jeffpoint
Posted: Sun Jul 15, 2007 6:02 pm Post subject: Hangar building code issues |
I'm looking for someone with expertise on hangar building codes.
Specifically IBC 412.2.4 and how it relates to furnace installations.
Please email me at jpoint(at)mindspring.com.
It's RV related since I'm going to put my RV in the hangar.
Jeff Point
RV-6 flying
RV-8 building
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
bmeyette
Posted: Mon Jul 16, 2007 12:19 pm Post subject: Hangar building code issues |
I'm not familiar with IBC 412, but you'll also want to consult NFPA 409
Section 8 (http://brian76.mystarband.net/HangarDetails.htm#apr28-06)
Your local Fire Dept/Planning Office may have copi4s of these regs
It mainly depends on how much trouble your local bureaucracy wants to give
you. I've tried it in a bad place and done it in a good place; huge
difference:
http://brian76.mystarband.net/hangar.htm
brian
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Jul 16, 2007 12:44 pm Post subject: Hangar building code issues |
I called the local building inspection dept that would ultimate do the
inspection for my hangar. That way I knew what they would be looking for.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
lsbrv7a(at)yahoo.com Guest
Posted: Mon Jul 16, 2007 2:00 pm Post subject: Hangar building code issues |
I can send a copy of NFPA 409 in pdf format if you wish. Just let me know. I will need to look at the IBC, but can probably send that as well. I will need the year or edition adopted. I will be back in the states and functioning on Thurs. Iceland is a pretty visit.
<<<<<: "Brian Meyette"
| Quote: | On Behalf Of Jeff Point
Subject: Hangar building code issues
--> RV-List message posted by: Jeff Point
Jeff Point
RV-6 flying
RV-8 building
Milwaukee
Sherman Butler
RV-7a Wings
Idaho Falls
Fussy? Opinionated? Impossible to please? Perfect. [url=http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7 ]Join Yahoo!'s user panel[/url] and lay it on us. [quote][b]
jeffpoint
Posted: Mon Jul 16, 2007 11:37 pm Post subject: Hangar building code issues |
That would be great. I know the IBC adopted is 2003 and I have that
book, but I don't have the NFPA. A pdf would be great.
Jeff
Sherman Butler wrote:
| Quote: | I can send a copy of NFPA 409 in pdf format if you wish. Just let me
RV-6
Milwaukee WI |
jeffpoint
Posted: Mon Jul 16, 2007 11:51 pm Post subject: Hangar building code issues |
Dale Ensing
That's the problem- I called the building inspector up front and asked
him about the requirements, and he referred me to IBC 412 and the
related Wisconsin building code as the ruling documents. Both of these
spell out the absurdly ridiculous 10 foot above the airplane height
requirement. There isn't a hangar on my airport, nor likely in the
state that conforms to this, yet he won't budge on the issue. So much
for trying to work with the inspector and being reasonable.
Jeff
RV-6
Milwaukee WI |
billsettle(at)bellsouth.n Guest
Posted: Tue Jul 17, 2007 1:16 am Post subject: Hangar building code issues |
Another downside to all this is that it has been my experience that you may try to comply with what one inspector wants only to have a different inspector come out and require something else.
Bill Settle
Date: 2007/07/17 Tue AM 02:45:29 EST
To: rv-list(at)matronics.com
Subject: Re: Hangar building code issues
Dale Ensing
Jeff
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Tue Jul 17, 2007 4:27 am Post subject: Hangar building code issues |
Jeff:
I am jumping into this thread midstream so hope this hasn't been mentioned.
We had a guy just build a hangar at MNM and came up against the same BS.
What he did is have his electrician wire just one overhead light, well
removed from where any airplane would get 10 ft away, and then had it
inspected. Once he didn't see the inspector's tailights, up went more
lights.
One other thing....At least in MI, if you install lights that are inclosed
with some sort of diffuser, then the 10 ft rule does not apply. In other
words, a bare bulb type of light is what they get bent out of shape about.
Jeff Orear
RV6A N782P
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
tiger10(at)centurytel.net Guest
Posted: Tue Jul 17, 2007 8:14 am Post subject: Hangar building code issues |
We at kpso Pagosa Springs co, had this proble =m for a while, the 10 ft
thing, and after talkoing to the fire marshal got a reasonable opinion that
10 ft. from the fuel system was going to be OK. Most of our hangars are at
least 14 ft high,some a lot more, and it the heater is in a rear corner, you
will have more than enough room.
Jim Carey asn kpso
Posted: Tue Jul 17, 2007 3:42 pm Post subject: Hangar building code issues |
Jeff Point wrote:
Dale Ensing
Jeff
Then don't build a hangar. Build a big storage building with a really
big entry door.
You need to think like a bureaucrat. For instance, it's almost always
easy to get a 'special vfr' clearance to depart an airport, but it will
never be offered to you. (Ya gotta ask.)
cjensen(at)dts9000.com Guest
Posted: Wed Jul 18, 2007 4:20 am Post subject: Hangar building code issues |
A little off subject, but since Charlie mentioned "special VFR", I
recall a while back before I got my IFR ticket that one morning I was
waiting to hop over the mountains from Knoxville TYS. There was a low
layer of wispy fog laying over the area that was just thick enough to be
below MVFR. I talked to the tower and they said it might clear in a
half hour or so. When I called about 15 minutes later to see if it had
improved, the tower wondered, in a slow, methodical query, if there was
anything "special" I would like request. Being denser than a rock and
dumber than a stump, it was only later that I understood what he was
hinting at. Yes, they can accommodate, but they can't offer.
However, bureaucrat can offer, but usually don't...unless you ply them
with enough donuts to go with their early morning coffee, mid morning
coffee and before lunch coffee!
Chuck Jensen
Posted: Wed Jul 18, 2007 8:52 am Post subject: Hangar building code issues |
Jeff, what exactly is the jurisdisction? I can check with my buddies and see if a friend can be contacted in the local area that knows teh personalities involved. The inspector has a boss, she/he may interpert it differently, or other sections of the code my apply.
What type of fuel? If it is wood then a ten feet stack or a spark arrestor may be required. It will make little diferance if it is a hangar or storage shed (hangar is french for shed, IBC is Internatational Building Code.).
Charlie England <ceengland(at)bellsouth.net> wrote:
| Quote: | --> RV-List message posted by: Charlie England
Jeff Point wrote:
| Quote: | --> RV-List message posted by: Jeff Point
Dale Ensing
big entry door.
Sherman Butler
RV-7a Wings
Idaho Falls
8:00? 8:25? 8:40? [url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news] Find a flick[/url] in no time
with the[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news]Yahoo! Search movie showtime shortcut.[/url] [quote][b]
