the airplane. I'd like to become more obviously visible without the trouble and extra weight of adding a separate strobe light system. Could I install a [quote][b]
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
by0ung(at)brigham.net Guest
Posted: Thu Jul 19, 2007 10:20 am Post subject: flasher for landing lights |
I assume you have a switch that turns on the landing lights.... change it
for a single pole double throw switch that has 3 positions,,
" on off on" the power comes to the common pole.... if you connect
an inexpensive car type flasher between the other 2 poles, and the light
connects to only one side of the switch....
In the off position nothing is on
In the on position the power is from the center to the side with the light
hooked up direct
In the flash position.. the power is from the center through the flasher to
the light.
If you need me to draw it out let me know
Boyd
| Quote: | >>>>>>>>>>>>>>>>>>>
Thom Riddle
Posted: Thu Jul 19, 2007 10:42 am Post subject: Re: flasher for landing lights |
Thanks guys. It is simpler than I thought... as the Geico commercial says even Caveman(me) can do it.
Buffalo, NY (9G0)
- Anonymous |
