hdwysong(at)gmail.com Guest
Posted: Fri Jul 13, 2007 12:37 am Post subject: best contactor reliability -- mechanical, solid state, or ma |
I have a remotely operated application where the loss of the
master battery contactor will result in the loss of
data/money/time (... and dignity!). My baseline design
resembles a "Z" diagram (thanks Bob!) and I planned to use a
mechanical, continuous duty contactor like the S-701 from
B&C. However, a buddy of mine recently experienced a
contactor failure in flight and it caused me to experience a
few "What If!?" nightmares. I'm back to reconsidering my
original decision...
I wish I could skip the contactor entirely, but the
components hanging off the master bus aren't switched (no
ON/OFF control) so I need a master contactor to switch power.
The options I toyed with initially were a mechanical can
(S-701), a solid state relay (Crydom D06D series), or a "hot
rod" manual switch.
I've had good personal experience with the cans (no failures
yet in hundreds of hours of flying). Sure, they get hot and
use/waste a little power but they have a good heritage. Had
my buddy not experienced a failure, I probably wouldn't have
worried at all. Now, I can't avoid worrying.
I've had good experience with the Crydom SSRs, too, and have
only seen one coaxed to failure by a well-intentioned
technician (25 Adc through a 7 Adc device... poof!). Low
power consumption, rugged, compact, moderately priced.
I've quizzed folks here about using manual "hot rod"
contactors and received some great feedback (e.g. - don't
use the cheap ones!). Seemed bulletproof at first, but
recent posts suggested these things can/have/will fail, too.
Perhaps it's just a problem with the cheap ones? Dunno.
So, I'm sitting at square one (again!) trying to determine
which of these options is most likely to keep me out of hot
water. I realize there is no "100% reliable" solution, but
I'm weighing my options to get the greatest number of 9's in
the long run.
Any feedback/wisdom from you folks will be greatly appreciated.
D
khorton01(at)rogers.com Guest
Posted: Fri Jul 13, 2007 1:35 am Post subject: best contactor reliability -- mechanical, solid state, or ma |
On 13 Jul 2007, at 04:38, D Wysong wrote:
I have a remotely operated application where the loss of the master
battery contactor will result in the loss of data/money/time (...
and dignity!). My baseline design resembles a "Z" diagram (thanks
Bob!) and I planned to use a mechanical, continuous duty contactor
like the S-701 from B&C. However, a buddy of mine recently
experienced a contactor failure in flight and it caused me to
experience a few "What If!?" nightmares. I'm back to reconsidering
my original decision...
I wish I could skip the contactor entirely, but the components
hanging off the master bus aren't switched (no ON/OFF control) so I
The options I toyed with initially were a mechanical can (S-701), a
solid state relay (Crydom D06D series), or a "hot rod" manual switch.
I've had good personal experience with the cans (no failures yet in
hundreds of hours of flying). Sure, they get hot and use/waste a
little power but they have a good heritage. Had my buddy not
experienced a failure, I probably wouldn't have worried at all.
I've had good experience with the Crydom SSRs, too, and have only
seen one coaxed to failure by a well-intentioned technician (25 Adc
through a 7 Adc device... poof!). Low power consumption, rugged,
I've quizzed folks here about using manual "hot rod" contactors and
received some great feedback (e.g. - don't use the cheap ones!).
Seemed bulletproof at first, but recent posts suggested these
things can/have/will fail, too. Perhaps it's just a problem with
So, I'm sitting at square one (again!) trying to determine which of
these options is most likely to keep me out of hot water. I
realize there is no "100% reliable" solution, but I'm weighing my
options to get the greatest number of 9's in the long run.
I assume that this is not an aircraft we are talking about.
If you have an application where you must absolutely ensure
continuity of power, then you have to assume that any single
component could someday fail, no matter how good quality that
component is. How about two contactors in parallel, with some sort
of periodic check to ensure that they are both working, or some way
to monitor them to have evidence that they are both working? For
monitoring, you could have each contactor feeding through a diode,
and monitor the voltage between the contactor and the diode. If the
contactor fails, that voltage will drop. If the voltage shows that
both contactors are closed, you could monitor that voltage to show
that each contactor can be opened (one at a time, so you don't stop
providing power to your application).
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Eric M. Jones
Posted: Sat Jul 14, 2007 7:08 am Post subject: Re: best contactor reliability -- mechanical, solid state, o |
Some reuse from an email to a customer here...)
Compare---
_____________________________Type 70__________GX-11
Weight.........................12.5 Oz.............18 Oz
Temp...........................50 DegC...........75-85 DegC
(50 degC 122 F) makes the type 70 unusable....
Position........................Cap Down..........Any
Environmental...............Dust-Proof.........Hermetically sealed
Coil Suppression............Must be added....Built in
B&C Type 70 uses diodes, GX-11 uses transorbs (SnapJacks!)
Continuous Amps............80 at 50C..........150A at 75C
Inrush A.........................150...................500-2000
Open against Vmax.......... 35V.................>>100V
(...same as Kilovac)
Hold current.....................1.0 A................700 mA
(Kilovac is 100 mA, Gigavac has lower hold currents on request)
G-force opening...............2G ??................>>10G
Anyway the GX11 will be about $120, but the Type 70 ($37.00 from Newark) is not really useable in my opinion. You may want the accessory contacts and long leads...couldn't hurt.
The Kilovac EV200aaana (aka Blue Sea 9012) is still great (similar to the Gigavac GX11).
The type 70 is problematic even if very common and long in the tooth. It is deficient in four main areas:
1) Poor coil suppression (this can be retrofitted to improve it)
2) Inadequate operating temperature. My GUESS is that the early ones had fiber/bakelite interiors, now they are Nylon. Regardless 122F spec is way too low to use.
3) Inadequate G force withstand. 2G ??
4) Open against Vmax. 35V. They could sustain an arc if the alternator runs away.
Pure solid state solutions are not quite ready. I have experimented with this, and continue to do so. There are some remarkable devices in development.
Mechanical contactors--"Flaming River" seems to come up when people talk about quality. I would like some people to describe what happens to lower quality mechanical contactors, but I haven't heard details.
"The despotism of custom is everywhere...the standing hindrance to human advancement."
--John Stuart Mill
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Eric M. Jones
Posted: Mon Jul 16, 2007 2:38 pm Post subject: Re: best contactor reliability -- mechanical, solid state, o |
I just ran across these. They should do. They are a little more expensive than the GX-11 or the Blue Sea 9012 (Kilovac EV200aaana). Frankly I can't see an advantage unless you find them on sale.
http://www.omron.com/ecb/products/pdf/en_g9ea_ec.pdf
Interesting note on coil suppressor from the Omron data sheet:
They caution that a varistor or a Zener plus diode should be used as a protective circuit for the coil. "Using a diode alone will reduce the switching characteristics."
Never use diodes for this purpose on relays, especially contactors.
"What the West really has to offer is honesty. Somehow, in the midst of their horrid history, the best among the Gaijin learned a wonderful lesson. They learned to distrust themselves, to doubt even what they were taught to believe or what their egos make them yearn to see. To know that even truth must be scrutinized, it was a great discovery.... "
-- David Brin, "Dr. Pak's Preschool"
113 Brentwood Drive
(508) 764-2072
