john(at)leptron.com Guest
Posted: Sun Jul 15, 2007 6:32 pm Post subject: 912UL max and cruise RPM |
Giovanni,
I use 5800 for take off, and climb. My cruise is almost always 5300 and
gives me 115-118 mph at medium load. If heavy loaded it will drop to 105-110
true.
Model 4 speedster
912ul
Short wing
NSI cap
On the 4 speedster 912UL what are most using for max and cruise RPM? What
airspeeds are you getting at those RPM on what prop? Thanks
_______________________________________
Giovanni Day
Model 4 speedster 912
wingnut
Posted: Mon Jul 16, 2007 12:15 pm Post subject: Re: 912UL max and cruise RPM |
According to the Rotax 912UL manual, with a variable pitch propeller, 75% power is achieved at 5000rpm and 27.2 in. HG manifold pressure. I gather that they qualify this with the need for a variable pitch prop because it would be hard to hit those exact numbers otherwise. My electric IVO prop comes in handy here. In practice though, 5000rpm and 26 in. Hg manifold pressure gets me as close to Vne as I care to fly in anything but dead calm air.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxmike
Posted: Mon Jul 16, 2007 1:47 pm Post subject: Re: 912UL max and cruise RPM |
I run the prop as flat as it will go on take off, with static at 5400 before takeoff. As I level off I hit the switch until I get 5400 and leave the throttle all the way in. I leave it there until I go to land. My speeds going eastbound to Arlington was 103kts ground speed ( about 120 mph)GPS, took me about an hour to get to wenatchee from spokane. On the return I was up to 120kts ground speed GPS, nice tail wind. When I landed in cle elum I had a nice head wind and floated onto the runway, way cool, winds were 15+, ellensburg was reporting 15 to 30mph. I have the patriot IVO in flight adjust.
Giovanni Day
Posted: Mon Jul 16, 2007 8:41 pm Post subject: Re: 912UL max and cruise RPM |
wingnut,
Wow, I must not have enough pitch or something is bad wrong. 5000 only gets me 90mph IAS and GPS. I do not have wheel pants or lift strut fairing or the radiator speed fairing on yet but I cannot imagine it will make 30MPH, assuming you are calling 120mph VNE. I have a 72in 3 bladed Warpdrive prop. I need a manifold pressure gauge for sure. Wow.
_________________ _______________________________________
Giovanni Day
Model 4 speedster 912 |
kitfoxfugit(at)yahoo.com Guest
Posted: Mon Jul 16, 2007 9:46 pm Post subject: 912UL max and cruise RPM |
and cruise RPM?
What airspeeds are you getting at those RPM on what
prop?
With the Ivoprop (ultralight), for takeoff, I use the
flatter climb pitch preset in the pattern slowing down
for landing, this gives 5800 for a max performance
takeoff (full throttle). After gaining sufficient
altitude, I blip the pitch to a steeper cruise, which
brings the RPM down to maybe 5200 or so, then screw
the power (throttle) back to 5000 RPM, with the
throttle back about 1.5" at low altitudes, maybe 1" at
higher altitudes. This gives about 117 mph at a
little less then 5GPH at lower altitudes at full gross
weight. It will go a little faster solo.
I should expirement more, but this seems to give the
most efficient balance. I have no MP guage, but if I
change the prop a little either way after setting the
power, it seems to go slower, ie too much pitch or not
enough. If the air is rough, I back off the power
some to with the same pitch to maybe 4800 RPM or a
little lower to cruise below manoevering speed. The
engine runs cooler with the Ivoprop than it did with
the GSC, but I have never tried cruising with full
throttle yet, even at high altitude.
I flight plan for the straight distance between
airports using 100 MPH at 5 GPH for 4 hours max,
normally 3 hours, especially where airports with gas
are scarce. This gives a margin for climbing,
crosswinds, headwinds, dodging storms, zigzagging
through passes, skirting airspace, finding
communications to close the flight plan, etc., with
more than sufficient fuel reserves.
John Allen
KF IV Speedster, 912UL, Ivoprop
O70 in central CA foothills & Sierras
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
kitfoxmike
Posted: Tue Jul 17, 2007 5:14 am Post subject: Re: 912UL max and cruise RPM |
I do the same for flight planning, 5gph, and for the same reasons.
wingnut
Posted: Tue Jul 17, 2007 5:32 am Post subject: Re: 912UL max and cruise RPM |
Quote: | Wow, I must not have enough pitch or something is bad wrong. 5000 only gets me 90mph IAS and GPS. I do not have wheel pants or lift strut fairing or the radiator speed fairing on yet but I cannot imagine it will make 30MPH, assuming you are calling 120mph VNE |
VNE on the model IV 1200 is 125. Even in dead calm weather, I'm not comfortable flying any closer than 115. If it's even a little little bumpy, I bring that down to 110. That's usually around 26 in Hg of manifold pressure for me. As you pointed out, you're probably pitched a little flatter then I am in this configuration. Without being able to adjust your pitch in flight, you have to make compromises between climb and cruise. With an 'in flight' adjustable prop, I can have my cake and eat it too .
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxmike
Posted: Tue Jul 17, 2007 9:52 am Post subject: Re: 912UL max and cruise RPM |
I was asked over the weekend why my fox goes so fast, my reply was, as I was grabbing the wing struts (plastic) must be because they are not glued, as I twisted them up. I said that when in flight they adjust to the center on their own.
wingnut
Posted: Tue Jul 17, 2007 10:37 am Post subject: Re: 912UL max and cruise RPM |
Quote: | I was asked over the weekend why my fox goes so fast |
I imagine that running WOT doesn't hurt too.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Giovanni Day
Posted: Tue Jul 17, 2007 11:01 am Post subject: Re: 912UL max and cruise RPM |
At what RPM are you guys calling WOT?
Giovanni Day
wingnut
Posted: Tue Jul 17, 2007 12:08 pm Post subject: Re: 912UL max and cruise RPM |
Quote: | At what RPM are you guys calling WOT? |
WOT = Wide Open Throttle. Meaning your throttle is pushed all the way in. Actual RPM will depend on air speed, prop pitch, density altitude, etc. Relevant to this discussion is the fact that an in flight adjustable prop lets you control your RPM without changing the throttle.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Float Flyr
Posted: Tue Jul 17, 2007 12:35 pm Post subject: 912UL max and cruise RPM |
WOT isn't an rpm. It means the throttle is all the way in and the manifold
pressure is close to 14 in Hg. Rpm will depend on how much bite you have
your prop set for.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Tue Jul 17, 2007 12:55 pm Post subject: 912UL max and cruise RPM |
Noel, shouldn't that actually be up around 28 or 29 inches MP (depending on
variables) when at full throttle? Perhaps we're talking about different
measurements?
Deke Morisse
N148DM
S5/Soob/CAP
NE Michigan
"The influence of each human being on others in this life is a kind of
immortality."
-- John Quincy Adams
Float Flyr
Posted: Tue Jul 17, 2007 2:26 pm Post subject: 912UL max and cruise RPM |
My bad... Too long out of grade school... its around 29.92 in. Hg. and 14.7
psi.. I looked it up this time:-). Funny thing is it didn't look right
when I wrote it and I changed it.....Sometimes you shouldn't second guess
yourself.
Noel
[quote] --
Kitfox III-A
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Tue Jul 17, 2007 5:50 pm Post subject: Re: 912UL max and cruise RPM |
Hmmm...This is an interesting thread of info. I should throw my numbers in...even tho they are not near so interesting.
3 blade taper tip 68"warp on a 692lb empty 912 UL speedster.
with me at 185lbs and half fuel or so....
no strut farings ....yet...wheel pants in the shed cause they get in the way.(and the way I land I am afraid I will knock em off!)
wot and 5700 rpms makes 105 mph..all shes got.
5000 rpms makes 90mph. maybe 95
WOT on takeoff makes about 5300
me and a 145 lb passenger...5000 rpms makes 80 to 85mph
I hope to look over some speedsters at OshKosh and see where mine can be improved.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Posted: Tue Jul 17, 2007 7:29 pm Post subject: 912UL max and cruise RPM |
Don G.
The strut fairings are the biggest and best mod you can make. I tried 4
different fairings until I found the best. That is the stuff that kitfox now
sales ( I think) from no fairings to the new is about 9 mph. The wood
fairing that was used behind the strut is about 3.5 mph. I was scared the
first time I flew with them, the plane used to hit a wall like yours and it
flew past that and changed her sound, weird, but very cool. You now have to
think about how to slow the thing down. My speedster is 720 lbs. And I
licensed it for 1320.
John Oakley
improved.
Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
http://www.geocities.com/dagger369th/my_firefly.htm
http://forums.matronics.com/viewtopic.php?p=124497#124497
Giovanni Day
Posted: Tue Jul 17, 2007 9:31 pm Post subject: Re: 912UL max and cruise RPM |
Did a little flying ad testing this afternoon. 5000RPM get me 3.7gph burn and 90mph indicated which is very close to ground speed with 0 wind. I had not tried WOT in straight and level. I am able to over rev the motor. I hit 5800 and about 110 mph. I say about because I had to back off to keep from over revving the engine. I think I need to add at least a degree of pitch. I read somewhere that to prolong the engine life of a 912ul one should not rev higher than 5500 even on climb out. I will add the pitch and see what happens.
I am looking at a set of the PVC strut fairing now.
Keep the good info coming.
Giovanni Day
kitfoxmike
Posted: Wed Jul 18, 2007 5:20 am Post subject: Re: 912UL max and cruise RPM |
Now here is my scoop. I don't let mine run past 5400 rpm. On climb out I will let it go to 5800, but just briefly, I will set the rpm with the elevator, not the prop. I want to get it up there so to speak. If I don't need the elevation, already at 1000agl, then I'm leveling and I'm setting the prop(you know, inflight adjust). As I level out the rpm's will increase of course, so I put in a little more adjust on the prop, I keep it at 5400rpm. I keep the throttle all the way in, call it what you want. If the rpm doesn't go over 5400 rpm you can run it all day like that. I've talked to a lot of people about this and they say it's OK, and not other pilots either. Now with my engine 912ul (80) if you have it set at 5400 rpm or 5000 rpm, the ground speed doesn't change, in fact it might loose a little going to a lower rpm, but it will run smoother.
av8rps(at)tznet.com Guest
Posted: Wed Jul 18, 2007 6:04 am Post subject: 912UL max and cruise RPM |
Giovanni,
I've found with my Kitfox IV-1200 912ul on amphib floats (with an IVO
inflight adust prop) that it goes the fastest with the throttle wide open
and the prop set for a 5400-5500 rpm, which is the max continuous horsepower
for the 912 (all 79 hp!)
Yes, get some of those fairings on your airplane, as I fly 90 mph+ at 5000
rpm, and I'm on floats with long wings!
I've attached a panel shot to inspire you. If my long wing kitfox on floats
can fly this fast on floats, your speedster should definitely go faster...
And here's a pic of my plane in flight. It's a neat little Kitfox, but it
can be cleaned up significantly yet. I have wing strut and horizontal
stabilizer strut fairings, but nothing on the jury struts, no gap seals,
poor fit around vertical fin to stab fairing, and no radiator fairing. Once
I do all that I expect I will go faster yet!
Paul Seehafer
Kitfox IV-1200 912ul on Aerocet amphibs
Description: |
Filesize: |
78.21 KB |
Viewed: |
522 Time(s) |
Description: |
Filesize: |
332.68 KB |
Viewed: |
560 Time(s) |
Posted: Wed Jul 18, 2007 7:23 am Post subject: 912UL max and cruise RPM |
Paul Seehafer
What a great looking fox, now I want to go and find a new set of floats to
go on mine...
John Oakley
